Other Parts Discussed in Thread: CC2640, CC2650
Hello friends,
I am using my custom board having CC2640.
I am able to debug as well as program it with SimpleBlePeriphral (default code)
I am able to scan this on my laptop.
But when I compile sensor tag code for CC2640,it is getting compile.
I can download stack and code without any error.
But when I start running application in debug mode it is showing me below warning.
Sat Oct 10, 2015 19:06:51: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 7.2\arm\config\debugger\
Sat Oct 10, 2015 19:06:51: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 7.2\arm\config\flashloader\TexasInstruments\FlashCC26xx.mac
Sat Oct 10, 2015 19:06:51: Connecting to TI XDS100 (Probe no: 06EB12212A94)
Sat Oct 10, 2015 19:06:56: TI XDS ARM, device revision: 0x00000001, big endian: false, cache: false, board revision: 0x00000000, driver revision: 0x0B020200
Sat Oct 10, 2015 19:06:56: Initial reset was performed
Sat Oct 10, 2015 19:06:56: Watchdog disabled
Sat Oct 10, 2015 19:06:56: 544 bytes downloaded (3.77 Kbytes/sec)
Sat Oct 10, 2015 19:06:56: Loaded debugee: C:\Program Files\IAR Systems\Embedded Workbench 7.2\arm\config\flashloader\TexasInstruments\FlashCC26xxRAM20.out
Sat Oct 10, 2015 19:06:56: Target reset
Sat Oct 10, 2015 19:07:00: Unloaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 7.2\arm\config\flashloader\TexasInstruments\FlashCC26xx.mac
Sat Oct 10, 2015 19:07:00: Downloaded C:\ti\simplelink\ble_cc26xx_2_01_00_44423\Projects\ble\SensorTag\CC26xx\IAR\Application\CC2650\FlashOnlyOAD\Exe\SensorTagAppFlashOnlyOAD.out to flash memory.
Sat Oct 10, 2015 19:07:05: Watchdog disabled
Sat Oct 10, 2015 19:07:09: 44305 bytes downloaded into FLASH (3.41 Kbytes/sec)
Sat Oct 10, 2015 19:07:09: Loaded debugee: C:\ti\simplelink\ble_cc26xx_2_01_00_44423\Projects\ble\SensorTag\CC26xx\IAR\Application\CC2650\FlashOnlyOAD\Exe\SensorTagAppFlashOnlyOAD.out
Sat Oct 10, 2015 19:07:09: Target reset
Sat Oct 10, 2015 19:07:18: The stack pointer for stack 'CSTACK' (currently 0x20002DB8) is outside the stack range (0x20004058 to 0x20004458)
