Other Parts Discussed in Thread: TEST2
Tool/software: Linux
I use ti-processor-sdk-linux-am57xx-evm-03.00.00.04 , kernel is 4.4.12 .
Follow the steps in http://processors.wiki.ti.com/index.php/WL18xx_System_Build_Scripts to enable Wlan0 on WL1873Q.
Below are command line outputs when running step #3 (./build_wl18xx.sh init) and step#4 (./build_wl18xx.sh update R8.7_SP1) in the aforementioned guide.
Command line output errors are highlighted in red (at the end of this post). There is no fs_skeleton.tbz2 generated under build-utilities/outputs folder even after run step#3 again, why?
Q1: In Step4, how can one tell the release tage name?
Q2: What does it mean for adjusting permission in the context of this guide "If the fs_skeleton.tbz2 file is not present, try adjusting the permissions of the files present in the build-utilities directory and go back to Step 3 to download the source again." Permission of the files on my machine are listed below:
xub@FTEFlex:~/wl8-build/build-utilites$ ls -l
total 148
-rwxrwxr-x 1 xub xub 32655 Apr 7 16:55 _build_with_sudo.sh
-rwxrwxrwx 1 xub xub 32027 Apr 7 16:01 build_wl18xx.sh
-rwxrwxr-x 1 xub xub 32028 Apr 7 16:53 build_wl18xx.sh.save
drwxrwxr-x 2 xub xub 4096 Apr 7 16:01 configuration
-rwxrwxr-x 1 xub xub 1521 Apr 7 16:01 configuration.sh
drwxrwxr-x 2 xub xub 4096 Apr 7 16:23 downloads
drwxrwxrwx 2 xub xub 4096 Apr 7 16:09 outputs
drwxrwxr-x 3 xub xub 4096 Apr 7 16:01 patches
-rw-rw-r-- 1 xub xub 139 Apr 7 16:01 README
-rwxrwxrwx 1 xub xub 1637 Apr 7 16:08 setup-env
-rw-rw-r-- 1 xub xub 1486 Apr 7 16:01 setup-env.sample
drwxrwxr-x 16 xub xub 4096 Apr 7 16:58 src
-rwxrwxrwx 1 xub xub 793 Apr 7 16:01 sudo_build_wl18xx.sh
drwxrwxr-x 2 xub xub 4096 Apr 7 16:09 tftp
drwxrwxr-x 2 xub xub 4096 Apr 7 16:09 toolchain
-rwxrwxrwx 1 xub xub 2118 Apr 7 16:01 verify_kernel_config.sh
Command line output
