Other Parts Discussed in Thread: CC2650, BLE-STACK
I use per-test project , then RAM free size is 8K~9KB.
But I need 15KB RAM size .
I want to use CC2650 cache RAM.
Would you please tell me how to modify linked files??
Thank you.
Abel,
We do not recommend or support re-configuring the cache as RAM since code execution speed will be drastically reduced and current consumption will be much higher.
I would suggest removing the menu driver and LCD driver from your application. This will reduce the RAM usage by several kB. You can also reduce the CSTACK size (2kB by default) in the linker file and reduce the task stack sizes. See the "BLE developers software guide" for information on using the TI RTOS plugin do watch the stack sizes.
Attached is a script that will visualize the IAR map file and show flash and RAM usage for you which is really helpful when optimizing your application.
Svend
<!DOCTYPE html>
<meta charset="utf-8">
<style>
body {
font-family: "Helvetica Neue", Helvetica, Arial, sans-serif;
margin: auto;
position: relative;
width: 1200px;
/*form {
position: absolute;
right: 10px;
top: 10px;
.node {
border: solid 1px white;
font: 11px sans-serif;
line-height: 12px;
overflow: hidden;
position: absolute;
text-indent: 2px;
.chart {
display: block;
margin: auto;
margin-top: 0px;
text {
font-size: 10px;
rect {
fill: none;
.axis path,
.axis line {
fill: none;
stroke: #000;
shape-rendering: crispEdges;
.dot {
stroke: #000;
#drop_zone {
border: 2px dashed #bbb;
-moz-border-radius: 5px;
-webkit-border-radius: 5px;
border-radius: 5px;
padding: 25px;
text-align: center;
font: 20pt bold 'Vollkorn';
color: #bbb;
.report { display: table; }
.reportRow { display: table-row; }
.reportCell { display: table-cell; }
.reportRow:hover{
background-color:#bababa;
.d3-tip {
line-height: 110%;
font-weight: bold;
font-size: x-small;
padding: 12px;
background: rgba(0, 0, 0, 0.8);
color: #fff;
border-radius: 2px;
/* Creates a small triangle extender for the tooltip */
.d3-tip:after {
box-sizing: border-box;
display: inline;
font-size: 10px;
width: 100%;
line-height: 1;
color: rgba(0, 0, 0, 0.8);
content: "\25BC";
position: absolute;
text-align: center;
/* Style northward tooltips differently */
.d3-tip.n:after {
margin: -1px 0 0 0;
top: 100%;
left: 0;
</style>
<div style="color: #999; margin-top: 10px;">Instructions for use (version 0.5):
<li>Drop a .map file onto the drop-zone to analyze. Refresh page to do another file.</li>
<li>Mouse-over will show details</li>
<li>Click on scatter-plot will zoom in on RAM+Flash treemap</li>
<li>Click on treemap-node will zoom in on module. Click again or outside to zoom out.</li>
<li>Tested with EWARM 7.30.3/4</li>
</div>
<div id="drop_zone" style="width: 400px; margin-top: 20px;}">Drop .map-file here</div>
<output id="list" style='{visibility: hidden;}'></output>
<script>
var modules = {"name": "Total", "children": []};
var modulesRam = {"name": "Total", "children": []};
var modulesFlash = {"name": "Total", "children": []};
var modulesRom = {"name": "Total", "children": []};
var modulesSpecial = {"name": "Total", "children": []};
function displayContents(contents) {
// For-now abandoned project of allowing a 2nd dropped file.
lines = contents.split('\n');
var i = 0, l;
var searchFor = '*** ENTRY LIST';
var searchState = 0;
for (i; l = lines[i]; i++) {
//lines[i] = i + l
if (searchState == 0 && l.indexOf(searchFor) >= 0)
{ searchState = 1; searchFor = '-----' }
if (searchState == 1 && l.indexOf(searchFor) >= 0)
{ break; }
i += 1;
var output = ''
var ret = [];
// i contains starting point for entry list.
// Continuation line holder
var cl = ''
// Process each line
// Terminate on empty-ish line
if (l.length < 4) { break; }
l = cl + l
cl = ''
items = l.match(/([.a-zA-Z\{\}\/\$0-9_-]((?=\s[^\s\[])\s)?)+/g)
if (items.length < 2)
cl = l;
continue;
if (items.length < 7)
items.splice(2, 0, "0x0");
// If it's one of the weird linker-created entries which are spread across entries.
var weirdType = ''
if (items[0].indexOf('$$') > -1 ) {
items[0] = items[0].split('$$')
weirdType =items[0][items[0].length-1]; // Base, Length, Limit
items[0] = items[0].slice(0, -1).join('$$') // Remove qualifier
if (weirdType == 'Length') { continue; } // Ignore linker-created length entry.
var entry = {"name": items[0],
"address": items[1],
"size": parseInt(items[2]),
"type": items[3],
"gblc": items[4],
"object": items[5],
"objref": items[6],
// Find memory type from address space
if (entry.address.indexOf('0x2')>=0) {entry.memory = 'RAM';}
else if (entry.address.indexOf('0x1')>=0) {entry.memory = 'ROM';}
else if (entry.address.indexOf('0x0')>=0) {entry.memory = 'Flash';}
else {entry.memory = 'Special';}
// Save it in a global thing, why not.
ret.push(entry);
// Pre-filter by Flash and RAM here to save on run-time. Also this is easier, if more imperative in style.
if (entry.memory == 'Flash') modules = modulesFlash;
else if (entry.memory == 'RAM') modules = modulesRam;
else if (entry.memory == 'ROM') modules = modulesRom;
else modules = modulesSpecial;
// Stupid way to bin the entries based on object-file. Check if bin exists.
var moduleEntries = modules.children.filter(function( obj ) {
return obj.name == entry.object;
// If not, length of filtered array is > 0.
if ( moduleEntries.length > 0 )
// For the weird entries like CSTACK we check if the item alerady exists
var existingEntry = moduleEntries[0].children.filter( function(o) { return o.name == entry.name });
if (existingEntry.length)
// Since all other entries are unique, parse the linker-created entries into one.
// The first one is always base. So if this is Limit, calculate size of existing.
if (weirdType == 'Limit') { existingEntry[0].size = parseInt(entry.address)-parseInt(existingEntry[0].address)};
else
moduleEntries[0].children.push(entry);
else
// Add a parent item. This is e.g. main.o.
modules.children.push( {"name": entry.object, "size":0, "children":[entry]} );
if (items)
//output += items.join('| ::: |') + '\n';
//output = JSON.stringify(modulesRam);
treeFile(modulesFlash, 'Flash');
treeFile(modulesRam, 'RAM');
var output = '<div class="report">'+ recurseSizeReport(modulesRam, 0) + '</div>';
ramReport = document.getElementById("RamReport");
ramReport.innerHTML = output;
var output = '<div class="report">'+ recurseSizeReport(modulesFlash, 0) + '</div>';
flashReport = document.getElementById("FlashReport");
flashReport.innerHTML = output;
// Scatter
var hierarchy = d3.layout.hierarchy()
.value(function(d) { return d.size; });
var nodesRam = hierarchy(modulesRam) //Side-effects modulesRam as well
.filter(function(d) { return d.depth==1; })// Get only modules, not total or entries.
.map(function(d) { return {"name": d.name, "ramSize": d.value, "ramCount": d.children.length, "ramNode": d} });
var nodesFlash = hierarchy(modulesFlash)
.map(function(d) { return {"name": d.name, "flashSize": d.value, "flashCount": d.children.length, "flashNode": d} });
// Merge ram and flash trees on d.name. O(m*n) but at least it's a one-liner.
nodesRam.forEach(function(e,i,a){inFlash = nodesFlash.filter(function(d){return d.name == e.name}); if (inFlash.length) {inFlash[0].ramCount = e.ramCount; inFlash[0].ramSize = e.ramSize; inFlash[0].ramNode = e.ramNode;} else {nodesFlash.push(e)}})
nodesCombined = nodesFlash;
// Fill in blanks for cleaner code later. Map without mapping. Could've used .forEach.
nodesCombined.map(function(d)
if (!d.ramCount) {d.ramCount=0;}
if (!d.ramSize) {d.ramSize=0;}
if (!d.flashSize) {d.flashSize=0;}
if (!d.flashCount) {d.flashCount=0;}
if (!d.flashNode) {d.flashNode=null;}
if (!d.ramNode) {d.ramNode=null;}
return d;
scatter(nodesCombined);
return ret;
function recurseSizeReport(o, s)
var ret = '<div class="reportRow">'
ret += '<div class="reportCell" style="font-size: '+ (14-2*s) +'pt; padding-left: '+ (10*s) +'px;">'
if (o.name) ret += o.name + "";
ret += '</div>'
ret += '<div class="reportCell" style="font-size: '+ (14-2*s) +'pt;">'
if (o.value) ret += o.value;
ret += '</div>'
ret += '</div>'
if (o.children && o.children.length)
for (var i = 0, c; c = o.children[i]; i++)
ret += recurseSizeReport(c, s+1);
return ret;
</script>
<script>
function handleFileSelect(evt) {
evt.stopPropagation();
evt.preventDefault();
var files = evt.dataTransfer.files; // FileList object.
// files is a FileList of File objects. List some properties.
var output = [];
for (var i = 0, f; f = files[i]; i++) {
output.push('<strong>', escape(f.name), '</strong> (', f.type || 'n/a', ') - ',
f.size, ' bytes, last modified: ',
f.lastModifiedDate ? f.lastModifiedDate.toLocaleDateString() : 'n/a',
// Read each file
var reader = new FileReader();
reader.onload = function(e) {
var contents = e.target.result;
displayContents(contents);
dropZone.remove();
document.getElementById('list').style.visibility='visible';
reader.readAsText(f);
document.getElementById('list').innerHTML = '<ul>' + output.join('') + '</ul>';
function handleDragOver(evt) {
evt.dataTransfer.dropEffect = 'copy'; // Explicitly show this is a copy.
// Setup the dnd listeners.
var dropZone = document.getElementById('drop_zone');
dropZone.addEventListener('dragover', handleDragOver, false);
dropZone.addEventListener('drop', handleFileSelect, false);
</script>
<!--textarea id="rawfile" style='{visibility: hidden;}'>
Hello!
</textarea-->
<script src="http://d3js.org/d3.v3.min.js"></script>
<script src="http://labratrevenge.com/d3-tip/javascripts/d3.tip.v0.6.3.js"></script>
<body>
<div id="body">
<!--div id="footer">
d3.layout.treemap
<div class="hint">click or option-click to descend or ascend</div>
<div><select>
<option value="size">Size</option>
<option value="count">Count</option>
</select></div>
</div>
</div-->
<div id="svgScatterTitle" style="display: block; margin-top: 20px; font: 2em sans-serif;">Ram vs Flash vs # elements in object (radius)</div>
<div id="svgScatter"></div>
<div id="svgRamTitle" style="display: block; margin-top: 20px; font: 2em sans-serif;">RAM</div>
<div id="svgRam" class="chart"></div>
<div id="selected_tooltip" class="selected_tooltip"></div>
<div id="svgFlashTitle" style="display: block; margin-top: 20px; font: 2em sans-serif;">Flash</div>
<div id="svgFlash"></div>
<div id="selected_tooltipFlash" class="selected_tooltip"></div>
<div style="display: block; margin-top: 20px; font: 2em sans-serif;">Report</div>
<div style="display: table"></div>
<div style="display: table-cell">
<div style="display: block; margin-top: 10px; font: 1.5em sans-serif;">Ram</div>
<div id="RamReport" style="display: block; margin-top: 5px; font: 1em sans-serif;">RamReport</div>
</div>
<div style="display: table-cell; padding-left: 20px;">
<div style="display: block; margin-top: 10px; font: 1.5em sans-serif;">Flash</div>
<div id="FlashReport" style="display: block; margin-top: 5px; font: 1em sans-serif;">FlashReport</div>
</div>
</div>
<script type="text/javascript">
var selected_tooltip = document.getElementsByClassName("selected_tooltip");
var w = 1280 - 80,
h = 800 - 180,
x = d3.scale.linear().range([0, w]),
y = d3.scale.linear().range([0, h]),
color = d3.scale.category20c(),
root,
node;
var treemapRam = d3.layout.treemap()
.round(false)
.size([w, h])
.sticky(true)
var tipMap = d3.tip()
.attr('class', 'd3-tip')
.offset(function(d) {return [-(25), -document.body.getBoundingClientRect().left]; })
.html(function(d) {
return "<span style='color:lightskyblue; font-size:larger; font-weight: bold;'>" +
d.parent.name + " :: " + d.name + "</span>" +
"<br>" + d.memory + ": " + d.size + " bytes";
var svgRam = d3.select("#svgRam") //d3.select("#body").append("div")
.attr("class", "chart")
.style("width", w + "px")
.style("height", h + "px")
.append("svg:svg")
.attr("width", w)
.attr("height", h)
.append("svg:g")
.attr("transform", "translate(.5,.5)");
svgRam.call(tipMap);
var treemapFlash = d3.layout.treemap()
.round(false)
.size([w, h])
.sticky(true)
var svgFlash = d3.select("#svgFlash") //d3.select("#body").append("div")
.append("svg:svg")
.attr("width", w)
.attr("height", h)
.append("svg:g")
svgFlash.call(tipMap);
var margin = {top: 20, right: 20, bottom: 30, left: 40},
width = 960 - margin.left - margin.right,
height = 500 - margin.top - margin.bottom;
var xS = d3.scale.linear()
.range([0, width]);
var yS = d3.scale.linear()
.range([height, 0]);
var rS = d3.scale.linear()
.range([3.5, 20]);
var colorS = d3.scale.category20c();
var xAxis = d3.svg.axis()
.scale(xS)
.orient("bottom");
var yAxis = d3.svg.axis()
.scale(yS)
.orient("left");
var tipScatter = d3.tip()
.html(function(d) {
return "<span style='color:lightskyblue; font-size:larger; font-weight: bold;'>" + d.name + "</span>"+
"<br>Flash: "+d.flashSize+" bytes / "+d.flashCount+" entries." +
"<br>Ram: "+d.ramSize+" bytes / "+d.ramCount+" entries.";
var svgScatter = d3.select("#svgScatter").append("svg")
.attr("width", width + margin.left + margin.right)
.attr("height", height + margin.top + margin.bottom)
.append("g")
.attr("transform", "translate(" + margin.left + "," + margin.top + ")");
svgScatter.call(tipScatter);
function scatter(data) {
// data.forEach(function(d) {
// d.sepalLength = +d.sepalLength;
// d.sepalWidth = +d.sepalWidth;
svg = svgScatter;
xS.domain(d3.extent(data, function(d) { return d.ramSize; })).nice();
yS.domain(d3.extent(data, function(d) { return d.flashSize; })).nice();
rS.domain(d3.extent(data, function(d) { return d.flashCount + d.ramCount; })).nice();
svg.append("g")
.attr("class", "x axis")
.attr("transform", "translate(0," + height + ")")
.call(xAxis)
.append("text")
.attr("class", "label")
.attr("x", width)
.attr("y", -6)
.style("text-anchor", "end")
.text("Ram usage (b)");
svg.append("g")
.attr("class", "y axis")
.call(yAxis)
.append("text")
.attr("transform", "rotate(-90)")
.attr("y", 6)
.attr("dy", ".71em")
.text("Flash usage (b)")
svg.selectAll(".dot")
.data(data)
.enter().append("circle")
.attr("class", "dot")
.attr("r", function(d) {return rS(d.ramCount + d.flashCount); })
.attr("cx", function(d) { return xS(d.ramSize); })
.attr("cy", function(d) { return yS(d.flashSize); })
.style("fill", function(d) { return color(d.name); })
.on('click', function(d) { if (d.ramNode) {zoom(d.ramNode)}; if (d.flashNode){zoom(d.flashNode)}; })
.on('mouseover', tipScatter.show)
.on('mouseout', tipScatter.hide);
svg.selectAll(".dot").append("title")
.text(function(d) { return d.name; });
// var legend = svg.selectAll(".legend")
// .data(color.domain())
// .enter().append("g")
// .attr("class", "legend")
// .attr("transform", function(d, i) { return "translate(0," + i * 16 + ")"; });
// legend.append("rect")
// .attr("x", width - 18)
// .attr("width", 14)
// .attr("height", 14)
// .style("fill", color);
// legend.append("text")
// .attr("x", width - 24)
// .attr("y", 7)
// .attr("dy", ".35em")
// .style("text-anchor", "end")
// .text(function(d) { return d; });
var nodesFlash;
var nodesRam;
function treeFile(data, memory)
node = root = data;
if (memory == 'RAM')
treemap = treemapRam;
svg = svgRam;
nodesRam = treemap.nodes(root)
.filter(function(d) { return !d.children; });
nodes = nodesRam;
else if (memory == 'Flash')
treemap = treemapFlash;
svg = svgFlash;
nodesFlash = treemap.nodes(root)
nodes = nodesFlash;
var cell = svg.selectAll("g")
.data(nodes)
.enter().append("svg:g")
.attr("class", "cell")
.attr("transform", function(d) { return "translate(" + d.x + "," + d.y + ")"; })
.on("click", function(d) {if (d.memory=='RAM'){root=modulesRam} else {root=modulesFlash}; return zoom(node == d.parent ? root : d.parent); });
cell.append("title")
.text(function(d) { return d.name + ': ' + ((d.size)?(d.size + ' bytes'):0); });
cell.append("svg:rect")
.attr("width", function(d) { return (d.dx - 1)<0?0:(d.dx - 1); })
.attr("height", function(d) { return (d.dy - 1)<0?0:(d.dy - 1); })
.style("fill", function(d) { return color(d.parent.name); })
.on('mouseover', function(d) {
selected_tooltip[0].innerHTML = d.parent.name + "("+d.parent.value+") :: "+d.name+"("+d.value+")";
selected_tooltip[1].innerHTML = d.parent.name + "("+d.parent.value+") :: "+d.name+"("+d.value+")";
tipMap.show(d);
.on('mouseout', tipMap.hide);
cell.append("svg:text")
.attr("x", function(d) { return d.dx / 2; })
.attr("y", function(d) { return d.dy / 2; })
.attr("dy", ".25em")
.attr("text-anchor", "middle")
.style("visibility", "hidden"); /*function(d) { d.w = this.getComputedTextLength(); return d.dx > d.w ? 'visible' : 'hidden'; });*/
d3.select(window).on("click", function() { zoom(modulesFlash); zoom(modulesRam); });
d3.select("select").on("change", function() {
treemap.value(this.value == "size" ? size : count).nodes(root);
zoom(node);
function size(d) {
return d.size;
function count(d) {
return 1;
function recurseAny(o, att, val)
if (o.hasOwnProperty(att) && o[att] == val) return true;
else if (o.children && o.children.length)
if (recurseAny(c, att, val)) return true;
return false;
function zoom(d) {
var kx = w / d.dx, ky = h / d.dy;
x.domain([d.x, d.x + d.dx]);
y.domain([d.y, d.y + d.dy]);
//debugger;
if (recurseAny(d, 'memory', 'RAM'))
svg = svgRam;
else if (recurseAny(d, 'memory', 'Flash'))
svg = svgFlash;
var t = svg.selectAll("g.cell").transition()
.duration(d3.event.altKey ? 750 : 300)
.attr("transform", function(d) { return "translate(" + x(d.x) + "," + y(d.y) + ")"; });
t.select("rect")
.attr("width", function(d) { return (kx * d.dx - 1)>0?(kx * d.dx - 1):0; })
.attr("height", function(d) { return (ky * d.dy - 1)>0?(ky * d.dy - 1):0; })
t.select("text")
.attr("x", function(d) { return kx * d.dx / 2; })
.attr("y", function(d) { return ky * d.dy / 2; })
.style("visibility", function(d) { return kx * d.dx > d.w ? 'visible' : 'hidden'; });
node = d;
d3.event.stopPropagation();
</script>
</body>
Dear Svend:
Thank you , but I see RAM 10~12KB in TI-RTOS.
So I need non-OS sample project in CC2650.
or other solution.
1. use NV memory in Flash. (x)
2. use SPI RAM (OK, but solution is costly and slowly)
3. use cache memory to RAM (no way to do)
Svendbt, Is there any more detaied information available on how the VIMS uses the cache between flash and the cpu? I'm curious how slow instruction of data fetch from flash is compared to average use with the cache, etc. Thanks.
ok.. i dont know if you already done this, but, i will tell you my trick to use 8kb VIMS CACHE as pure RAM:
First:
in your main.c file add the header:
#include "driverlib/vims.h"
and
#define CACHE_RAM_BASE 0x11000000 //address of VIMS GP-RAM
then add:
VIMSModeSet(VIMS_BASE, VIMS_MODE_DISABLED);
before
/* Start BIOS */
BIOS_start();
This will disable VIMS cache and will free you to read/write at the CACHE_RAM_BASE.
To use, include a pointer like uint8_t *ptr = CACHE_RAM_BASE;
And write/read your data from this pointer. after 4 hours looking for this specific information, it works here.
I was needing 16kb (8kb+8kb) of RAM to log data and i use this addr to hold the half of the data for me.
Hope that this code will help you!
PS: im not interested in low power now, so i use:
Power_setConstraint(Power_SB_DISALLOW);
Power_setConstraint(Power_IDLE_PD_DISALLOW);
before the VIMSModeSet(); to let SensorController stay awake too.
I'm interested in memory access times. When you say that there is 1 wait cycle for cache hits and 3 wait cycles for FLASH accesses; Is that read and write? Is a wait cycle a XOSC 48MHz high freequency CPU clock cycle or is it something longer?
Thank you,
Ken
PS Is there a way to force something to stick in the cache so that it always hits.
Kenneth,
The cache RAM has no wait states, while the Flash has 3 (on SCLK_HF / 48 MHz). Memory/peripheral writes are buffered, so (nonblocking) write delay depends on the number of writes in the CPU pipeline and is thus not deterministic.
There is unfortunately no supported way of ensuring that a certain piece of code/data is always cached.
Svend
