Other Parts Discussed in Thread: Z-STACK
Hello
I am using the SampleSwitch application and I have encountered a problem with the connectivity of the devices. When a device is close to the limit of its range (indoors) and there are often connection and re-connection (meaning trying to find a parent, finds him, looses him and repeat) a case exist where it will disconnect from the network and wont connect again even if the link quality improves. My main culprit is that in the zstack core in ZDApp.c when waiting for authentication from trust center due to bad connectivity the device stays in DEV_END_DEVICE_UNAUTH and when it performs a ZDO_DEVICE_RESET it forces a new join. Is this theory correct or is it something else.
Thank you for your time.
Nomikos Panagiotis
