Does Zigbee 3.0 Linux Gateway Sensor to Cloud Solution suppoert OTA to joined device?
Other Parts Discussed in Thread: Z-STACK
Does Zigbee 3.0 Linux Gateway Sensor to Cloud Solution suppoert OTA to joined device? If yes, how to do it from user interface?
  • The Node.js Web Application/Sensor-to-Cloud interface does not have support for OTA, however, the Zigbee 3.0 Linux Gateway local sample application does support OTA Upgrade for joined devices. You can refer to the document 'Z-Stack Linux Gateway User Guide.pdf' in Section 6.3.3.7 for how to get OTA working properly on the Gateway.
    Sean
  • I thought you only support web UI for new Z-Stack Linux GW and not aware of console UI still works. I will test it. THanks.
