Part Number: CC2652P
fix the access of "zclport_registerZclHandleExternal" in zcl_port.h like this
extern bool zclport_registerZclHandleExternal(uint8_t endpoint, zclport_pFnZclHandleExternal pfn);
Then fix zcl_port.c
// multiple endpoint for ZCL handler external, added by luoyiming 2020-02-08
typedef struct
void *next;
uint8_t endpoint;
zclport_pFnZclHandleExternal pfn;
} zclHandleExternalList_t;
// Function pointer for applications to ZCL Handle External
// added multiple endpoint processing by luoyiming at 2020-02-08
zclHandleExternalList_t *zclHandleExternalList = NULL;
* Call to register a function pointer to handle zcl_HandleExternal() messages.
* Added multiple endpoint processing by luoyiming at 2020-02-08.
* Public function defined in zcl_port.h
bool zclport_registerZclHandleExternal( uint8_t endpoint, zclport_pFnZclHandleExternal pfn )
zclHandleExternalList_t *find = zclHandleExternalList;
zclHandleExternalList_t *tail = NULL;
// If endpoint is valid, added by luoyiming 2020-02-08
if ( zcl_afFindEndPointDesc( endpoint ) == NULL )
return false;
// match if there be same endpoint and find tail item, fixed by luoyiming 2020-02-08
while ( find )
if ( find->endpoint == endpoint )
find->pfn = pfn;
return true;
if ( find->next == NULL )
tail = find;
find = find->next;
// add new item, fixed by luoyiming 2020-02-08
zclHandleExternalList_t *newItem = zcl_mem_alloc( sizeof(zclHandleExternalList_t) );
if ( newItem )
newItem->next = NULL;
newItem->endpoint = endpoint;
newItem->pfn = pfn;
if ( zclHandleExternalList == NULL )
zclHandleExternalList = newItem;
else
tail->next = newItem;
return true;
return false;
* @fn zcl_HandleExternal
* @brief Callback function to handle messages externally
* @param pInMsg - incoming message to process
* @return TRUE
uint8_t zcl_HandleExternal(zclIncoming_t *pInMsg)
#ifdef BDB_REPORTING
zclIncomingMsg_t *pCmd;
pCmd = (zclIncomingMsg_t *)OsalPort_msgAllocate( sizeof ( zclIncomingMsg_t ) );
if ( pCmd != NULL )
// fill in the message
pCmd->hdr.event = ZCL_INCOMING_MSG;
pCmd->zclHdr = pInMsg->hdr;
pCmd->clusterId = pInMsg->msg->clusterId;
pCmd->srcAddr = pInMsg->msg->srcAddr;
pCmd->endPoint = pInMsg->msg->endPoint;
pCmd->attrCmd = pInMsg->attrCmd;
if(pCmd->zclHdr.commandID == ZCL_CMD_CONFIG_REPORT)
zstack_bdbProcessInConfigReportReq_t Req = {0};
Req.pZclIncommingMsg = pCmd;
Zstackapi_bdbProcessInConfigReportCmd(zclPortFindEntity(pCmd->endPoint),&Req);
OsalPort_msgDeallocate((uint8_t*)pCmd);
return TRUE;
if(pCmd->zclHdr.commandID == ZCL_CMD_READ_REPORT_CFG)
zstack_bdbProcessInReadReportCfgReq_t Req = {0};
Zstackapi_bdbProcessInReadReportCfgCmd(zclPortFindEntity(pCmd->endPoint),&Req);
return TRUE;
#endif
// zclHandleExternal for multiple endpoint, fixed by luoyiming 2020-02-08
// Did the application register to handle this message
while ( find )
if ( ( find->endpoint == pInMsg->msg->endPoint ) && ( find->pfn ) )
// Let the application handle it
return (find->pfn( pInMsg ));
find = find->next;
return(TRUE);
The completely solution is in my GitHub
