CC2531: CC2531 End Device Showing UNKNOWN
Part Number: CC2531
I am trying to show casing device as a end device. I am using below script file to make device to end device.
  Filename:       znp-bringup.zjs
  Revised:        $Date:$
  Revision:       $Revision:$
  Description:    This file is a test script bring up ZC and ZR.
  Copyright 2010 Texas Instruments Incorporated. All rights reserved.
  IMPORTANT: Your use of this Software is limited to those specific rights
  granted under the terms of a software license agreement between the user
  who downloaded the software, his/her employer (which must be your employer)
  and Texas Instruments Incorporated (the "License").  You may not use this
  Software unless you agree to abide by the terms of the License. The License
  limits your use, and you acknowledge, that the Software may not be modified,
  copied or distributed unless embedded on a Texas Instruments microcontroller
  or used solely and exclusively in conjunction with a Texas Instruments radio
  frequency transceiver, which is integrated into your product.  Other than for
  the foregoing purpose, you may not use, reproduce, copy, prepare derivative
  works of, modify, distribute, perform, display or sell this Software and/or
  its documentation for any purpose.
  YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
  PROVIDED �AS IS� WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
  INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
  NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
  TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
  NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
  LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
  INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
  OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
  OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
  (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
  Should you have any questions regarding your right to use this Software,
  contact Texas Instruments Incorporated at www.TI.com.
  Instructions:
  Connect a device to be a ZC to a COM nicknamed �C� and another to a COM named �R�
import System;
import System.Text;
import TI.ZPI2;
class TheScript
  // Set to 'true' when running the ZNP in order to reset the devices and startup the network.
  private var ZNP_RUN : boolean = true;
  private var SUCCESS : int = 0;
  private var HOMEAUT : int = 0x0104;
  private var LIGHT   : int = 0x0100;
  private var AF_DEFAULT_RADIUS : int = 0x1E;
  // Set this variable to the script engine's nickname for the COM port to the target device.
  private var ZR_Com : String = "COM17";
  private var ZC_Com : String = "COM3";
  // Set this variable to 'true' to enable the display of log messages (i.e. verbose mode).
  private var showLogMsgs : boolean = true;
  // Variables set by the incoming message handler to enable "re-try until success" looping.
  private var gotRstRsp           : boolean = false;
  private var gotCfgRsp           : boolean = false;
  private var gotRegRsp           : boolean = false;
  private var gotStartRsp         : boolean = false;
  private var gotStateRsp         : boolean = false;
  private var gotAfReqExtRsp      : boolean = false;
  private var gotAfIncExt         : boolean = false;
  private var gotAfStoreRsp       : boolean = false;
  private var gotAfRetrieveRsp    : boolean = false;
  private var gotDevRsp           : boolean = false;
  private var gotEpRsp            : boolean = false;
  private var gotSdescRsp         : boolean = false;
  private var gotTogRsp         : boolean = false;
  private var isLight             : boolean = false;
  private var lightStatus             : boolean = false;
  private var profileId           : UInt16  = 0x0104;  // HA Profile ID
  private var devId               : UInt16  = 0x0100;  // HA Profile ID
  private var endPoint            : Byte    = 0x07;    // SampleSW has endpoint 12 so we use that
  private var inClusterCnt        : Byte    = 5;
  private var outClusterCnt       : Byte    = 1;
  private var inClusterList = new Array(inClusterCnt);
  private var outClusterList = new Array(outClusterCnt);
  private var NV_STARTUP_OPTION     : Byte = 0x03;
  private var NV_STARTUP_OPTION_VAL : Byte = 0x03;	// 0x03 = clear configuration
  private var NV_STARTUP_LEN        : Byte = 1;
  private var cfgArr = new Array(256);        // Make big enough for any configuration item.
  private var retrieveBuf = new Array(1024);  // Make big enough for any huge message attempted.
  private var retrieveTot           : UInt16 = 741;
  private var retrieveLen           : Byte = 247;
  private var retrieveIdx           : UInt16;
  private var devaddr               : UInt16;
  private var dstEndPoint           : Byte    = 0x00;
  //DATA REQUEST VARIABLES
  private var drData = new Array(99);
  private var drCluster           : UInt16;
  private var drTrans          : Byte;
  private var drOption           : Byte;
  private var drRadius           : Byte = 0x1E;//AF_DEFAULT_RADIUS
  private var drLen           : Byte;
  //INCOMING MESSAGES VARIABLES
  private var imData = new Array(99);
  private var imGroup           : UInt16;
  private var imCluster           : UInt16;
  private var imSrcAddr           : UInt16;
  private var imSrcEndp           : Byte;
  private var imDstEndp           : Byte;
  private var imLen           : Byte;
  // Main class function that effects the work of this test script.
  function run() {
    //set up clusters for light
    inClusterList[0] = 0;
    inClusterList[1] = 3;
    inClusterList[2] = 4;
    inClusterList[3] = 5;
    inClusterList[4] = 6;
    outClusterList[0] = 0;
	outClusterList[1] = 1;
    // Subscribe to the incoming message handler.
    ZEngine.add_OnMessageZPI2(this.msgHandler);
    if (ZNP_RUN)
      // Force a device out of the boot loader wait routine (no bad effect when SBL is not present).
      //sysReset(ZC_Com);
      // Set the Startup_Option to Clear Configuration and reset to effect the action.
      //cfgArr[0] = NV_STARTUP_OPTION_VAL;
      //writeCfg(ZC_Com , NV_STARTUP_OPTION, NV_STARTUP_LEN, cfgArr);
      //sysReset(ZC_Com);
      sysReset(ZR_Com);
      writeCfg(ZR_Com , NV_STARTUP_OPTION, NV_STARTUP_LEN, cfgArr);
      sysReset(ZR_Com);
      // Setup the device type, panId & channel mask and reset to effect the settings.
      cfgArr[0] = 0x00;                    // Set Logical Device Type to ZC.
      //writeCfg(ZC_Com, 0x87, 0x01, cfgArr);
      cfgArr[0] = 0x02;                    // Set Logical Device Type to ZR.
      writeCfg(ZR_Com, 0x87, 0x01, cfgArr);
      cfgArr[0] = 0x22; cfgArr[1] = 0x06;  // Set Pan Id to 0x0622 // Change this to anything you need to test
      //writeCfg(ZC_Com, 0x83, 0x02, cfgArr);
      writeCfg(ZR_Com, 0x83, 0x02, cfgArr);
      cfgArr[0] = 0x00; cfgArr[1] = 0x08; cfgArr[2] = 0x00; cfgArr[3] = 0x00; //channel 11
                                         // Set Channel Mask to 0x00100000  // 20 - 0x14
					 // Set Channel Maks to 0x00080000  // 19 - 0x13 - Current channel mask
      //writeCfg(ZC_Com, 0x84, 0x04, cfgArr);
      writeCfg(ZR_Com, 0x84, 0x04, cfgArr);
	  cfgArr[0] = 0xAA; cfgArr[1] = 0xBB;
      //writeCfg(ZC_Com,0x62, 16, cfgArr); //program the NWK Key 1st two bytes are AA and BB
      // Start the devices on the network.
      //startReq(ZC_Com);
      cfgArr[0] = true;
      writeCfg(ZR_Com, 0x8F, 0x01, cfgArr);// Set ZCD_NV_ZDO_DIRECT_CB to true. ZCD_NV_ZDO_DIRECT_CB address = 0x8F
      afReg(ZR_Com); // define end point
      startReq(ZR_Com);
      while(1)
          //wait for incoming messages
    ZEngine.Complete(true);
  function setDataReq(mode : Byte) { // mode: 0 = switch, 1 = default response, 2 = read attribute, 3 = read attribute response
      if (mode == 0)//switch
          drCluster = 0x6;
          drTrans = 0;
          drOption = 0x0;
          drLen = 3;
          drData[0] = 0x01;
          drData[1] = 0x00;
          drData[2] = 0x02;
      else if (mode == 1)//default response
          drCluster = imCluster;
          drTrans = 0;
          drOption = 0x0;
          drLen = 5;
          drData[0] = 0x18; //frame control
          drData[1] = 0x00; //transaction sequence number
          drData[2] = 0x0B; //default response
          drData[3] = imData[2]; //command ID
          drData[4] = 0x00; // status
      else if (mode == 2)//read attribute from light
          drCluster = 0x6;
          drTrans = 0;
          drOption = 0x0;
          drLen = 5;
          drData[0] = 0x00; //frame control
          drData[2] = 0x00; //read attribute
          //attribute ID 16 bits
          drData[3] = 0x00; //attribute ID
          drData[4] = 0x00; // attribute ID
      else if (mode == 3)//read attribute response light
          drTrans = 0;
          drOption = 0x0;
          drLen = 8;
          drData[2] = 0x01; //read attribute response
          drData[3] = imData[3]; //attribute ID
          drData[4] = imData[4]; // attribute ID
          drData[5] = 0x00; //status: success
          drData[6] = 0x20; //Data type: unsigned 8-bit integer
          var attID : UInt16 = (imData[4] << 8) | imData[3]; //attribute ID that will be read
          if(attID == 0)
            drData[7] = lightStatus;
// Send a process incoming message.
  function pInMsg(comm : String) {
     if(imData[0] == 1)
         if(imData[2] == 2)
             lightStatus = (~lightStatus) & 0x01; //toggle light
         else if (imData[2] == 1)
             lightStatus = 0x01; // light ON
         else if (imData[2] == 0)
             lightStatus = 0x00; //light OFF
    if ((imData[0] & 0x01) == 0 && imData[2] == 0)//read attribute
         if (imData[0] == 0 && imData[2] == 0)
            setDataReq(3);
            afDataReq(comm, imSrcAddr, imSrcEndp);//send read attribute response
     else if ((imData[0] & 0x10) == 0)//Default response active
         setDataReq(1);
         afDataReq(comm, imSrcAddr, imSrcEndp);// send default response
// Send a UTIL_GET_DEVICE_INFO message.
  function devInfo(comm : String) {
     var req : UTIL_GET_DEVICE_INFO  = new UTIL_GET_DEVICE_INFO ();
      gotDevRsp = false;
      while(!gotDevRsp)
          logMsg("dev response");
          ZEngine.Send(comm, req);
          ZEngine.Pause(2000);
// Send a ZDO_ACTIVE_EP_REQ message.
  function epReq(comm : String, dst : UInt16, aoi : UInt16) {
    var req : ZDO_ACTIVE_EP_REQ  = new ZDO_ACTIVE_EP_REQ ();
    req.DstAddr = dst;
    req.NWKAddrOfInterest = aoi;
    gotEpRsp = false;
    while(!gotEpRsp)
        logMsg("ZDO_ACTIVE_EP_REQ to " + comm);
        ZEngine.Pause(1000);
// Send a ZDO_SIMPLE_DESC_REQ message.
  function simDescReq(comm : String, dst : UInt16, aoi : UInt16, dstEp : Byte) {
    var req : ZDO_SIMPLE_DESC_REQ  = new ZDO_SIMPLE_DESC_REQ ();
    req.DstAddr = dst;
    req.Endpoint = dstEp;
    gotSdescRsp = false;
    isLight = false;
    while(!gotSdescRsp)
      logMsg("ZDO_SIMPLE_DESC_REQ to " + comm);
  // Send a AF_DATA_REQUEST message.
  function afDataReq(comm : String, dst : UInt16, dstEp : Byte) {
    var req : AF_DATA_REQUEST  = new AF_DATA_REQUEST ();
    req.DstAddr = dst;
    req.DestEndpoint = dstEp;
    req.SrcEndpoint = endPoint;
    req.ClusterID = drCluster;
    req.TransID = drTrans;
    req.Options = drOption;
    req.Radius = drRadius;
    req.Len = drLen;
    for (var idx = 0; idx < drLen; idx++)
          req.Data[idx] = drData[idx];
    logMsg("AF_DATA_REQUEST to " + comm);
  // Handler for incoming messages.
  function msgHandler(comm : String, id : MESSAGE_ID, msg : Object) {
    switch (id)
    case MESSAGE_ID.SYS_RESET_RESPONSE:
      gotRstRsp = true;
      break;
    case MESSAGE_ID.UTIL_GET_DEVICE_INFO_RESPONSE:
        var devRsp : UTIL_GET_DEVICE_INFO_RESPONSE = msg;
        if (devRsp.Status == SUCCESS && devRsp.NumAssocDevices != 0)
            gotDevRsp = true;
            devaddr = devRsp.AssocDevicesList[0];
      break;
    case MESSAGE_ID.ZDO_ACTIVE_EP_RSP:
        var epRsp : ZDO_ACTIVE_EP_RSP = msg;
        if (epRsp.Status == SUCCESS && epRsp.ActiveEPCount != 0)
            gotEpRsp=true;
            dstEndPoint = epRsp.ActiveEPList[0];
      break;
    case MESSAGE_ID.ZDO_SIMPLE_DESC_RSP: /*change*/
        var smpdRsp : ZDO_SIMPLE_DESC_RSP = msg;
        if (smpdRsp.Status == SUCCESS && smpdRsp.ProfileID == HOMEAUT && smpdRsp.DeviceID == LIGHT)
            gotSdescRsp = true;
            isLight = true;
      break;
    case MESSAGE_ID.ZB_WRITE_CONFIGURATION_RSP:
      var cfgRsp : ZB_WRITE_CONFIGURATION_RSP = msg;
      if (cfgRsp.Status == SUCCESS)
        gotCfgRsp = true;
      break;
    case MESSAGE_ID.AF_REGISTER_SRSP:
      var regRsp : AF_REGISTER_SRSP = msg;
      if (regRsp.Status == SUCCESS)
        gotRegRsp = true;
      break;
    case MESSAGE_ID.ZB_START_REQUEST_RSP:
      gotStartRsp = true;
      break;
    case MESSAGE_ID.ZDO_STATE_CHANGE_IND:
      var zdoStateInd : ZDO_STATE_CHANGE_IND = msg;
      // { DEV_END_DEVICE, DEV_ROUTER, DEV_ZB_COORD } : { 6, 7, 9 }
      if ((zdoStateInd.State == 6) || (zdoStateInd.State == 7) || (zdoStateInd.State == 9))
        gotStateRsp = true;
      break;
    case MESSAGE_ID.AF_DATA_REQUEST_EXT_SRSP:
      var afRegExtRsp : AF_DATA_REQUEST_EXT_SRSP = msg;
      if (afRegExtRsp.Status == SUCCESS)
        gotAfReqExtRsp = true;
      break;
    case MESSAGE_ID.AF_DATA_STORE_SRSP:
      var afStoreRsp : AF_DATA_STORE_SRSP = msg;
      if (afStoreRsp.Status == SUCCESS)
        gotAfStoreRsp = true;
      break;
    case MESSAGE_ID.AF_INCOMING_MSG_EXT:
      var afIncExt : AF_INCOMING_MSG_EXT = msg;
      afDataRetrieve(comm, msg);
      gotAfIncExt = true;
      break;
    case MESSAGE_ID.AF_INCOMING_MSG:
      var inMsgDat : AF_INCOMING_MSG = msg;
      imGroup = inMsgDat.GroupID;
      imCluster = inMsgDat.ClusterID;
      imSrcAddr = inMsgDat.SrcAddr;
      imSrcEndp = inMsgDat.SrcEndpoint;
      imDstEndp = inMsgDat.DstEndpoint;
      imLen = inMsgDat.Len;
      for (var idx = 0; idx < imLen; idx++)
          imData[idx] = inMsgDat.Data[idx];
      pInMsg(comm);
      break;
    case MESSAGE_ID.AF_DATA_RETRIEVE_SRSP:
      var afRetrieveRsp : AF_DATA_RETRIEVE_SRSP = msg;
      if (afRetrieveRsp.Status == SUCCESS)
        var index = retrieveIdx;
        for (var idx = 0; idx < afRetrieveRsp.Length; idx++, index++)
          retrieveBuf[index] = afRetrieveRsp.Data[idx];
        gotAfRetrieveRsp = true;
      break;
    default:
      break;
  // Send a ZB_SYSTEM_RESET message until success.
  function sysReset(comm : String) {
    var req : ZB_SYSTEM_RESET = new ZB_SYSTEM_RESET();
    gotRstRsp = false;
    while (!gotRstRsp)
      logMsg("ZB_SYSTEM_RESET  to " + comm);
      ZEngine.Pause(50);
      // Sending SYS_STACK_TUNE as a way to get a 0x07 byte to the SBL before a 0xF8 byte.
      // An 0x07 byte forces the immediate run of valid code.
      //sysStackTune(comm, 7, 7);
      //ZEngine.Pause(300);
  // Send a SYS_STACK_TUNE message.
  function sysStackTune(comm : String, Operation: Byte, Value: Byte) {
    var req : SYS_STACK_TUNE = new SYS_STACK_TUNE();
    req.Operation = Operation;
    req.Value = Value;
    logMsg("SYS_STACK_TUNE to " + comm);
  // Send a ZB_WRITE_CONFIGURATION message.
  function writeCfg(comm : String, cfgId : Byte, len : Byte,  value : Array ) {
    var req : ZB_WRITE_CONFIGURATION = new ZB_WRITE_CONFIGURATION();
    req.ConfigId = cfgId;
    req.Len = len;
		req.Value = new byte[len];
    for (var idx = 0; idx < len; idx++)
      req.Value[idx] = value[idx];
    gotCfgRsp = false;
    while (!gotCfgRsp)
      logMsg("ZB_WRITE_CONFIGURATION  to " + comm);
      ZEngine.Pause(200);
  // Send a ZB_AF_REGISTER_REQUEST message.
  function afReg(comm : String) {
    var req : AF_REGISTER  = new AF_REGISTER ();
    req.AppProfID = profileId;
    req.AppDeviceId = devId;
    req.EndPoint = endPoint;
    req.AppInClusterList = inClusterList;
    req.AppNumInClusters = inClusterCnt;
    req.AppOutClusterList = outClusterList;
    req.AppNumOutClusters = outClusterCnt;
    gotRegRsp = false;
    while (!gotRegRsp)
      logMsg("ZB_AF_REGISTER_REQUEST to " + comm);
      ZEngine.Pause(200);
  // Send a ZB_START_REQUEST message.
  function startReq(comm : String) {
    var req : ZB_START_REQUEST  = new ZB_START_REQUEST();
    gotStateRsp = false;
    while (!gotStateRsp)
      gotStartRsp = false;
      while (!gotStartRsp)
        logMsg("ZB_START_REQUEST  to " + comm);
      ZEngine.Pause(5000);
  /* Make a huge data request via an AF_DATA_REQUEST_EXT message and store the huge data.
   * Since the max MT payload is 250 & the store message header is 3, the max bytes per store
   * is 247. So to simplify the script just use 3 X 247 = 741.
   * Note that we are simultaneously proving the max capacity of 250 bytes per MT message here.
  function afDataReqFrag(comm : String) {
    var req : AF_DATA_REQUEST_EXT = new AF_DATA_REQUEST_EXT();
    req.DstAddrMode = 2;  // Addr16Bit = 2
    req.DstAddr[0] = 0; req.DstAddr[1] = 0;  // Short address 0x0000 is for ZC.
    req.DstEndPoint = endPoint;
    req.DstPanId = 0;  // Zero signifies not Inter-PAN.
    req.ClusterID = 1;  // Startup initialization makes cluster Id's 1,2,3... up to count.
    req.TransID = 0;  // Trans Id is a don't care.
    req.Options = 0;  // AF_TX_OPTIONS_NONE = 0
    req.Radius = 15;  // AF_DEFAULT_RADIUS = 15
    req.Len = retrieveTot;
    gotAfReqExtRsp = false;
    while (!gotAfReqExtRsp)
      logMsg("AF_DATA_REQUEST_EXT to " + comm);
      ZEngine.Pause(3000);
    var index : UInt16 = 0;
    var fragLen : Byte = retrieveLen;
    var fragBuf : Byte[] = new Byte[fragLen];
    for (var idx = 0; idx < fragLen; idx++)
      fragBuf[idx] = idx;
    afDataStore(comm, index, fragLen, fragBuf);
    index += fragLen;
    // Change the frag data to enhance verification reliability on Rx.
    for (idx = 0; idx < fragLen; idx++)
      fragBuf[idx]++;
    index += fragLen;
    // Change the frag data again to enhance verification reliability on Rx.
      // Without a type-cast, the script promotes fragBuf[] to int at run-time.
      fragBuf[idx] = (Byte)(idx * 2);
    // A store of zero length indicates to send it OTA.
    afDataStore(comm, 0, 0, fragBuf);
  // Send a AF_DATA_STORE message.
  function afDataStore(comm : String, index : UInt16, len : Byte, buf : Byte[]) {
    var req : AF_DATA_STORE = new AF_DATA_STORE();
    req.Index = index;
    req.Length = len;
      req.Data[idx] = buf[idx];
    gotAfStoreRsp = false;
    while (!gotAfStoreRsp)
      logMsg("AF_DATA_STORE to " + comm);
      ZEngine.Pause(100);
  // Send a series of AF_DATA_RETRIEVE message(s) to get the data of an incoming huge message.
  function afDataRetrieve(comm : String, msgIn : AF_INCOMING_MSG_EXT) {
    var req : AF_DATA_RETRIEVE = new AF_DATA_RETRIEVE();
    req.Timestamp = msgIn.Timestamp;
    req.Length = retrieveLen;
    for (retrieveIdx = 0; retrieveIdx < msgIn.Len; retrieveIdx += retrieveLen)
      req.Index = retrieveIdx;
      gotAfRetrieveRsp = false;
      while (!gotAfRetrieveRsp)
        logMsg("AF_DATA_RETRIEVE to " + comm);
        ZEngine.Pause(100);
    /* Retrieve request with zero length indicates to flush the message and free the dynamic
     * memory. If this request fails, the device times out the incoming huge message buffer and
     * flushes it automatically, so no loop here.
    req.Length = 0;
    ZEngine.Pause(100);
  // Verify the data in the global retrieveBuf[] according to what was sent in afDataReqFrag().
  function verifyMsgIn() : boolean {
    /* At first writing of this script, the afDataReqFrag() sent 741 bytes.
     * The first 247 bytes were 0-247; the next 247 bytes were 1-248; and the last 247 bytes were
     * calculated as twice the corresponding index.
    var index = 0;
    for (var idx = 0; idx < retrieveLen; idx++, index++)
      if (retrieveBuf[index] != idx)
        break;
    for (var idx = 1; idx <= retrieveLen; idx++, index++)
        break;
      if (retrieveBuf[index] != (Byte)(idx * 2))
        break;
    if (index < retrieveTot)
      return false;
    else
      return true;
  // Display a log message if log messages are enabled.
  function logMsg(theMsg : String) {
    if (showLogMsgs)
      ZEngine.WriteLog(theMsg);  // Display the message.
} // End of TheScript class.
// The script engine will execute the following code.
var script:TheScript = new TheScript();
script.run();
Is there any data is missing in script file?.I want to control light on/off .
How i have to configure device support for controlling light on/off.
Thanks and Regards
Amar.
