Other Parts Discussed in Thread: CC3120BOOST, , CC31XXEMUBOOST, UNIFLASH, CC3235S, CC3200, CC3100, CC3XXXRADIOTEST
Hi all-
I've been trying to get the RadioTool application up and running, but I'm having some trouble and I don't know where the problem is.
I'm currently using the LAUNCHXL-CC3235S, CC31XXEMUBOOST, and CC3120BOOST boards as described by the User Guide for the RadioTool application.
I've downloaded Uniflash, and have been able to successfully flash the CC3235S (though I'm not certain it is correctly flashed). For the flash, I am using the sp_4.9.0.2_3.7.0.1_3.1.0.26.bin service pack update. I'm using the certcatalogPlayGround20160911.lst and certcatalogPlayGround20160911.lst.signed_3235.bin certificate catalogues, and the dummy security certificates (dummy-root-ca-cert, dummy-trusted-ca-cert, and dummy-trusted-cert). And again, when I try to flash the board, I don't get any error messages.
However, when I go to the RadioTool application, I cannot connect to the board. When I try to make the connection (CC3200 UART), I get the following error message:
I've tried flashing the CC3235S with different service packs and trying to change some of the other settings, but I haven't been able to figure out what's going wrong here. If anyone has any insight, I would much appreciate it.
