Hi All,
I know there is a AT command document for cc3220, SWRU534D.
May I know is there any AT command to support CC3235 especially for switching Wi-Fi band?(2.4G/5G)?
Thanks a lot.
Hi All,
Thanks a lot.
No, the ATCMD library currently doesn't support the commands to control the active band(s), such as :
SL_WLAN_GENERAL_PARAM_OPT_ENABLE_5G,
SL_WLAN_GENERAL_PARAM_OPT_SCAN_PARAMS_5G
It is possible to add these by updating the ATCmdWlan_setParse() function (in the library).
You will need to add the right cases to the SL_WLAN_CFG_GENERAL_PARAM_ID switch:
else if (setParams->id == SL_WLAN_CFG_GENERAL_PARAM_ID) { if ((ret = StrMpl_getListVal(ATCmd_wlanGenCfg,sizeof(ATCmd_wlanGenCfg)/sizeof(StrMpl_List_t),&buff,&setParams->option,ATCMD_DELIM_ARG, sizeof(setParams->option))) < 0) { return ret; } switch (setParams->option)
Br,
Kobi
Hi Kobi,
I check all ATCmd_wlanGenCfg or ATCmd_wlanApCfg, there is NO specific keyword for 2.4G/5G settings.
So if I add kind of this "{"ENABLE_5G", SL_WLAN_GENERAL_PARAM_OPT_ENABLE_5G},"
Is this correct? Especially for yellow part....not sure its working on CC3235....
StrMpl_List_t ATCmd_wlanApCfg[12] =
{"ssid", SL_WLAN_AP_OPT_SSID },
{"channel", SL_WLAN_AP_OPT_CHANNEL },
{"hidden_ssid", SL_WLAN_AP_OPT_HIDDEN_SSID },
{"security", SL_WLAN_AP_OPT_SECURITY_TYPE },
{"password", SL_WLAN_AP_OPT_PASSWORD },
{"max_stations", SL_WLAN_AP_OPT_MAX_STATIONS },
{"max_sta_aging", SL_WLAN_AP_OPT_MAX_STA_AGING },
{"access_list_mode", SL_WLAN_AP_ACCESS_LIST_MODE },
{"access_list_add_mac", SL_WLAN_AP_ACCESS_LIST_ADD_MAC },
{"access_list_del_mac", SL_WLAN_AP_ACCESS_LIST_DEL_MAC },
{"access_list_del_idx", SL_WLAN_AP_ACCESS_LIST_DEL_IDX },
{"access_list_num_entries", SL_WLAN_AP_ACCESS_LIST_NUM_ENTRIES}
StrMpl_List_t ATCmd_wlanGenCfg[7] =
{"country_code", SL_WLAN_GENERAL_PARAM_OPT_COUNTRY_CODE },
{"sta_tx_power", SL_WLAN_GENERAL_PARAM_OPT_STA_TX_POWER },
{"ap_tx_power", SL_WLAN_GENERAL_PARAM_OPT_AP_TX_POWER },
{"info_element", SL_WLAN_GENERAL_PARAM_OPT_INFO_ELEMENT },
{"scan_params", SL_WLAN_GENERAL_PARAM_OPT_SCAN_PARAMS },
{"suspend_profiles", SL_WLAN_GENERAL_PARAM_OPT_SUSPEND_PROFILES },
{"disable_ent_server_auth",SL_WLAN_GENERAL_PARAM_DISABLE_ENT_SERVER_AUTH }
Ok, good.
Please let me know if you have specific questions about the required work.
Br,
Kobi
