Part Number: CC1352P
Other Parts Discussed in Thread: Z-STACK
Hello community,
We are making an application that works on Z-Stack. I want to "save" all the settings for my current coordinator, and copy it to my new coordinator. It would work as if it were a backup of the entire network.
I have various doubts.
First: I am saving the PAN-ID, the network key, and the CSV of the devices. Do I need to save another configuration?
Second: To modify the PAN-ID, I am modifying ZDAPP_CONFIG_PAN_ID in the config.ini configuration file, which defaults to 0xFFFF. When I modify the PAN-ID in the file, and then do a HARD_RESET, the PAN-ID is modified on the network. My question is: This process is correct ??? Why is Channel 0 and PAN-ID 0xFFFE sometimes displayed and the network does not work ????
Third: Is there a logical sequence of steps to backup / restore Zigbee ???
Fourth: Is it possible to backup / restore only by copying specific configuration files ??? In case yes, what files would they be ??
The steps I am doing to get the data are:
-PAN-ID: With NWK_ZIGBEE_NWK_INFO_REQ_VALUE
-Key: With NWK_ZIGBEE_NWK_INFO_REQ_VALUE
-Devices: I copy the 4 CSVs that contain the information of the network devices (DbDeviceInfo.csv, DbEndpoints.csv, DbUpgradeCtxt.csv, DbUpgradeList.csv)
I appreciate any help you can give us. Thank you very much!!!
Kind regards,
Randy
