Part Number: CC2538
Other Parts Discussed in Thread: Z-STACK
Tool/software: TI-RTOS
@Ryan Brown1
@JasonB
We are in urgent need of help.
All CC2538 device use the newest Z-Stack 3.0.2(include coordinator and router,end-device),capture all OTA packet with newest Ubiqua.
1. When there are more than 20 routers around the coordinator, there is no signal saturation at the right distance. End-device has been tried many times. It has been beacon request, Association Request, Association Response: Success, but there is nothing behind the key transports. It has been repeated all the time. It is impossible to joined the network successful, cut off all router power supply and test again, except the coordinator. and end-device, access to joined the network immediately succeeded, in other words, can not joined the network in the "key-tunnel" way,I don't know why coordinator not issue key transport whenever it send Association Response Success?
2.The above steps will lead to internal abnormalities in the coordinator protocol stack (as the coordinator no longer issue control instructions at all, test the coordinator issue permit join, also can not come out, but each time the coordinator receives data from other routers, it has the Acknowledgement response, indicating that it did receive truely, but the routing is not feasible, all router issue Route Failure occurs, and eventually the upper gateway of the coordinator has to be restarted (the coordinator's issue MT command to ZNP executes the reset command) ,the network of coordinator will resume.
I can confirm that this is the bug. It has been repeated at least a dozen times.
