I was reading the wiki article about ZLight and ZStack and luckily it seems that it's possible to use the light with the Philips hub. (at least the headline "Changes Require for a ZStack-Lighitng-1.0.1 Light to be Recognized Correctly by Hue Hub" sounds like it's possible)
In the article it's mentioned that the ZLL device has to be part of a HA network in order to transport the network key encrypted with the HA default trust center link key.
I've managed to join a Philips Hue bulb to my HA network by resetting it before. But the same didn't work for the Philips Hub (aka bridge).
The hub can be resettet fine but it won't scan and join my HA network.
So the big question is how can I join the Philips hue hub to my HA network?
Maybe the hub port 30000 on the bridge could be used to force the bridge to scan?
Two commands for hub port 30000 are known to me:
- [Link,Touchlink] to scan and join ZLL devices
- [Link,Discover] opens the permit join flag for while. I discovered this command by trial and error ;)
best regards,
Manuel
