Other Parts Discussed in Thread: CC2564C
Tool/software: Linux
When we use CC2564C chip in our phone and it's paired with a bluetooth handset and a bluetooth headset at the same time with headset profile.
We found that during speech with handset, headset goes into sniff mode. After about 2 minutes, headset is disconnected and reconnected again.
We have done test to disable sending HCI_Change_Connection_Packet_Type, but the problem is still there.
The logs for CC2564B and CC2564C cases are collected, both BT handset and headset are paired in exactly the same test procedure.
For CC2564C case, the headset lost connection during handset in speech and reconnected and speech transfer to headset (phone behavior), and after a while, handset lost connection and reconnect, so there are 2 times of lost connection happened to headset and handset seperately.
For CC2564B, there is no disconnection happened and handset keeps in speech.
Why CC2564C doesn't work properly? Please help check it. Thanks.
Gao Hong
