LAUNCHXL-CC1352P: Adding OAD Feature to zr_light
Part Number: LAUNCHXL-CC1352P
Other Parts Discussed in Thread: UNIFLASH, SIMPLELINK-CC13X2-26X2-SDK
Hi All,
I have added the OAD feature to the zr_light (simplelink_cc13x2_26x2_sdk_3_30_00_03) SDK example following the below link
 file:///C:/ti/simplelink_cc13x2_26x2_sdk_3_30_00_03/docs/zigbee/html/zigbee/ota_upgrade.html#adding-client-functionality-to-an-application.
I am able to port and generate the oad.bin file. When flashing from Uniflash tool along with BIM_OFF_CHIP first I am able to see the UART print (OTA Info : [Current File Version] 0x00000001).
But when I provision with the Co ordinator I am not able to see the OTA Cluster in the Simple Descriptor response on the Endpoint 8, but other clusters are able to see.
Thanks & Regards,
Yasar Arafath
  • Do you add the following two defines in your OTA project?
    OTA_CLIENT_CC26XX
    OTA_CLIENT=TRUE
  • Yes, I have already added the same in Properties->Build->ARM Complier->Predefined Symbols
    Thanks & Regards,
    Yasar Arafath
  • Can you attach your zcl_xxx_data.c?
  • Changes in the zcl_xxx_data.c is not mentioned in the porting guide.
    Updating the changes comparing with the zr_sw_ota_client project and  revert back to you with the results.
    Attached the file. Kindly verify and feedback.
      Filename:       zcl_samplelight_data.c
      Revised:        $Date: 2014-05-12 13:14:02 -0700 (Mon, 12 May 2014) $
      Revision:       $Revision: 38502 $
      Description:    Zigbee Cluster Library - sample device application.
      Copyright 2006-2014 Texas Instruments Incorporated. All rights reserved.
      IMPORTANT: Your use of this Software is limited to those specific rights
      granted under the terms of a software license agreement between the user
      who downloaded the software, his/her employer (which must be your employer)
      and Texas Instruments Incorporated (the "License").  You may not use this
      Software unless you agree to abide by the terms of the License. The License
      limits your use, and you acknowledge, that the Software may not be modified,
      copied or distributed unless embedded on a Texas Instruments microcontroller
      or used solely and exclusively in conjunction with a Texas Instruments radio
      frequency transceiver, which is integrated into your product.  Other than for
      the foregoing purpose, you may not use, reproduce, copy, prepare derivative
      works of, modify, distribute, perform, display or sell this Software and/or
      its documentation for any purpose.
      YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
      PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
      INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
      NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
      TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
      NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
      LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
      INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
      OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
      OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
      (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
      Should you have any questions regarding your right to use this Software,
      contact Texas Instruments Incorporated at www.TI.com.
     * INCLUDES
    #include "zcomdef.h"
    #include "zcl.h"
    #include "zcl_general.h"
    #include "zcl_ha.h"
    #include "zcl_poll_control.h"
    #include "zcl_electrical_measurement.h"
    #include "zcl_meter_identification.h"
    #include "zcl_appliance_identification.h"
    #include "zcl_appliance_events_alerts.h"
    #include "zcl_power_profile.h"
    #include "zcl_appliance_control.h"
    #include "zcl_appliance_statistics.h"
    #include "zcl_hvac.h"
    #include "zcl_samplelight.h"
    #ifdef BDB_REPORTING
    #include "zstackapi.h"
    #endif
    #ifdef OTA_CLIENT_CC26XX
    #include "ota_client_app.h"
    #endif
     * CONSTANTS
    #define SAMPLELIGHT_DEVICE_VERSION     1
    #define SAMPLELIGHT_FLAGS              0
    #define SAMPLELIGHT_HWVERSION          1
    #define SAMPLELIGHT_ZCLVERSION         BASIC_ZCL_VERSION
    #define DEFAULT_IDENTIFY_TIME 0
    #define DEFAULT_ON_OFF_TRANSITION_TIME 20
    #define DEFAULT_ON_LEVEL ATTR_LEVEL_ON_LEVEL_NO_EFFECT
    #define DEFAULT_ON_TRANSITION_TIME 20
    #define DEFAULT_OFF_TRANSITION_TIME 20
    #define DEFAULT_MOVE_RATE 0 // as fast as possible
    #define DEFAULT_ON_OFF_STATE LIGHT_OFF
    #define DEFAULT_LEVEL ATTR_LEVEL_MAX_LEVEL
     * TYPEDEFS
     * MACROS
     * EXTERNAL VARIABLES
    extern uint8_t  appServiceTaskId;
     * GLOBAL VARIABLES
    //global attributes
    const uint16_t zclSampleLight_basic_clusterRevision = 0x0002;
    const uint16_t zclSampleLight_identify_clusterRevision = 0x0001;
    const uint16_t zclSampleLight_groups_clusterRevision = 0x0001;
    const uint16_t zclSampleLight_scenes_clusterRevision = 0x0001;
    const uint16_t zclSampleLight_onoff_clusterRevision = 0x0001;
    const uint16_t zclSampleLight_level_clusterRevision = 0x0001;
    // Basic Cluster
    const uint8_t zclSampleLight_HWRevision = SAMPLELIGHT_HWVERSION;
    const uint8_t zclSampleLight_ZCLVersion = SAMPLELIGHT_ZCLVERSION;
    const uint8_t zclSampleLight_ManufacturerName[] = { 16, 'T','e','x','a','s','I','n','s','t','r','u','m','e','n','t','s' };
    const uint8_t zclSampleLight_PowerSource = POWER_SOURCE_MAINS_1_PHASE;
    uint8_t zclSampleLight_PhysicalEnvironment = PHY_UNSPECIFIED_ENV;
    // Identify Cluster
    uint16_t zclSampleLight_IdentifyTime;
    // Groups Cluster
    uint8_t zclSampleLight_GroupsNameSupport = 0;
    // On/Off Cluster
    static uint8_t  zclSampleLight_OnOff;
    // Level Control Cluster
    #ifdef ZCL_LEVEL_CTRL
    static uint8_t  zclSampleLight_LevelCurrentLevel;
    uint16_t zclSampleLight_LevelRemainingTime;
    uint16_t zclSampleLight_LevelOnOffTransitionTime;
    uint8_t  zclSampleLight_LevelOnLevel;
    uint16_t zclSampleLight_LevelOnTransitionTime;
    uint16_t zclSampleLight_LevelOffTransitionTime;
    uint8_t  zclSampleLight_LevelDefaultMoveRate;
    #endif
    uint8_t  zclSampleLight_ScenesCurrentScene = 0;
    uint16_t zclSampleLight_ScenesCurrentGroup = 0;
    uint8_t  zclSampleLight_ScenesValid = 0;
    uint8_t  zclSampleLight_ScenesNameSupport = 0;
    #if ZCL_DISCOVER
    CONST zclCommandRec_t zclSampleLight_Cmds[] =
        ZCL_CLUSTER_ID_GEN_BASIC,
        COMMAND_BASIC_RESET_FACT_DEFAULT,
        CMD_DIR_SERVER_RECEIVED
        ZCL_CLUSTER_ID_GEN_ON_OFF,
        COMMAND_OFF,
        COMMAND_ON,
        COMMAND_TOGGLE,
    #ifdef ZCL_LEVEL_CONTROL
        ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL,
        COMMAND_LEVEL_MOVE_TO_LEVEL,
        COMMAND_LEVEL_MOVE,
        COMMAND_LEVEL_STEP,
        COMMAND_LEVEL_STOP,
        COMMAND_LEVEL_MOVE_TO_LEVEL_WITH_ON_OFF,
        COMMAND_LEVEL_MOVE_WITH_ON_OFF,
        COMMAND_LEVEL_STEP_WITH_ON_OFF,
        COMMAND_LEVEL_STOP_WITH_ON_OFF,
    #endif // ZCL_LEVEL_CONTROL
    CONST uint8_t zclCmdsArraySize = ( sizeof(zclSampleLight_Cmds) / sizeof(zclSampleLight_Cmds[0]) );
    #endif // ZCL_DISCOVER
     * ATTRIBUTE DEFINITIONS - Uses REAL cluster IDs
    // NOTE: The attributes listed in the AttrRec must be in ascending order
    // per cluster to allow right function of the Foundation discovery commands
    CONST zclAttrRec_t zclSampleLight_Attrs[] =
      // *** General Basic Cluster Attributes ***
        { // Attribute record
          ATTRID_BASIC_ZCL_VERSION,
          ZCL_DATATYPE_UINT8,
          ACCESS_CONTROL_READ,
          (void *)&zclSampleLight_ZCLVersion
        ZCL_CLUSTER_ID_GEN_BASIC,             // Cluster IDs - defined in the foundation (ie. zcl.h)
          ATTRID_BASIC_HW_VERSION,            // Attribute ID - Found in Cluster Library header (ie. zcl_general.h)
          ZCL_DATATYPE_UINT8,                 // Data Type - found in zcl.h
          ACCESS_CONTROL_READ,                // Variable access control - found in zcl.h
          (void *)&zclSampleLight_HWRevision  // Pointer to attribute variable
          ATTRID_BASIC_MANUFACTURER_NAME,
          ZCL_DATATYPE_CHAR_STR,
          (void *)zclSampleLight_ManufacturerName
          ATTRID_BASIC_POWER_SOURCE,
          ZCL_DATATYPE_ENUM8,
          (void *)&zclSampleLight_PowerSource
          ATTRID_BASIC_PHYSICAL_ENV,
          ZCL_DATATYPE_ENUM8,
          (ACCESS_CONTROL_READ | ACCESS_CONTROL_WRITE),
          (void *)&zclSampleLight_PhysicalEnvironment
          ATTRID_CLUSTER_REVISION,
          ZCL_DATATYPE_UINT16,
          (void *)&zclSampleLight_basic_clusterRevision
    #ifdef ZCL_IDENTIFY
      // *** Identify Cluster Attribute ***
        ZCL_CLUSTER_ID_GEN_IDENTIFY,
          ATTRID_IDENTIFY_TIME,
          (void *)&zclSampleLight_IdentifyTime
          (void *)&zclSampleLight_identify_clusterRevision
    #endif
      // *** On/Off Cluster Attributes ***
          ATTRID_ON_OFF,
          ZCL_DATATYPE_BOOLEAN,
          ACCESS_CONTROL_READ | ACCESS_REPORTABLE,
          (void*)&zclSampleLight_OnOff
          (void *)&zclSampleLight_onoff_clusterRevision
          ATTRID_LEVEL_CURRENT_LEVEL,
          ZCL_DATATYPE_UINT8,
          (void*)&zclSampleLight_LevelCurrentLevel
          ATTRID_LEVEL_REMAINING_TIME,
          (void *)&zclSampleLight_LevelRemainingTime
          ATTRID_LEVEL_ON_OFF_TRANSITION_TIME,
          ACCESS_CONTROL_READ | ACCESS_CONTROL_WRITE,
          (void *)&zclSampleLight_LevelOnOffTransitionTime
          ATTRID_LEVEL_ON_LEVEL,
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight_LevelOnLevel
          ATTRID_LEVEL_ON_TRANSITION_TIME,
          (void *)&zclSampleLight_LevelOnTransitionTime
          ATTRID_LEVEL_OFF_TRANSITION_TIME,
          (void *)&zclSampleLight_LevelOffTransitionTime
          ATTRID_LEVEL_DEFAULT_MOVE_RATE,
          (void *)&zclSampleLight_LevelDefaultMoveRate
          (void *)&zclSampleLight_level_clusterRevision
    #endif
    #ifdef ZCL_GROUPS
        ZCL_CLUSTER_ID_GEN_GROUPS,
          ATTRID_GROUP_NAME_SUPPORT,
          ZCL_DATATYPE_BITMAP8,
          (void*)&zclSampleLight_GroupsNameSupport
          (void *)&zclSampleLight_groups_clusterRevision
    #endif
      // *** Scene Cluster Attributes ***
        ZCL_CLUSTER_ID_GEN_SCENES,
          ATTRID_SCENES_COUNT,
          ZCL_DATATYPE_UINT8,
          NULL // Use application's callback to Read this attribute
          ATTRID_SCENES_CURRENT_SCENE,
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight_ScenesCurrentScene
          ATTRID_SCENES_CURRENT_GROUP,
          (void *)&zclSampleLight_ScenesCurrentGroup
          ATTRID_SCENES_SCENE_VALID,
          (void *)&zclSampleLight_ScenesValid
          ATTRID_SCENES_NAME_SUPPORT,
          (void *)&zclSampleLight_ScenesNameSupport
          (void *)&zclSampleLight_scenes_clusterRevision
      // *** OTA Cluster ***
      OTA_ATTR_LIST
    #endif
    uint8_t CONST zclSampleLight_NumAttributes = ( sizeof(zclSampleLight_Attrs) / sizeof(zclSampleLight_Attrs[0]) );
     * SIMPLE DESCRIPTOR
    // This is the Cluster ID List and should be filled with Application
    // specific cluster IDs.
    const cId_t zclSampleLight_InClusterList[] =
      , ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL
    #endif
    #define ZCLSAMPLELIGHT_MAX_INCLUSTERS   (sizeof(zclSampleLight_InClusterList) / sizeof(zclSampleLight_InClusterList[0]))
    const cId_t zclSampleLight_OutClusterList[] =
    #if defined (OTA_CLIENT_CC26XX)
      ZCL_CLUSTER_ID_OTA
    #endif
    #define ZCLSAMPLELIGHT_MAX_OUTCLUSTERS   ( sizeof( zclSampleLight_OutClusterList ) / sizeof( zclSampleLight_OutClusterList[0] ))
    SimpleDescriptionFormat_t zclSampleLight_SimpleDesc =
      SAMPLELIGHT_ENDPOINT,                  //  int Endpoint;
      ZCL_HA_PROFILE_ID,                     //  uint16_t AppProfId;
      ZCL_HA_DEVICEID_DIMMABLE_LIGHT,        //  uint16_t AppDeviceId;
    #else
      ZCL_HA_DEVICEID_ON_OFF_LIGHT,          //  uint16_t AppDeviceId;
    #endif
      SAMPLELIGHT_DEVICE_VERSION,            //  int   AppDevVer:4;
      SAMPLELIGHT_FLAGS,                     //  int   AppFlags:4;
      ZCLSAMPLELIGHT_MAX_INCLUSTERS,         //  byte  AppNumInClusters;
      (cId_t *)zclSampleLight_InClusterList, //  byte *pAppInClusterList;
    //  0,        //  byte  AppNumInClusters;
    //  NULL, //  byte *pAppInClusterList;
      ZCLSAMPLELIGHT_MAX_OUTCLUSTERS,        //  byte  AppNumInClusters;
      (cId_t *)zclSampleLight_OutClusterList //  byte *pAppInClusterList;
    // Added to include Touchlink Target functionality
    #if defined ( BDB_TL_INITIATOR ) || defined ( BDB_TL_TARGET )
    bdbTLDeviceInfo_t tlSampleLight_DeviceInfo =
      SAMPLELIGHT_ENDPOINT,                  //uint8_t endpoint;
      ZCL_HA_PROFILE_ID,                        //uint16_t profileID;
    #else
    #endif
      SAMPLELIGHT_DEVICE_VERSION,                    //uint8_t version;
      SAMPLELIGHT_NUM_GRPS                   //uint8_t grpIdCnt;
    #endif
     * GLOBAL FUNCTIONS
     * @fn      zclSampleLight_updateOnOffAttribute
     * @brief   Function that updates the OnOff attribute, this will also update scene attribute.
     * @param   OnOff state
     * @return  none
    void zclSampleLight_updateOnOffAttribute(uint8_t OnOff)
        if(zclSampleLight_OnOff != OnOff)
            zclSampleLight_OnOff = OnOff;
            zclSampleLight_ScenesValid = FALSE;
            zstack_bdbRepChangedAttrValueReq_t Req;
            Req.attrID = ATTRID_ON_OFF;
            Req.cluster = ZCL_CLUSTER_ID_GEN_ON_OFF;
            Req.endpoint = SAMPLELIGHT_ENDPOINT;
          Zstackapi_bdbRepChangedAttrValueReq(appServiceTaskId,&Req);
    #endif
     * @fn      zclSampleLight_getOnOffAttribute
     * @brief   Function to get the state of the OnOff attribute.
     * @param   none
     * @return  OnOff attribute state (True if on, False if Off)
    uint8_t zclSampleLight_getOnOffAttribute(void)
        return zclSampleLight_OnOff;
     * @fn      zclSampleLight_updateCurrentLevelAttribute
     * @param   Current Level state
     * @return  none
    void zclSampleLight_updateCurrentLevelAttribute(uint8_t CurrentLevel)
        if(zclSampleLight_LevelCurrentLevel != CurrentLevel)
            zclSampleLight_LevelCurrentLevel = CurrentLevel;
            Req.attrID = ATTRID_LEVEL_CURRENT_LEVEL;
            Req.cluster = ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL;
    #endif
     * @fn      zclSampleLight_getCurrentLevelAttribute
     * @param   none
     * @return  Current Level attribute state
    uint8_t zclSampleLight_getCurrentLevelAttribute(void)
        return zclSampleLight_LevelCurrentLevel;
    #endif
     * LOCAL FUNCTIONS
     * @fn      zclSampleLight_ResetAttributesToDefaultValues
     * @brief   Reset all writable attributes to their default values.
     * @param   none
     * @return  none
    void zclSampleLight_ResetAttributesToDefaultValues(void)
    #ifdef ZCL_IDENTIFY
      zclSampleLight_IdentifyTime = DEFAULT_IDENTIFY_TIME;
    #endif
      zclSampleLight_LevelRemainingTime = 0;
      zclSampleLight_LevelOnOffTransitionTime = DEFAULT_ON_OFF_TRANSITION_TIME;
      zclSampleLight_LevelOnLevel = DEFAULT_ON_LEVEL;
      zclSampleLight_LevelOnTransitionTime = DEFAULT_ON_TRANSITION_TIME;
      zclSampleLight_LevelOffTransitionTime = DEFAULT_OFF_TRANSITION_TIME;
      zclSampleLight_LevelDefaultMoveRate = DEFAULT_MOVE_RATE;
      zclSampleLight_updateCurrentLevelAttribute(DEFAULT_LEVEL);
    #endif
      zclSampleLight_updateOnOffAttribute(DEFAULT_ON_OFF_STATE);
      zclSampleLight_IdentifyTime = 0;
    Thanks & Regards,
    Yasar Arafath
  • You have to add OTA cluster into your zclSampleLight_OutClusterList[].
  • But in the zr_sw_ota_client project it is added in zclSampleSw_OutClusterList.
    Thanks & Regards,
    Yasar Arafath
  • Sorry, it’s my mistake. It’s correct to put OTA cluster in zclSampleLight_OutClusterList. So, do you mean you don’t see OTA cluster in your OutCluster of simple descriptor when you request it?
  • Made the zcl_samplelight_data.c file changes recently after this post. Need to be tested.
    I will update you ASAP.
    Also I want to know the below MACRO can be changed and what will be the maximum when configuring as a router?
    #define OTA_MAX_MTU                                   32
    This is defined in Common/zcl/zcl_ota.h
    Thanks & Regards,
    Yasar Arafath
  • Hi Yasar,
    A diff compare between the project sources of zr_sw and zr_sw_ota_client is definitely a good approach.  I've responded to your OTA_MAX_MTU inquiry in the related E2E thread.
    Ryan
  • Hi YKChen & Ryan,
    Changes in the zcl_xxx_data.c file fixed the issue which is not part of
    file:///C:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/docs/zigbee/html/zigbee/ota_upgrade.html#adding-client-functionality-to-an-application
    Thanks for your references.
    Yasar Arafath
  • Hi Yasar,
    Thank you for the feedback, I have submitted a documentation ticket and will make sure this is addressed by the next SIMPLELINK-CC13X2-26X2-SDK version.
    Ryan
