Other Parts Discussed in Thread: CC2530, Z-STACK
I am running smart energy sample application using 2 CC2530 devices, one as coordinator/ESP, and the other as router/simple metering device.
Following is the procedure in my experiment:
1. I turned on coordinator, then router. They are connected. This can be seen using the packet sniffer.
2. I turned off the coordinator. I can see the router is sending the following 3 types of frames repeatedly.
a) NWK link status frame,
b) NWK route request frame. I can see the frame has coordinator's IEEE address as its destination IEEE address.
c) APS/SE current summation delivered frame,
Since the coordinator is not alive, the router repeatedly sends these frames.
3. In the last step, I turned on the coordinator again. However, the router can not join the coordinator automatically.
What should be coordinator's response if it sees a "route request" command with its IEEE address from the router?
Should I do anything at the application layer, for example the router issues rejoin command after certain amount of failures, or should this be taken care of in the network layer automatically?
Yiliang
