AF_DataRequest function.
When device A sends to device B a message, it uses the AF_DataRequest function.
I wanted to know pleaes, when device A sends a message to device B, and AF_DataRequest returns afStatus_SUCCESS, does it mean that device B has necessarily received the message, or does it just mean that device A has managed to send the message successfully, without knowing if device B has received it?
Thank you very much.
Shahar.
  • I believe the SRSP simply indicates that it was transmitted.
    If you specify AF_ACK_REQUEST in the flags parameter, then the AF_DATA_CONFIRM message will indicate that the destination received the message (APS ACK).
    If you don't specify AF_ACK_REQUEST, then AF_DATA_CONFIRM confirms a response from the first hop (MAC ACK).
    AF_DATA_CONFIRM has a status byte that must be examined.
    I reached this thread when searching information about AF_DataRequest.
    I wanted to ask please,
    If you specify the AF_ACK_REQUEST in the tx_options, does the AF_DataRequest function won't return an afStatus_SUCCESS only if the message has reached its destination? (not just the first hop)
    If its not correct, could you please tell me how to examine the AF_DATA_CONFIRM in order to know if the destination has received the sent message?
    Thank you very much in advance.
  • The AF_DATA_REQUEST with tx_options == AF_ACK_REQUEST may have an SRSP with a status of SUCCESS even if the message does not reach the final destination.
    The AF_DATA_CONFIRM message looks like
    Length, Cmd0, Cmd1, Status, EndPoint, TransId.  These are all single byte values.
    Status == 0 is SUCCESS.
    This is all documented in swra175a.pdf
  • I'm trying to implement a timeout feature when an APS ACK is not received for a certain amount of time....
    I'm noting that when using the AF_ACK_REQUEST option for the AF_DataRequest function (in SampleApp.c of ZStack-MSP2618-2.3.0), I only register the first APS ACK received.  The AF_DATA_CONFIRM_CMD case (in ZDApp.c) is never executed after this initial time.
    I've also noted that when I don't use the AF_ACK_REQUEST option, I still get one (and only one) iteration of the AF_DATA_CONFIRM_CMD case, so I doubt whether my configuration of the AF_DataRequest function is configuring the reception of APS ACKs at all.
    Anyone else in a similar boat or have an idea as to why this may be happening?
