Other Parts Discussed in Thread: Z-STACK
I am using Z-Stack 2.4.0 (PRO disabled). How may I obtain the following information about an End Device's parent, after it has joined the network?
- IEEE address
- Network address
- LQI
Thanks.
Hi Jim,
From the Z-Stack API:
3.4.2.1.3 NLME_GetCoordShortAddr() This function will return the device's parent’s network (short - 16 bit) address. This is NOT the Zigbee Coordinator’s short address (it’s always 0x0000). In MAC terms, the parent is called a coordinator.
3.4.2.1.4 NLME_GetCoordExtAddr() This function will get the device's parent’s IEEE (64 bit) address. This is NOT the Zigbee Coordinator’s extended address. In MAC terms, the parent is called a coordinator.
Check out the Simple API document:
C:\Texas Instruments\ZStack-CC2530-2.4.0-1.4.0\Documents\Z-Stack Simple API.pdf
For LQI, you can't know until the device in question sends a message OA, check out the parameters of an incoming message at the Application layer - when the AF layter sends the AF_INCOMING_MSG_CMD message, you get a "afIncomingMSGPacket_t *pkt" which has RSSI:
typedef struct
osal_event_hdr_t hdr; /* OSAL Message header */
uint16 groupId; /* Message's group ID - 0 if not set */
uint16 clusterId; /* Message's cluster ID */
afAddrType_t srcAddr; /* Source Address, if endpoint is STUBAPS_INTER_PAN_EP,
it's an InterPAN message */
uint16 macDestAddr; /* MAC header destination short address */
uint8 endPoint; /* destination endpoint */
uint8 wasBroadcast; /* TRUE if network destination was a broadcast address */
uint8 LinkQuality; /* The link quality of the received data frame */
uint8 correlation; /* The raw correlation value of the received data frame */
int8 rssi; /* The received RF power in units dBm */
uint8 SecurityUse; /* deprecated */
uint32 timestamp; /* receipt timestamp from MAC */
afMSGCommandFormat_t cmd; /* Application Data */
} afIncomingMSGPacket_t;
