Part Number: CC3100MOD
Other Parts Discussed in Thread: UNIFLASH, CC3100, CC3200, , TPS54336A
My customer recently received quite a number of RMA for their CC3100MOD-based product.
It is found that while calling sl_WlanPolicySet( ... ), the SimpleLinkGeneralEventHandler( ) return the following 2 errors:
pDevEvent->Event=1,
pDevEvent->EventData.deviceEvent.status=-77,( SL_ERROR_FS_FILE_TABLE_LOAD_FAILED )
pDevEvent->EventData.deviceEvent.sender=6
pDevEvent->Event=1,
pDevEvent->EventData.deviceEvent.status=-78,( SL_ERROR_PREFERRED_NETWORKS_FILE_LOAD_FAILED )
pDevEvent->EventData.deviceEvent.sender=2
While using UNIFlash to re-format and program the device, UNIFlash gives the Flash erase error as shown in the UNIFlash log below.
Please advise what could be the possible cause of error? Note that all these failure devices were working perfectly before.
UNIFlash log:
[18:55:07] Begin Format operation.
[18:55:08] INFO: > Executing Operation: Connect
[18:55:08] DEBUG: waiting and clearing uart rx buffer
[18:55:10] INFO: setting break signal
[18:55:10] DEBUG: wait for ack
[18:55:11] DEBUG: UART timeout
[18:55:11] DEBUG: --- COM Port timeout on ACK read
[18:55:11] INFO: detecting FTDI for device reset
[18:55:11] DEBUG: got 0 devices connected
[18:55:11] ERROR: No device USB ports were found
[18:55:11] INFO: --- please restart the device ---
[18:55:11] DEBUG: wait for ack
[18:55:12] INFO: connection succeeded
[18:55:12] INFO: getting storage list
[18:55:12] DEBUG: wait for ack
[18:55:12] INFO: > Executing Operation: Init
[18:55:12] INFO: reading version info
[18:55:12] INFO: DEVICE CC3100 ES1.33
[18:55:12] DEBUG: Bootloader version is 2, 0, 4, 0
[18:55:12] DEBUG: raw storage write
[18:55:12] DEBUG: status request
[18:55:12] DEBUG: BlockSize is 4096, number of blocks is 16
[18:55:12] DEBUG: erasing 13 blocks starting from 0
[18:55:13] DEBUG: wait for ack
[18:55:13] DEBUG: status request
[18:55:14] DEBUG: wait for ack
[18:55:14] DEBUG: status request
[18:55:14] DEBUG: 0
[18:55:14] INFO: > Executing Operation: Format
[18:55:14] INFO: Erase storage SFLASH
[18:55:20] DEBUG: status request
[18:55:20] DEBUG: wait for ack
[18:55:20] DEBUG: Error 74 : Fail
[18:55:20] INFO: erase storage failed
[18:55:20] INFO: erase storage completed
[18:55:20] INFO: > Executing Operation: Disconnect
[18:55:20] DEBUG: disconnecting from device . . .
[18:55:20] Operation Format returned.
[18:56:09] Begin ServicePackProgramming operation.
[18:56:09] INFO: > Executing Operation: Connect
[18:56:09] DEBUG: waiting and clearing uart rx buffer
[18:56:11] INFO: setting break signal
[18:56:11] DEBUG: wait for ack
[18:56:12] DEBUG: UART timeout
[18:56:12] DEBUG: --- COM Port timeout on ACK read
[18:56:12] INFO: detecting FTDI for device reset
[18:56:12] DEBUG: got 0 devices connected
[18:56:12] ERROR: No device USB ports were found
[18:56:12] INFO: --- please restart the device ---
[18:56:12] DEBUG: wait for ack
[18:56:13] INFO: connection succeeded
[18:56:13] INFO: getting storage list
[18:56:14] DEBUG: wait for ack
[18:56:14] INFO: > Executing Operation: ServicePackProgramming
[18:56:14] INFO: Path to the service pack file: D:/ti/CC3100_CC3200_ServicePack_1.0.1.11-2.9.0.0/servicepack_1.0.1.11-2.9.0.0.bin
[18:56:14] INFO: reading version info
[18:56:14] INFO: CC3100R Device detected.
[18:56:14] INFO: NWP/MAC/PHY Version from Service Pack:
[18:56:14] INFO: NWP Patch version: 2.8.99.0
[18:56:14] INFO: MAC Patch version: 1.4.0.1
[18:56:14] INFO: PHY Patch version: 1.0.3.37
[18:56:14] INFO: DEVICE CC3100 ES1.33
[18:56:14] DEBUG: Bootloader version is 2, 0, 4, 0
[18:56:14] DEBUG: raw storage write
[18:56:14] DEBUG: status request
[18:56:14] DEBUG: BlockSize is 4096, number of blocks is 16
[18:56:14] DEBUG: erasing 13 blocks starting from 0
[18:56:15] DEBUG: wait for ack
[18:56:15] DEBUG: status request
[18:56:15] DEBUG: 0
[18:56:16] DEBUG: wait for ack
[18:56:16] INFO: Downloading file "/sys/servicepack.ucf" with size 31348
[18:56:16] DEBUG: sending start download command
[18:56:16] DEBUG: Granularity conversion: G(1024) * N(128) = 131072
[18:56:16] DEBUG: Access code is 3
[18:56:16] DEBUG: wait for ack/nack
[18:56:16] DEBUG: receive nack
[18:56:16] ERROR: Open operation failed
[18:56:16] DEBUG: status request
[18:56:16] DEBUG: Error 66 : Invalid command
[18:56:16] INFO: > Executing Operation: Disconnect
[18:56:16] DEBUG: disconnecting from device . . .
[18:56:16] Operation ServicePackProgramming returned.
- Thomas
