Tool/software: TI-RTOS
I've been trying to get the sample code for collector/sensor to work consistently but it seems it's not
consistent with connecting. I've been reading the documentation that comes with the sources listed below. It doesn't seem
any of documentation go into details on how the connection sequence is supposed to work. It gives a general overview but
the actual code is fairly complex because looking at jdllc.*, ssf.*,sensor.*, cllc.*, collector.* , csf.* there are a fair number of states both for
device and application, but I don't know what the actual sequence is supposed to be for a valid connection. Most of the time the
collector sits and rejects the connection and the sensor keeps retrying but nothing ever happens. BTW, that's after pushing the right
buttons for the connections to happen.
Is there a document that describes the connection process as in sensor has to send these sequences and the collector has to send
these corresponding sequences for the connection to occur. Also is there a document that documents the correct state transitions
for both the collector and the sensor?
technical-reference-manual.htm
ti-15.4-stack-migration-guide.html
manifest_ti154stack_2_09_01_00.html
ti-15.4-stack-quick-start-guide.html
ti-15.4-stack-users-guide.html
