Sensor Demo Software Rev.C Linking Error
Other Parts Discussed in Thread: Z-STACK, CC2531, CC2530EM, CC2530
After recently purchasing the CC2530ZDK I downloaded the SensorDemo (CC2530ZDK Sensor Demo Software (Rev. C) ) and I'm trying to build from the included source files but I'm getting an error during linking.
Here is what I have done so far:
- I downloaded and installed latest Z-Stack-Home 1.2.1 from here: http://www.ti.com/tool/z-stack
- I read the release notes and it states that the library and hex files were built and tested with IAR EW8051 8.30.3.
- I downloaded and installed IAR EW8051 8.30.3.
- Downloaded CC2530ZDK Sensor Demo Software (Rev. C) and unzip to where zstack is installed.
- I open the included IAR project. It says it needs to convert to new format, OK.
- I execute "Rebuild All". Everything compiles but I get the following error when Linking starts:
Error[e46]: Undefined external "ZDiagsUpdateStats::?relay" referred in APS ( C:\Texas Instruments\Z-Stack Home 1.2.1\Projects\zstack\Libraries\TI2530DB\bin\Router-Pro.lib )
Is there a way to make this work with the current version of the Z-Stack even if the Sensor Demo Software was made with an older version? Change some settings in the project options?
Thank you for reading this.
Jonathan
  • After recently purchasing the CC2530ZDK I downloaded the SensorDemo (CC2530ZDK Sensor Demo Software (Rev. C) ) and I'm trying to build from the included source files but I'm getting an error during linking.
    - I downloaded and installed latest Z-Stack-Home 1.2.1 from here: http://www.ti.com/tool/z-stack).
    Jonathan
  • The architecture of Z-Stack is changed so sensor demo cannot be compiled in latest Z-Stack Home. You can try to download Z-Stack mesh and put sensor demo inside to try again.
  • Thank you for responding. As suggested I have tried building "Sensor Demo" with Z-Stack mesh but that doesn't work either. I guess I'll try the examples included in the Z-Stack-Home.
  • Yes, you can try SampleTemperatureSensor in Z-Stack Home.
    I had the same problem. I placed the Sample code in directory  and added the file Z-Stack Mesh 1.0.0\Components\stack\sys\ZDiags.c to the project. Now I was able to Build without error.
    I would like to use this example on USB-Stick CC2531 Dongle. Should this be possible ?
    I have a SmartRF06 EVA Kit. Can I use the Sample CC2538EM or does it only work on CC2530. If so Can I connect a CC2530EM to the SmartRF06 ?
    Thanks and best regards,
    Gerhard
  • To use CC2530EM, you have to use SmartRF05EB. To use CC2538EM, you need to use SmartRF06EB.
