TCP server can't reconnect with TCP client!
Other Parts Discussed in Thread: CC3200, CC3200SDK, CC3200MOD
PC or Smartphone is tcp client and CC3200 is tcp server in AP mode.
Socket connection succeeded and client send packets to server.
Through a sl_Recv() function, I can received packets very well.
But the client disconnect to server, there isn't any return values from sl_Recv().
It's polling on sl_Recv(). When the client attempt to reconnect server, sl_Recv() return error value and then it's can't connect to server.
How can a client reconnect to server?
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
    char            received_data[100];
    //filling the TCP server socket address
    sLocalAddr.sin_family = SL_AF_INET;
    sLocalAddr.sin_port = sl_Htons((unsigned short)5001);
    sLocalAddr.sin_addr.s_addr = 0;
    // creating a TCP socket
    iSockID = sl_Socket(SL_AF_INET,SL_SOCK_STREAM, 0);
    if( iSockID < 0 )
        // error
        ASSERT_ON_ERROR(SOCKET_CREATE_ERROR);
    iAddrSize = sizeof(SlSockAddrIn_t);
    // binding the TCP socket to the TCP server address
    iStatus = sl_Bind(iSockID, (SlSockAddr_t *)&sLocalAddr, iAddrSize);
    if( iStatus < 0 )
        // error
        sl_Close(iSockID);
        ASSERT_ON_ERROR(BIND_ERROR);
       // putting the socket for listening to the incoming TCP connection
    iStatus = sl_Listen(iSockID, 0);
    if( iStatus < 0 )
        sl_Close(iSockID);
        ASSERT_ON_ERROR(LISTEN_ERROR);
    // setting socket option to make the socket as non blocking
    iStatus = sl_SetSockOpt(iSockID, SL_SOL_SOCKET, SL_SO_NONBLOCKING,
                            &lNonBlocking, sizeof(lNonBlocking));
    if( iStatus < 0 )
        sl_Close(iSockID);
        ASSERT_ON_ERROR(SOCKET_OPT_ERROR);
    for(;;)
        iNewSockID = SL_EAGAIN;
        // waiting for an incoming TCP connection
        while( iNewSockID < 0 )
            // accepts a connection form a TCP client, if there is any
            // otherwise returns SL_EAGAIN
            iNewSockID = sl_Accept(iSockID, ( struct SlSockAddr_t *)&sAddr,
                                    (SlSocklen_t*)&iAddrSize);
            if( iNewSockID == SL_EAGAIN )
               //MAP_UtilsDelay(10000);
                osi_Sleep(1);
            else if( iNewSockID < 0 )
                // error
                sl_Close(iNewSockID);
                ASSERT_ON_ERROR(ACCEPT_ERROR);
        for(;;)
            //received packets from the connected TCP client
            iStatus = sl_Recv(iNewSockID, received_data, 1000);
            if( iStatus < 0 )
                //error
                break;
            else if( iStatus > 0 )
                received_data[iStatus] = 0;
                UART_PRINT("Received Data: %s\n\r",received_data);
            else
                break;
cs
