On the Coordinator's Processing, In function "ZDSecMgrDeviceJoinDirect", "bdb_TCAddJoiningDevice" is executed after "ZDSecMgrDeviceJoin". But in function "ZDSecMgrUpdateDeviceInd", "bdb_TCAddJoiningDevice" is executed before than "ZDSecMgrDeviceJoin".
ZDSecMgrUpdateDeviceInd can be fixed like this.
void ZDSecMgrUpdateDeviceInd( ZDO_UpdateDeviceInd_t* ind )
ZDSecMgrDevice_t device;
#if (ZG_BUILD_COORDINATOR_TYPE)
uint8_t tcJoin = FALSE; //fixed by luoyiming, 2019-10-22
#endif
device.nwkAddr = ind->devAddr;
device.extAddr = ind->devExtAddr;
device.parentAddr = ind->srcAddr;
device.devStatus = DEV_SEC_INIT_STATUS;
device.secure = FALSE;
// Trust Center should identify the type of JOIN/REJOIN and
// Transport the NWK key accordingly, it will only be transported for:
// APSME_UD_STANDARD_UNSECURED_JOIN
// OR APSME_UD_STANDARD_TRUST_CENTER_REJOIN
if ( ind->status != APSME_UD_DEVICE_LEFT )
if ( ind->status == APSME_UD_STANDARD_SECURED_REJOIN )
device.devStatus &= ~DEV_SEC_INIT_STATUS;
device.devStatus |= DEV_SEC_AUTH_STATUS;
device.secure = TRUE;
else if ( ind->status == APSME_UD_STANDARD_TRUST_CENTER_REJOIN )
device.devStatus |= DEV_SEC_AUTH_TC_REJOIN_STATUS;
else
uint8_t found;
uint16_t keyNvIndex, index;
APSME_TCLinkKeyNVEntry_t TCLKDevEntry;
keyNvIndex = APSME_SearchTCLinkKeyEntry(device.extAddr,&found, &TCLKDevEntry);
//If found and it was verified, then allow it to join in a fresh state by erasing the key entry
if((found == TRUE) && (TCLKDevEntry.keyAttributes == ZG_VERIFIED_KEY))
TCLKDevEntry.keyAttributes = ZG_DEFAULT_KEY;
//Increase the shift by one. Validate the maximum shift of the seed which is 15
TCLKDevEntry.SeedShift_IcIndex++;
TCLKDevEntry.SeedShift_IcIndex &= 0x0F;
TCLKDevEntry.rxFrmCntr = 0;
TCLKDevEntry.txFrmCntr = 0;
index = keyNvIndex;
TCLinkKeyRAMEntry[index].rxFrmCntr = 0;
TCLinkKeyRAMEntry[index].txFrmCntr = 0;
//Update the entry
osal_nv_write_ex(ZCD_NV_EX_TCLK_TABLE, keyNvIndex,
sizeof(APSME_TCLinkKeyNVEntry_t),
&TCLKDevEntry);
//old bdb_TCAddJoiningDevice
tcJoin = TRUE; //TC Add Joining device after ZDSecMgrDeviceJoin, fixed by luoyiming 2019-10-22
#endif
if( ZSuccess == ZDSecMgrDeviceJoin( &device ) )
if( tcJoin == TRUE )
bdb_TCAddJoiningDevice(device.parentAddr,device.extAddr);
#endif
else
// remove the TCLK NV entry for a device which has left the network
uint8_t found;
//If found and it was verified, erase the key entry
memset(&TCLKDevEntry,0,sizeof(APSME_TCLinkKeyNVEntry_t));
index = keyNvIndex;
TCLinkKeyRAMEntry[index].entryUsed = FALSE;
//Update the entry
&TCLKDevEntry);
#endif
// execute devie leave notify callback, add by luoyiming
if( NULL != pZDSecMgrDeviceLeaveNotifyCallback )
pZDSecMgrDeviceLeaveNotifyCallback( device.nwkAddr, device.extAddr, device.parentAddr );
