Linux: building Zigbee 3.0 Linux Gateway to x86 platform failed
Other Parts Discussed in Thread: LAUNCHXL-CC26X2R1, CC2531EMK
Tool/software: Linux
I am running into a problem while building Zigbee_3_0_Linux_Gateway_1_0_0 to x86 platform. I have changed target platform in the build script to x86 i.e. in $(INSTALL_DIR)/source/scripts/package_builder file. I ran "build_all" script but it ended up with errors.
gcc -Wall -DVERSION_NUMBER="0.1" main.o zbSocCmd.o zbSocTransportUart.o -L.../usr/lib/  -o gw_soc_fw_version_query.bin
cp: cannot stat '/home/securifi/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/scripts/hagateway/reset/x86/soc_reset_hold': No such file or directory
cp: cannot stat '/home/securifi/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/scripts/hagateway/reset/x86/soc_reset_release': No such file or directory
cp: cannot stat '/home/securifi/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/protobuf-c/lib/x86/libprotobuf-c.so.0.0.0': No such file or directory
Package verification results:
ERROR: 2 error(s) occured during make
ERROR: 110 warning(s) occured during make
sort: cannot read: /home/securifi/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/scripts/package_builder_expected_content_RUNTIME_x86.txt: No such file or directory
diff /home/securifi/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/out/content.txt /home/securifi/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/out/expected_content.txt
1,29d0
< ./content.txt
< ./Precompiled
< ./Precompiled/app
< ./Precompiled/app/main.bin
< ./Precompiled/misc
< ./Precompiled/misc/CC2531-GW-ZNP_39203.bin
< ./Precompiled/misc/ota_sample_images
< ./Precompiled/misc/ota_sample_images/5678-1234-0000AAAA.zigbee
< ./Precompiled/misc/ota_sample_images/5678-1234-0000BBBB.zigbee
< ./Precompiled/protobuf
< ./Precompiled/servers
< ./Precompiled/servers/config.ini
< ./Precompiled/servers/gateway_config.ini
< ./Precompiled/servers/gateway_config.tlg
< ./Precompiled/servers/GATEWAY_SRVR_x86
< ./Precompiled/servers/NPI_Gateway.cfg
< ./Precompiled/servers/NPI_lnx_x86_server
< ./Precompiled/servers/nwkmgr_config.ini
< ./Precompiled/servers/NWKMGR_SRVR_x86
< ./Precompiled/servers/OTA_SRVR_x86
< ./Precompiled/servers/sample_app_ota.cfg
< ./Precompiled/servers/start_application
< ./Precompiled/servers/track_servers
< ./Precompiled/servers/zigbeeHAgw
< ./Precompiled/servers/ZLSZNP_x86
< ./Precompiled/tools
< ./Precompiled/tools/gw_soc_fw_version_query.bin
< ./Precompiled/tools/sbl_tool.bin
ERROR: Content verification failed
mv: target 'directory.tar' is not a directory
ERROR: RUNTIME package for x86 creation failed. See details above. Output folder/tar name prefixed with "ERROR_."
The build says failed but it generated servers as I see in this folder "source/ERROR__out/Precompiled/servers". I tried to run the generated servers using "zigbeeHAgw" script. It always failed and says "Could not initialize SoC... exiting".
$ ./zigbeeHAgw x86
running ./zigbeeHAgw on an x86
done processing arguments, board type x86, target x86
NPI                 is 'NPI_lnx_x86_server'
Zstack linux server is 'ZLSZNP_x86'
gateway server      is 'GATEWAY_SRVR_x86'
network manager     is 'NWKMGR_SRVR_x86'
OTA server     	  is 'OTA_SRVR_x86'
Starting the ZigBee gateway subsystem
making sure there are no lingering servers...
there are 0 NPI servers
there are 0 ZLS servers
there are 0 GATEWAY servers
there are 0 NWKMGR servers
there are 0 OTA servers
(total 0)
done
starting NPI, cmd ' ./NPI_lnx_x86_server NPI_Gateway.cfg ' on Sat May 11 12:29:20 IST 2019
[12:29:20.533,786] [NPISRVR/MAIN] UNMSKBL:
[12:29:20.533,821] [NPISRVR/MAIN] UNMSKBL:  ************************************************
[12:29:20.533,824] [NPISRVR/MAIN] UNMSKBL:  *  NPI Server v1.0.2d                          *
[12:29:20.533,826] [NPISRVR/MAIN] UNMSKBL:  ************************************************
[12:29:20.533,827] [NPISRVR/MAIN] UNMSKBL:
getaddrinfo error: Servname not supported for ai_socktype
Startup phase 1 completed successfully, server started (NPI_PID=16910) on Sat May 11 12:29:20 IST 2019
starting ZLSZNP, cmd ' ' on Sat May 11 12:29:20 IST 2019
[12:29:20.558,930] [Z_STACK/MAIN] UNMSKBL:
[12:29:20.558,997] [Z_STACK/MAIN] UNMSKBL:  ************************************************
[12:29:20.559,001] [Z_STACK/MAIN] UNMSKBL:  *  ZStack Server for ZNP v1.0.2d               *
[12:29:20.559,003] [Z_STACK/MAIN] UNMSKBL:  ************************************************
[12:29:20.559,005] [Z_STACK/MAIN] UNMSKBL:
[12:29:22.559,123] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:22.559,145] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
[12:29:24.559,257] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:24.559,298] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
[12:29:26.559,443] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:26.559,476] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
[12:29:28.559,609] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:28.559,628] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
[12:29:30.559,749] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:30.559,771] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
[12:29:32.559,877] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:32.559,894] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
[12:29:34.560,035] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:34.560,078] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
[12:29:36.560,221] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:36.560,245] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
[12:29:38.560,374] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:38.560,388] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
Startup phase 2 completed successfully, server started (ZLSZNP_PID=16918) on Sat May 11 12:29:38 IST 2019
starting NETWORK_MGR, cmd ' ./NWKMGR_SRVR_x86 127.0.0.1:2536 ' on Sat May 11 12:29:38 IST 2019
[12:29:38.562,932] [NWK_MGR/MAIN] UNMSKBL:
[12:29:38.562,960] [NWK_MGR/MAIN] UNMSKBL:  ************************************************
[12:29:38.562,963] [NWK_MGR/MAIN] UNMSKBL:  *  Network Manager Server v1.0.2d              *
[12:29:38.562,965] [NWK_MGR/MAIN] UNMSKBL:  ************************************************
[12:29:38.562,967] [NWK_MGR/MAIN] UNMSKBL:
[12:29:40.560,745] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:40.560,781] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
[12:29:40.563,256] [NWK_MGR/MAIN] ERROR  : SRSP Cond Wait timed out!
[12:29:40.563,288] [NWK_MGR/MAIN] ERROR  : apicSendSynchData() failed getting response
[12:29:40.563,568] [NWK_MGR/MAIN] ERROR  : Reading Local Network Information Failed
[12:29:40.563,582] [NWK_MGR/MAIN] UNMSKBL: Initialization failed. Quitting now.
Startup phase 3 failed
waiting for Zstack linux to exit
waiting for NPI to exit
(total 0)
done
Please unplug the ZigBee USB dongle (/dev/ttyACM0) to continue...
Please wait...
Please plug in the ZigBee USB dongle to continue...
Please wait...
starting NPI, cmd ' ./NPI_lnx_x86_server NPI_Gateway.cfg ' on Sat May 11 12:30:01 IST 2019
[12:30:01.731,957] [NPISRVR/MAIN] UNMSKBL:
[12:30:01.732,074] [NPISRVR/MAIN] UNMSKBL:  ************************************************
[12:30:01.732,087] [NPISRVR/MAIN] UNMSKBL:  *  NPI Server v1.0.2d                          *
[12:30:01.732,095] [NPISRVR/MAIN] UNMSKBL:  ************************************************
[12:30:01.732,102] [NPISRVR/MAIN] UNMSKBL:
[12:30:01.732,635] [NPISRVR/MAIN] ERROR  : Could not initialize SoC... exiting
Startup phase 1 failed
(total 0)
done
  • Please refer to the following instructions: e2e.ti.com/.../2845752
    Ryan
  • Hi Ryan
    Actually, I am trying to install on Ubuntu 16.04 machine.
    I followed the instructions from the link you sent. But still getting errors.
    Compiling ../zstackserverznp/zstack_pb_ctrl.c
    Linking ZLSZNP_x86
    ../protobuf-c/lib/x86/libprotobuf-c.a: error adding symbols: File truncated
    collect2: error: ld returned 1 exit status
    Makefile:121: recipe for target 'ZLSZNP_x86' failed
    make: *** [ZLSZNP_x86] Error 1
    Compiling ../zstackserverznp/zstack_pb_ctrl.c ...
    Compiling ../nwkmgr/nwkmgr_pb_ctrl.c ...
    Compiling ../serverpb/server_pb_ctrl.c ...
    Building target out/NWKMGR_SRVR_x86 ...
    Makefile:180: recipe for target 'out/NWKMGR_SRVR_x86' failed
    make[1]: *** [out/NWKMGR_SRVR_x86] Error 1
    make[1]: Leaving directory 'Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/nwkmgr'
    Makefile:125: recipe for target 'arch-all-x86' failed
    make: *** [arch-all-x86] Error 2
    Compiling ../hagateway/gateway_pb_ctrl.c ...
    Compiling ../nwkmgr/nwkmgr.pb-c.c ...
    Building target out/GATEWAY_SRVR_x86 ...
    Makefile:194: recipe for target 'out/GATEWAY_SRVR_x86' failed
    make[1]: *** [out/GATEWAY_SRVR_x86] Error 1
    make[1]: Leaving directory 'Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/hagateway'
    Makefile:147: recipe for target 'arch-all-x86' failed
    Compiling ../otaserver/otasrvr_pb_ctrl.c ...
    Building target out/OTA_SRVR_x86 ...
    Makefile:186: recipe for target 'out/OTA_SRVR_x86' failed
    make[1]: *** [out/OTA_SRVR_x86] Error 1
    make[1]: Leaving directory 'Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/otaserver'
    Makefile:127: recipe for target 'arch-all-x86' failed
  • Instructions should be the same regardless of Ubuntu version. The errors indicate a libprotobuf-c issue, you can try "sudo apt-get install libprotobuf-c-dev:i386" to download the 32-bit version and copy libprotobuf-c.a/la/so.1/so.1.0.0 from /usr/lib/i386-linux-gnu. You may also want to apply "sudo apt-get install gcc-multilib".
    Ryan
  • Hi Ryan
    That worked. Thanks for the instructions. Compilation pass with zero errors, still some warnings are there but I continued.
    I am launching the servers with "sudo ./zigbeeHAgw x86" command. All the servers are running fine.
    On the other terminal I am launching the User Interface application with "./start_application" command. While launching the UI application it is giving the following message and not proceeding further.
    Terminal dimentions are not optimal - it is currently set to 38 rows by 150 columns.
    Please resize terminal to at least 53 rows by 150 columns.
    Press [ENTER] to recheck, [Q/q] to quit or any other key to use the current terminal dimentions.
    But the terminal is maximized to my monitor size. Please help me to meet the requirement.
  • Glad to hear that it's operational now, zoom out in your terminal to address the dimension issue.
    Ryan
  • Hi Ryan
    Some times "ZLSZNP_x86" is getting disconnected even though it is idle.
    [11:39:37.008,232] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
    [11:39:37.008,258] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
    [11:39:39.008,418] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
    [11:39:39.008,443] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
    Synchronous Request Timeout...
    [11:39:41.008,564] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
    [11:39:41.008,581] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
    [11:39:43.008,734] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
    [11:39:43.008,760] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
    [11:39:45.008,921] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
    [11:39:45.008,946] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
    [11:39:47.009,094] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
    [11:39:47.009,122] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
    [11:39:49.009,299] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
    [11:39:49.009,325] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
    [11:39:51.009,505] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
    [11:39:51.009,546] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
    [11:39:53.009,734] [Z_STACK/MAIN] ERROR  : SRSP Cond Wait timed out!
    [11:39:53.009,761] [Z_STACK/MAIN] ERROR  : apicSendSynchData() failed getting response
    Even restarting the script didn't work.
    If I get "Unhandled SRSP cleared" then I am restarting the zigbeeHAgw script and it started working.
    [11:39:53.019,889] [Z_STACK/READ] WARNING: [ERR] Unhandled SRSP cleared
    [11:39:53.028,420] [Z_STACK/READ] WARNING: [ERR] Unhandled SRSP cleared
    [11:39:53.036,752] [Z_STACK/READ] WARNING: [ERR] Unhandled SRSP cleared
    [11:39:53.039,514] [Z_STACK/READ] WARNING: [ERR] Unhandled SRSP cleared
    [11:39:53.599,391] [Z_STACK/READ] WARNING: [ERR] Unhandled SRSP cleared
    Can you please explain what is the workaround at this situation.
  • What's your ZNP HW? CC2531EMK or LAUNCHXL-CC26x2R1?
  • It is LAUNCHXL-CC26x2R1
  • If you do reset to LAUNCHXL-CC26x2R1, does it work again?
  • I haven't tried. Moreover, Reset I don't want to do. Because I am using it as coordinator and it has some devices added to the network. I will loose them if I do reset.
  • Maybe try to build ZNP by yourself and debug what happens.
  • You shouldn't lose the devices so long as NV_INIT and NV_RESTORE are defined in the ZNP project (default) and a reset is performed which does not clear NV items (soft vs hard reset).
