Other Parts Discussed in Thread: CC2538
The CC2592 datasheet says that only pins 9, 11, and 12 should be shorted to the die attach pad on the top layer. However, in the reference design, all the grounds are shorted to the pad on the top layer. Should the datasheet recommendation be completely ignored or is there some other consideration I should be taking to treat each ground pins differently?
Arthur
