CC2538: Debug time warning by stop LCD functionalities in Z-Stack project
Part Number: CC2538
Other Parts Discussed in Thread: Z-STACK,
I am using Z-Stack 3.0,  "Sample light OTA Image A with Boot loader" Projects to make software CC25358.
Everything is fine, but I don't to access LCD more in project so, I trying to stop all the LCD stuff. But making
"#define HAL_LCD TRUE" in "hal_board_cfg" to FALSE or commenting this line itself  is giving warning at the debug time. The warning is as fallow:
Fri Dec 29, 2017 16:12:04: IAR Embedded Workbench 7.70.2 (armproc.dll)
Fri Dec 29, 2017 16:12:04: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\debugger\TexasInstruments\CC2538.dmac
Fri Dec 29, 2017 16:12:04: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\flashloader\TexasInstruments\FlashCC2538.mac
Fri Dec 29, 2017 16:12:05: Connecting to TI XDS100v3 ( Probe no: 12210908 ) COM[--/15]
Fri Dec 29, 2017 16:12:06: TI XDS ARM, device revision: 0x00000001, big endian: false, cache: false, board revision: 0x00000000, driver revision: 0x0B020200
Fri Dec 29, 2017 16:12:06: Initial reset was performed
Fri Dec 29, 2017 16:12:06: 416 bytes downloaded and verified (4.32 Kbytes/sec)
Fri Dec 29, 2017 16:12:06: Loaded debugee: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\flashloader\TexasInstruments\FlashCC2538RAM32K.out
Fri Dec 29, 2017 16:12:06: Target reset
Fri Dec 29, 2017 16:12:49: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\flashloader\TexasInstruments\FlashCC2538.mac
Fri Dec 29, 2017 16:12:49: Downloaded E:\raghu\KIKO_PROJECTS\KIKO_POINT\Project\zstack\HomeAutomation\KikoPoint\CC2538\EndDevice - OTAClient - ImageA - withBootloader\Exe\
EndDevice-OTAClient-ImageA-withBootloader.out to flash memory.
Fri Dec 29, 2017 16:13:07: 524256 bytes downloaded into FLASH and verified (8.42 Kbytes/sec)
Fri Dec 29, 2017 16:13:07: Warning:
Verify error at address 0x0027D000, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D001, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D008, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D009, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D00A, target byte: 0x08, byte in file: 0xFF
Verify error at address 0x0027D00B, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D00C, target byte: 0xF8, byte in file: 0xFF
Verify error at address 0x0027D00D, target byte: 0x07, byte in file: 0xFF
Verify error at address 0x0027D010, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D011, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D014, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D015, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D020, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D021, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D022, target byte: 0x08, byte in file: 0xFF
Verify error at address 0x0027D023, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D024, target byte: 0x75, byte in file: 0xFF
Verify error at address 0x0027D025, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D030, target byte: 0x8B, byte in file: 0xFF
Verify error at address 0x0027D031, target byte: 0x4D, byte in file: 0xFF
Verify error at address 0x0027D032, target byte: 0x3A, byte in file: 0xFF
Verify error at address 0x0027D033, target byte: 0x06, byte in file: 0xFF
Verify error at address 0x0027D034, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D035, target byte: 0x4B, byte in file: 0xFF
Verify error at address 0x0027D036, target byte: 0x12, byte in file: 0xFF
Verify error at address 0x0027D037, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D038, target byte: 0x03, byte in file: 0xFF
Verify error at address 0x0027D039, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D03A, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D03B, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D03C, target byte: 0xFD, byte in file: 0xFF
Verify error at address 0x0027D03D, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D048, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D04C, target byte: 0x55, byte in file: 0xFF
Verify error at address 0x0027D04D, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D04E, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D04F, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D050, target byte: 0xFD, byte in file: 0xFF
Verify error at address 0x0027D051, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D05C, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D060, target byte: 0x87, byte in file: 0xFF
Verify error at address 0x0027D061, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D062, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D063, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D065, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D070, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D074, target byte: 0x35, byte in file: 0xFF
Verify error at address 0x0027D075, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D076, target byte: 0x04, byte in file: 0xFF
Verify error at address 0x0027D077, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D078, target byte: 0xEB, byte in file: 0xFF
Verify error at address 0x0027D079, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D084, target byte: 0xE8, byte in file: 0xFF
Verify error at address 0x0027D085, target byte: 0x03, byte in file: 0xFF
Verify error at address 0x0027D086, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D087, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D088, target byte: 0x25, byte in file: 0xFF
Verify error at address 0x0027D089, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D08A, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D08B, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D08C, target byte: 0x62, byte in file: 0xFF
Verify error at address 0x0027D08D, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D098, target byte: 0x64, byte in file: 0xFF
Verify error at address 0x0027D099, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D09C, target byte: 0x26, byte in file: 0xFF
Verify error at address 0x0027D09D, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D09E, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D09F, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0A0, target byte: 0x62, byte in file: 0xFF
Verify error at address 0x0027D0A1, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D0AC, target byte: 0x64, byte in file: 0xFF
Verify error at address 0x0027D0AD, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0B0, target byte: 0x27, byte in file: 0xFF
Verify error at address 0x0027D0B1, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0B2, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D0B3, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0B4, target byte: 0xB7, byte in file: 0xFF
Verify error at address 0x0027D0B5, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D0C0, target byte: 0xB8, byte in file: 0xFF
Verify error at address 0x0027D0C1, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D0C4, target byte: 0x28, byte in file: 0xFF
Verify error at address 0x0027D0C5, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0C6, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D0C7, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0C9, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D0D4, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D0D8, target byte: 0x29, byte in file: 0xFF
Verify error at address 0x0027D0D9, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0DA, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D0DB, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0DD, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D0E8, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D0EC, target byte: 0x84, byte in file: 0xFF
Verify error at address 0x0027D0ED, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0EE, target byte: 0x04, byte in file: 0xFF
Verify error at address 0x0027D0EF, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0F0, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0F1, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0FC, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0FD, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0FE, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D0FF, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D100, target byte: 0x86, byte in file: 0xFF
Verify error at address 0x0027D101, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D102, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D103, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D104, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D105, target byte: 0x03, byte in file: 0xFF
Verify error at address 0x0027D110, target byte: 0x04, byte in file: 0xFF
Verify error at address 0x0027D114, target byte: 0x2A, byte in file: 0xFF
Verify error at address 0x0027D115, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D116, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D117, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D119, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D124, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D128, target byte: 0x2B, byte in file: 0xFF
Verify error at address 0x0027D129, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D12A, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D12B, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D12C, target byte: 0x04, byte in file: 0xFF
Verify error at address 0x0027D12D, target byte: 0x03, byte in file: 0xFF
Verify error at address 0x0027D138, target byte: 0x07, byte in file: 0xFF
Verify error at address 0x0027D13C, target byte: 0x2C, byte in file: 0xFF
Verify error at address 0x0027D13D, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D13E, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D13F, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D140, target byte: 0x1B, byte in file: 0xFF
Verify error at address 0x0027D141, target byte: 0x03, byte in file: 0xFF
Verify error at address 0x0027D14C, target byte: 0x1E, byte in file: 0xFF
Verify error at address 0x0027D150, target byte: 0x2D, byte in file: 0xFF
Verify error at address 0x0027D151, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D152, target byte: 0x08, byte in file: 0xFF
Verify error at address 0x0027D153, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D154, target byte: 0x75, byte in file: 0xFF
Verify error at address 0x0027D155, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D160, target byte: 0x8B, byte in file: 0xFF
Verify error at address 0x0027D161, target byte: 0x4D, byte in file: 0xFF
Verify error at address 0x0027D162, target byte: 0x3A, byte in file: 0xFF
Verify error at address 0x0027D163, target byte: 0x06, byte in file: 0xFF
Verify error at address 0x0027D164, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D165, target byte: 0x4B, byte in file: 0xFF
Verify error at address 0x0027D166, target byte: 0x12, byte in file: 0xFF
Verify error at address 0x0027D167, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D168, target byte: 0x2E, byte in file: 0xFF
Verify error at address 0x0027D169, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D16A, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D16B, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D16D, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D178, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D17C, target byte: 0x2F, byte in file: 0xFF
Verify error at address 0x0027D17D, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D17E, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D17F, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D180, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D181, target byte: 0x03, byte in file: 0xFF
Verify error at address 0x0027D18C, target byte: 0x05, byte in file: 0xFF
Verify error at address 0x0027D190, target byte: 0x30, byte in file: 0xFF
Verify error at address 0x0027D191, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D192, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D193, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D194, target byte: 0x1B, byte in file: 0xFF
Verify error at address 0x0027D195, target byte: 0x03, byte in file: 0xFF
Verify error at address 0x0027D1A0, target byte: 0x1E, byte in file: 0xFF
Verify error at address 0x0027D1A4, target byte: 0x31, byte in file: 0xFF
Verify error at address 0x0027D1A5, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1A6, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D1A7, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1A9, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D1B4, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D1B8, target byte: 0x32, byte in file: 0xFF
Verify error at address 0x0027D1B9, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1BA, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D1BB, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1BC, target byte: 0xFD, byte in file: 0xFF
Verify error at address 0x0027D1BD, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D1C8, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1CC, target byte: 0x33, byte in file: 0xFF
Verify error at address 0x0027D1CD, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1CE, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D1CF, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1D0, target byte: 0xFD, byte in file: 0xFF
Verify error at address 0x0027D1D1, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D1DC, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1E0, target byte: 0x34, byte in file: 0xFF
Verify error at address 0x0027D1E1, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1E2, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D1E3, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1E4, target byte: 0x07, byte in file: 0xFF
Verify error at address 0x0027D1E5, target byte: 0x03, byte in file: 0xFF
Verify error at address 0x0027D1F0, target byte: 0x0A, byte in file: 0xFF
Verify error at address 0x0027D1F4, target byte: 0x36, byte in file: 0xFF
Verify error at address 0x0027D1F5, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1F6, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D1F7, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D1F8, target byte: 0xFD, byte in file: 0xFF
Verify error at address 0x0027D1F9, target byte: 0x02, byte in file: 0xFF
Verify error at address 0x0027D204, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D208, target byte: 0x38, byte in file: 0xFF
Verify error at address 0x0027D209, target byte: 0x00, byte in file: 0xFF
Verify error at address 0x0027D20A, target byte: 0x01, byte in file: 0xFF
Verify error at address 0x0027D20B, target byte: 0x00, byte in file: 0xFF
Fri Dec 29, 2017 16:13:07: Warning: Too many verify errors, only the first 200 are displayed
Fri Dec 29, 2017 16:13:14: Warning: There were warnings during download, see Log Window
Fri Dec 29, 2017 16:13:14: Loaded debugee: E:\raghu\KIKO_PROJECTS\KIKO_POINT\Project\zstack\HomeAutomation\KikoPoint\CC2538\EndDevice - OTAClient - ImageA - withBootloader\Exe\
Fri Dec 29, 2017 16:13:14: Target reset
Fri Dec 29, 2017 16:13:14: Set SYS_CTRL:EMUOVR Register
Fri Dec 29, 2017 16:13:14: There was 1 warning during the initialization of the debugging session.
Fri Dec 29, 2017 16:13:18: IAR Embedded Workbench 7.70.2 (armproc.dll)
I am also getting this error many times when I made any changes in the original project.
Please any one let me know how to resolve this or how can i remove LED stuff in my project.
    Please try referring to the "Removing the example User Interface" section of this wiki page, it describes how to remove UI and LCD-related code for Z-Stack 3.0.x
    processors.wiki.ti.com/.../Optimizing_Flash_and_RAM_Usage_of_Z-Stack_for_CC2530
    Also, if you have not already upgraded to Z-Stack 3.0.1, I would recommend doing so, you should be able to easily migrate your custom project since there are not many changes other than bug fixes. You will, however, need to upgrade your IAR version to IAR EWARM 8.11.1 for Z-Stack 3.0.1.
  • Hi Jason,
    Its good it hear your suggestion, I will go through link.
    Regarding upgrade of IAR, currently I am using "V7.70.2" because I was getting an compile time error for all the Z-stack 3.0 projects in IAR "V8.11", but you are telling upgrade to higher version.
    To upgrade my IAR version I want Z-stack projects should work without any error in respective version is it possible?
    Thank you.
  • Hi Jason,
    I make the changes in Z-stack 3.0 as per the link but again I was getting the same warning.
    How to update from Z-stack 3.0 to 3.1 with out affect or rework my code.
    Thank you.
  • You have to use IAR EWARM 8.11 to build examples in Z-Stack 3.0.1.
  • Hi Chen,
    Ok I will update to 8.11, to update my project is need to make all my code set up in Z-stack 3.0.1 example project or is there any way to update my whole project as Z-stack 3.0.1 project.
    Thank you
  • Is your previous application based on Z-Stack 3.0?
  • Yes I made my application by extending "Z-stack3.0" example 'Sample Switch"
  • Then, you only need to merge your modifications into application code.
  • Hi Chen,
    Thank you. So, I have to download and install Z-Stack3.0.1 then I have to merge what all modifications I made in the Z-Stack3.0 application to Z-Stack3.0.1 application again. Then my application will be Z-Stack3.0.1 there is no other way of of Stack update is it write.
  • Yes, it's correct.
    I got Z-Stack3.0.1 and updated IAR to 8.20.2, here I was getting an similar warning for the project "Sample_Switch_OTAClient_ImageA-with BootLoader" while debugging  in verification I was getting this warning
    Tue Jan 02, 2018 13:04:06: IAR Embedded Workbench 8.20.2 (C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\bin\armproc.dll)
    Tue Jan 02, 2018 13:04:06: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\config\debugger\TexasInstruments\CC2538.dmac
    Tue Jan 02, 2018 13:04:06: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\config\flashloader\TexasInstruments\FlashCC2538.mac
    Tue Jan 02, 2018 13:04:06: Connecting to TI XDS100v3 ( Probe no: 122108EB ) COM[--/16]
    Tue Jan 02, 2018 13:04:08: TI XDS ARM, device revision: 0x00000001, big endian: false, cache: false, board revision: 0x00000000, driver revision: 0x0B020200
    Tue Jan 02, 2018 13:04:08: Initial reset was performed
    Tue Jan 02, 2018 13:04:08: 416 bytes downloaded and verified (5.21 Kbytes/sec)
    Tue Jan 02, 2018 13:04:08: Loaded debugee: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\config\flashloader\TexasInstruments\FlashCC2538RAM32K.out
    Tue Jan 02, 2018 13:04:08: Target reset
    Tue Jan 02, 2018 13:05:02: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.0\arm\config\flashloader\TexasInstruments\FlashCC2538.mac
    Tue Jan 02, 2018 13:05:02: Downloaded F:\Z-Stack 3.0.1\Projects\zstack\HomeAutomation\SampleSwitch\CC2538\EndDevice - OTAClient - ImageA - withBootloader\Exe\
    Tue Jan 02, 2018 13:05:27: 524256 bytes downloaded into FLASH and verified (6.54 Kbytes/sec)
    Tue Jan 02, 2018 13:05:27: Warning:
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C010, target byte: 0x00, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C011, target byte: 0x00, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C012, target byte: 0x00, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C013, target byte: 0x00, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C020, target byte: 0x21, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C021, target byte: 0x05, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C022, target byte: 0x13, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C023, target byte: 0x20, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C024, target byte: 0x21, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C025, target byte: 0x05, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C026, target byte: 0x13, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C027, target byte: 0x20, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C028, target byte: 0x90, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C029, target byte: 0x74, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C02A, target byte: 0x00, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C02B, target byte: 0x20, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C02C, target byte: 0xF9, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C02D, target byte: 0x7E, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C02E, target byte: 0x21, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:27: Verify error at address 0x0027C02F, target byte: 0x00, byte in file: 0xFF
    Tue Jan 02, 2018 13:05:31: Warning: There were warnings during download, see Log Window
    Tue Jan 02, 2018 13:05:31: Loaded debugee: F:\Z-Stack 3.0.1\Projects\zstack\HomeAutomation\SampleSwitch\CC2538\EndDevice - OTAClient - ImageA - withBootloader\Exe\
    Tue Jan 02, 2018 13:05:31: Target reset
    Tue Jan 02, 2018 13:05:33: Set SYS_CTRL:EMUOVR Register
    Tue Jan 02, 2018 13:05:33: There was 1 warning during the initialization of the debugging session.
    Earlier I made my project by extending the same Sample-Switch-OTA-Client-ImageA-withBootLoader project of Z-Stack3.0. Anyway I need the this project to work without issue.
    I tried for IAR 8.11.1 to use but not this version of IAR anywhere
    Thank you
  • You can download IAR EWARM 8.11 from www.iar.com/.../
  • Hi Chen,
    Thanks for the link, it seems works fine.
    Our technical team requesting to use Z-Stack3.0 with no update in Stack just stop all the LCD functionality as we are not using LCD in our custom PCB and as well to reduce code.
    I made it stop as per JasonB suggestion but again I am getting the same warning at the time of Debug and exactly during verification.
  • If you only do the following items, do you still see the same issue?
    If present, remove these flags:
    LCD_SUPPORTED=DEBUG
    LEGACY_LCD_DEBUG
    Add these flags:
    HAL_LCD=FALSE
  • Yes I seeing same warning.
    Hi Chen, can I know what all reasons for this warning to occur?
    Thank you
  • I test the same the same thing on my Sample light OTA Image A with Boot loader in Z-Stack 3.0.1 and it works fine. Can you reinstall Z-Stack 3.0.1 to build again?
  • Sorry Chen,
    I am not made change in Z-Stack3.0.1, yet tried with Z-Stack3.0. My manager is forcing to do in Z-Stack3.0 and not allowing to use Z-Stack3.0.1
    Please help me in Z-Stack3.0.
    Thank you
  • I test the same thing on Z-Stack3.0 and it also works. I suggest you to reinstall a clean Z-Stack 3.0 to test again.
  • Hi Chen,
    I installed Z-Stack3.0 newly and tried getting same warning.
    "LEGACY_LCD_DEBUG" is not defined any where in project (Not in defined symbols and not in project)
    I am using "IAR 7.70.2"
    Thank you
  • I test this with IAR 8.11 and maybe you can try it.
  • Ok, the link you have shared for IAR has no 8.11 it has 8.11.1 and other can you please share other having 8.11. So I can try that also.
    Thank you
  • I use IAR EWARM 8.11.1 when I test it so you can use it.
  • I already tried with 8.11.1 for both Z-Stack3.0 and Z-Stack3.0.1 its no use getting same warning.
  • If you build original example without modification, do you still the the same warning?
  • Z-Stack 3.0 has no issue in Z-Stack3.0.1 "Sample-Switch-OTA-Client-ImageA-with BootLoader" is giving the same warning
  • I don't see any issue when I build Sample-Switch-OTA-Client-ImageA-with BootLoader example on both 3.0 and 3.0.1. Anyway, your manager asks you to use 3.0 and I think you can just use it since you don't see problem on it.
  • Hi Chen,
    That's ok I continued with Z-Stack3.0, as I stopped LCD functionality I am always getting the same warning on every debug verification.
    Thank you
  • I think I misunderstand your question. After I try to download the binary with IAR, I see the issue you mention. This is caused by 0x0027C000 to 0x0027C7FF is the region for Image Boot Manager (IBM) Ledger Page so it would verified fail using IAR with Sample-Switch-OTA-Client-ImageA-with BootLoader since the project file doesn't contain boot loader information. You can skip this warning without problem.
  • Oh is it, then how about I was getting the warning on Stopping LCD functionality by making
    remove of "LCD_SUPPORTED=DEBUG" and add of "HAL_LCD=FALSE"
  • What warning do you mean here?
  • The below warning:
    Thu Jan 04, 2018 19:14:57: IAR Embedded Workbench 7.70.2 (armproc.dll)
    Thu Jan 04, 2018 19:14:57: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\debugger\TexasInstruments\CC2538.dmac
    Thu Jan 04, 2018 19:14:57: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\flashloader\TexasInstruments\FlashCC2538.mac
    Thu Jan 04, 2018 19:15:06: Connecting to TI XDS100v3 ( Probe no: 12210908 ) COM[--/15]
    Thu Jan 04, 2018 19:15:08: TI XDS ARM, device revision: 0x00000001, big endian: false, cache: false, board revision: 0x00000000, driver revision: 0x0B020200
    Thu Jan 04, 2018 19:15:08: Initial reset was performed
    Thu Jan 04, 2018 19:15:08: 416 bytes downloaded and verified (5.21 Kbytes/sec)
    Thu Jan 04, 2018 19:15:08: Loaded debugee: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\flashloader\TexasInstruments\FlashCC2538RAM32K.out
    Thu Jan 04, 2018 19:15:08: Target reset
    Thu Jan 04, 2018 19:15:51: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.5\arm\config\flashloader\TexasInstruments\FlashCC2538.mac
    Thu Jan 04, 2018 19:15:51: Downloaded E:\raghu\KIKO_PROJECTS\KIKO_POINT\Project\zstack\HomeAutomation\KikoPoint\CC2538\EndDevice - OTAClient - ImageA - withBootloader\Exe\
    Thu Jan 04, 2018 19:16:11: 524256 bytes downloaded into FLASH and verified (8.11 Kbytes/sec)
    Thu Jan 04, 2018 19:16:11: Warning:
    Thu Jan 04, 2018 19:16:11: Warning: Too many verify errors, only the first 200 are displayed
    Thu Jan 04, 2018 19:17:38: Warning: There were warnings during download, see Log Window
    Thu Jan 04, 2018 19:17:38: Loaded debugee: E:\raghu\KIKO_PROJECTS\KIKO_POINT\Project\zstack\HomeAutomation\KikoPoint\CC2538\EndDevice - OTAClient - ImageA - withBootloader\Exe\
    Thu Jan 04, 2018 19:17:38: Target reset
    Thu Jan 04, 2018 19:17:39: Set SYS_CTRL:EMUOVR Register
    Thu Jan 04, 2018 19:17:39: There was 1 warning during the initialization of the debugging session.
    Thu Jan 04, 2018 19:29:06: IAR Embedded Workbench 7.70.2 (armproc.dll)
  • I have told you it shouldn’t matter.
  • If it not make any problem to my application then no issue, thanks for your support.
