WiLink 1837MOD support in SDK 7.01
Hi All,
            Is WiLink 1837MOD supported in SDK 7.01?
Rudresh
  • Hi Rudresh,
    Yes, you can find the prebuilt images at: processors.wiki.ti.com/.../WL18xx_AMxxx_Platform_Integration_Guide
    Gigi Joseph.
  • Hi Joseph,
    I need the patch for SDK 7.01 to support. By default DTS entry for Wi-link is not there. Also I think firmware fro 1837 is different .
    So, please guide us
    Rudresh
  • Hi Rudresh,
    The link I sent you contains the patch set that are required. Please check that.
    The firmware is the same.
    Gigi Joseph.
  • Hi Joseph,
    We found that there was a wrong settings for pinmux in SDIO. After doing that we are getting following crash.
    [ 0.000000] Booting Linux on physical CPU 0x0
    [ 0.000000] Linux version 3.12.10-ti2013.12.01 (guardhat1tb@guardhat) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #4 Tue Apr 21 18:43:24 IST 2015
    [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
    [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [ 0.000000] Machine: Generic AM43 (Flattened Device Tree), model: TI AM437x gp EVM
    [ 0.000000] cma: CMA: reserved 24 MiB at ae000000
    [ 0.000000] Memory policy: ECC disabled, Data cache writeback
    [ 0.000000] CPU: All CPU(s) started in SVC mode.
    [ 0.000000] AM437x ES1.0 (sgx neon )
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259856
    [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
    [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [ 0.000000] Memory: 1003132K/1045504K available (5563K kernel code, 558K rwdata, 1868K rodata, 341K init, 224K bss, 42372K reserved, 267264K highmem)
    [ 0.000000] Virtual kernel memory layout:
    [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
    [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
    [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
    [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
    [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
    [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
    [ 0.000000] .text : 0xc0008000 - 0xc074a03c (7433 kB)
    [ 0.000000] .init : 0xc074b000 - 0xc07a07e0 ( 342 kB)
    [ 0.000000] .data : 0xc07a2000 - 0xc082d9e0 ( 559 kB)
    [ 0.000000] .bss : 0xc082d9e0 - 0xc0865bf8 ( 225 kB)
    [ 0.000000] NR_IRQS:16 nr_irqs:16 16
    [ 0.000000] GIC CPU mask not found - kernel will fail to boot.
    [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
    [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
    [ 0.000000] OMAP clocksource: timer1 at 24000000 Hz
    [ 0.000000] Console: colour dummy device 80x30
    [ 0.000399] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
    [ 0.059559] pid_max: default: 32768 minimum: 301
    [ 0.059720] Security Framework initialized
    [ 0.059800] Mount-cache hash table entries: 512
    [ 0.068270] CPU: Testing write buffer coherency: ok
    [ 0.068716] Setting up static identity map for 0xc0574648 - 0xc05746b8
    [ 0.068849] L310 cache controller enabled
    [ 0.068874] l2x0: 16 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x7e030000, Cache size: 256 kB
    [ 0.069752] devtmpfs: initialized
    [ 0.073027] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    [ 0.137457] omap_hwmod: dss_dispc: cannot be enabled for reset (3)
    [ 0.140745] omap_hwmod: dss_rfbi: cannot be enabled for reset (3)
    [ 0.141407] pinctrl core: initialized pinctrl subsystem
    [ 0.142270] regulator-dummy: no parameters
    [ 0.144479] NET: Registered protocol family 16
    [ 0.147169] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [ 0.149990] cpuidle: using governor ladder
    [ 0.150005] cpuidle: using governor menu
    [ 0.163823] L3 debug error: target 13 clkdm 1 (unclearable)
    [ 0.163869] L3 application error: target 13 clkdm 1 (unclearable)
    [ 0.164127] platform 49000000.edma: FIXME: clock-name 'fck' DOES NOT exist in dt!
    [ 0.167129] OMAP GPIO hardware version 0.1
    [ 0.176950] platform 56000000.sgx: FIXME: clock-name 'fck' DOES NOT exist in dt!
    [ 0.178955] platform ocp2scp.0: FIXME: clock-name 'fck' DOES NOT exist in dt!
    [ 0.179260] platform ocp2scp.1: FIXME: clock-name 'fck' DOES NOT exist in dt!
    [ 0.179678] platform 48380000.omap_dwc3_1: FIXME: clock-name 'fck' DOES NOT exist in dt!
    [ 0.180057] platform 483c0000.omap_dwc3_2: FIXME: clock-name 'fck' DOES NOT exist in dt!
    [ 0.180398] platform 4832a000.dss: FIXME: clock-name 'fck' DOES NOT exist in dt!
    [ 0.180768] platform 4832a400.dispc: FIXME: clock-name 'fck' DOES NOT exist in dt!
    [ 0.181341] platform 4832a800.rfbi: FIXME: clock-name 'fck' DOES NOT exist in dt!
    [ 0.183550] No ATAGs?
    [ 0.183574] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    [ 0.183586] hw-breakpoint: maximum watchpoint size is 4 bytes.
    [ 0.210843] bio: create slab <bio-0> at 0
    [ 0.227488] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
    [ 0.228455] vmmcsd_fixed: 3300 mV
    [ 0.229030] vmmcwl_fixed: 1800 mV
    [ 0.229473] evm_v3p3: 3300 mV
    [ 0.233056] vgaarb: loaded
    [ 0.234418] SCSI subsystem initialized
    [ 0.235926] usbcore: registered new interface driver usbfs
    [ 0.236153] usbcore: registered new interface driver hub
    [ 0.236384] usbcore: registered new device driver usb
    [ 0.237334] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c0_pins, deferring probe
    [ 0.237365] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral
    [ 0.237629] media: Linux media interface: v0.10
    [ 0.237823] Linux video capture interface: v2.00
    [ 0.238135] pps_core: LinuxPPS API ver. 1 registered
    [ 0.238147] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.238295] PTP clock support registered
    [ 0.241102] Switched to clocksource timer1
    [ 0.262253] NET: Registered protocol family 2
    [ 0.262847] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [ 0.263045] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.263152] TCP: Hash tables configured (established 8192 bind 8192)
    [ 0.263294] TCP: reno registered
    [ 0.263310] UDP hash table entries: 512 (order: 1, 8192 bytes)
    [ 0.263346] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
    [ 0.263597] NET: Registered protocol family 1
    [ 0.263979] RPC: Registered named UNIX socket transport module.
    [ 0.263994] RPC: Registered udp transport module.
    [ 0.264002] RPC: Registered tcp transport module.
    [ 0.264009] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 0.264922] NetWinder Floating Point Emulator V0.97 (double precision)
    [ 0.265591] PM: Loading am335x-pm-firmware.binbounce pool size: 64 pages
    [ 0.420483] VFS: Disk quotas dquot_6.5.2
    [ 0.420546] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [ 0.421180] NFS: Registering the id_resolver key type
    [ 0.421250] Key type id_resolver registered
    [ 0.421262] Key type id_legacy registered
    [ 0.421303] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
    [ 0.421505] msgmni has been set to 1485
    [ 0.423282] NET: Registered protocol family 38
    [ 0.423327] io scheduler noop registered
    [ 0.423337] io scheduler deadline registered
    [ 0.423361] io scheduler cfq registered (default)
    [ 0.424115] omap-ocp2scp ocp2scp.0: invalid resource
    [ 0.424150] omap-ocp2scp: probe of ocp2scp.0 failed with error -22
    [ 0.424635] omap-ocp2scp ocp2scp.1: invalid resource
    [ 0.424663] omap-ocp2scp: probe of ocp2scp.1 failed with error -22
    [ 0.427888] pinctrl-single 44e10800.pinmux: 199 pins at pa f9e10800 size 796
    [ 0.433270] OMAP DSS rev 2.0
    [ 0.438066] omapfb omapfb: no displays
    [ 0.438149] omapfb omapfb: failed to setup omapfb
    [ 0.438173] platform omapfb: Driver omapfb requests probe deferral
    [ 0.440452] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [ 0.443285] omap_uart 44e09000.serial: No clock speed specified: using default:48000000
    [ 0.443576] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 104, base_baud = 3000000) is a OMAP UART0
    [ 1.184581] console [ttyO0] enabled
    [ 1.188943] omap_uart 48022000.serial: No clock speed specified: using default:48000000
    [ 1.197784] omap_uart 48022000.serial: [UART-1]: failure [serial_omap_probe]: -22
    [ 1.205845] omap_uart: probe of 48022000.serial failed with error -22
    [ 1.213843] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
    [ 1.231849] brd: module loaded
    [ 1.240701] loop: module loaded
    [ 1.244440] (stk) :sysfs entries created
    [ 1.248655] (stk) : debugfs entries created
    [ 1.256677] mtdoops: mtd device (mtddev=name/number) must be supplied
    [ 1.268201] usbcore: registered new interface driver asix
    [ 1.274244] usbcore: registered new interface driver ax88179_178a
    [ 1.280954] usbcore: registered new interface driver cdc_ether
    [ 1.287361] usbcore: registered new interface driver r815x
    [ 1.293448] usbcore: registered new interface driver smsc95xx
    [ 1.299790] usbcore: registered new interface driver net1080
    [ 1.305999] usbcore: registered new interface driver cdc_subset
    [ 1.312513] usbcore: registered new interface driver zaurus
    [ 1.318719] usbcore: registered new interface driver cdc_ncm
    [ 1.325300] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 1.332294] ehci-pci: EHCI PCI platform driver
    [ 1.337263] ehci-omap: OMAP-EHCI Host Controller driver
    [ 1.343947] usbcore: registered new interface driver cdc_wdm
    [ 1.350222] usbcore: registered new interface driver usb-storage
    [ 1.357878] mousedev: PS/2 mouse device common for all mice
    [ 1.366308] i2c /dev entries driver
    [ 1.370730] Driver for 1-wire Dallas network protocol.
    [ 1.378946] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [ 1.388515] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
    [ 1.395821] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
    [ 1.403545] Unable to handle kernel NULL pointer dereference at virtual address 00000004
    [ 1.412169] pgd = c0004000
    [ 1.415049] [00000004] *pgd=00000000
    [ 1.418864] Internal error: Oops: 5 [#1] ARM
    [ 1.423410] Modules linked in:
    [ 1.426672] CPU: 0 PID: 4 Comm: kworker/0:0 Not tainted 3.12.10-ti2013.12.01 #4
    [ 1.434466] task: ed087080 ti: ed094000 task.ti: ed094000
    [ 1.440231] PC is at process_one_work+0x24/0x33c
    [ 1.445150] LR is at worker_thread+0x128/0x384
    [ 1.449884] pc : [<c00595e4>] lr : [<c0059cb8>] psr: 400001d3
    [ 1.449884] sp : ed095ef8 ip : ed095f38 fp : ed095f34
    [ 1.462110] r10: 00000009 r9 : c07f6264 r8 : ed07add8
    [ 1.467672] r7 : c07f6274 r6 : 00000000 r5 : c07f6264 r4 : ed07adc0
    [ 1.474622] r3 : 00000000 r2 : 00000001 r1 : ed25fbd0 r0 : ed07adc0
    [ 1.481575] Flags: nZcv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
    [ 1.489544] Control: 10c53c7d Table: 80004059 DAC: 00000017
    [ 1.495662] Process kworker/0:0 (pid: 4, stack limit = 0xed094240)
    [ 1.502243] Stack: (0xed095ef8 to 0xed096000)
    [ 1.506884] 5ee0: c0058240 ed07adc0
    [ 1.515599] 5f00: c07f6264 ed094000 c07f6274 ed07adc0 c07f6264 ed094000 c07f6274 ed07add8
    [ 1.524312] 5f20: c07f6264 00000009 ed095f64 ed095f38 c0059cb8 c00595cc ed087080 ed089de8
    [ 1.533025] 5f40: 00000000 ed07adc0 c0059b90 00000000 00000000 00000000 ed095fac ed095f68
    [ 1.541738] 5f60: c005f74c c0059b9c 042ac892 00000000 c0171205 ed07adc0 00000000 ed095f7c
    [ 1.550451] 5f80: ed095f7c 00000000 ed095f88 ed095f88 ed089de8 c005f6a0 00000000 00000000
    [ 1.559163] 5fa0: 00000000 ed095fb0 c0014238 c005f6ac 00000000 00000000 00000000 00000000
    [ 1.567875] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 1.576588] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 1531bc60 08414844
    [ 1.585292] Backtrace:
    [ 1.587911] [<c00595c0>] (process_one_work+0x0/0x33c) from [<c0059cb8>] (worker_thread+0x128/0x384)
    [ 1.597555] [<c0059b90>] (worker_thread+0x0/0x384) from [<c005f74c>] (kthread+0xac/0xb8)
    [ 1.606191] [<c005f6a0>] (kthread+0x0/0xb8) from [<c0014238>] (ret_from_fork+0x14/0x3c)
    [ 1.614715] r7:00000000 r6:00000000 r5:c005f6a0 r4:ed089de8
    [ 1.620768] Code: e590202c e2136004 13c360ff e3120080 (e5963004)
    [ 1.627287] ---[ end trace 964d8a45bb51f2df ]---
    [ 1.632281] mmc0: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 0 timing 0
    [ 1.640702] Unable to handle kernel paging request at virtual address fffffff0
    [ 1.648395] pgd = c0004000
    [ 1.651275] [fffffff0] *pgd=adff2821, *pte=00000000, *ppte=00000000
    [ 1.657965] Internal error: Oops: 17 [#2] ARM
    [ 1.662601] Modules linked in:
    [ 1.665860] CPU: 0 PID: 4 Comm: kworker/0:0 Tainted: G D 3.12.10-ti2013.12.01 #4
    [ 1.674672] task: ed087080 ti: ed094000 task.ti: ed094000
    [ 1.680424] PC is at kthread_data+0x10/0x18
    [ 1.684882] LR is at wq_worker_sleeping+0x14/0xbc
    [ 1.689893] pc : [<c005f958>] lr : [<c005a5c8>] psr: 200001d3
    [ 1.689893] sp : ed095b78 ip : ed095b88 fp : ed095b84
    [ 1.702118] r10: c07f6c70 r9 : ed087160 r8 : ed087160
    [ 1.707681] r7 : ed094000 r6 : c07f6c70 r5 : 00000000 r4 : ed0871dc
    [ 1.714631] r3 : 00000000 r2 : 00002e7b r1 : 00000000 r0 : ed087080
    [ 1.721583] Flags: nzCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment user
    [ 1.729367] Control: 10c53c7d Table: 80004059 DAC: 00000015
    [ 1.735484] Process kworker/0:0 (pid: 4, stack limit = 0xed094240)
    [ 1.742064] Stack: (0xed095b78 to 0xed096000)
    [ 1.746704] 5b60: ed095b9c ed095b88
    [ 1.755418] 5b80: c005a5c8 c005f954 ed0871dc ed087080 ed095c34 ed095ba0 c056f5e4 c005a5c0
    [ 1.764131] 5ba0: ed080440 00000000 ed095be4 ed095bb8 c005c06c c008a428 ed095bec c056fa5c
    [ 1.772845] 5bc0: c032b1d0 ed087080 ed07f700 c082f198 c082f180 ed081040 ed07f700 c082f198
    [ 1.781557] 5be0: ed095c04 ed095bf0 c0044f34 c00cb328 ed094000 ed087080 ed095c44 ed095c08
    [ 1.790271] 5c00: c004714c c008a428 c0097c7c ed087080 00000001 ed087078 ed087a40 ed087160
    [ 1.798984] 5c20: ed087160 ed094000 ed095c44 ed095c38 c056fa5c c056f3b8 ed095c7c ed095c48
    [ 1.807697] 5c40: c0048290 c056fa30 c082dc04 00000001 ed087160 ed095c5c 00000001 ed095c5c
    [ 1.816410] 5c60: ed095c5c ed0871a8 c0046ab8 0000000b ed095d04 ed095c80 c00178ec c0047cfc
    [ 1.825123] 5c80: ed094240 0000000b 00000000 ed095eb0 00000000 00000008 c00595e8 600001d3
    [ 1.833836] 5ca0: 65000005 32303935 20633230 33313265 34303036 63333120 66303633 33652066
    [ 1.842549] 5cc0: 30303231 28203038 36393565 34303033 c0002029 c056b160 c06eab00 00000000
    [ 1.851262] 5ce0: 00000004 00000005 ed095eb0 ed07add8 00000005 ed087080 ed095d1c ed095d08
    [ 1.859975] 5d00: c056a6cc c001760c ed095eb0 00000004 ed095dbc ed095d20 c05724a8 c056a67c
    [ 1.868688] 5d20: c05727dc c07b5370 00000003 00000003 00000000 00000002 00000000 c07f5e80
    [ 1.877401] 5d40: ed095d5c ed095d50 c007df14 c007de5c ed095d84 ed095d60 c0034770 c007df08
    [ 1.886113] 5d60: c07b5370 00000003 00000003 00000000 00000002 00000000 ed095dac ed095d88
    [ 1.894826] 5d80: c0039ffc c0034754 c07b5370 00000000 c082ecd8 ed095eb0 00000005 00000004
    [ 1.903538] 5da0: ed095eb0 ed07add8 c07f6264 00000009 ed095ddc ed095dc0 c05726d8 c05722f4
    [ 1.912251] 5dc0: 00000004 00000005 c07ae5c4 00000004 ed095dfc ed095de0 c0572788 c0572680
    [ 1.920964] 5de0: 00000005 c07ae5c4 00000004 ed095eb0 ed095eac ed095e00 c00085b4 c05726f0
    [ 1.929677] 5e00: 27e5a26e 00000000 ed087080 c07f6c70 ed0870b0 00000001 ed07add8 c07f6c70
    [ 1.938390] 5e20: ed095e5c ed095e30 c006a834 c0069d64 c006a6c4 ed1edaf0 ffffffff c07ad3b0
    [ 1.947103] 5e40: ed095e74 ed095e50 c05727dc c000a50c ffffffff ed1ee01c ed087080 00000017
    [ 1.955816] 5e60: 155e62df 00000001 ed095e8c ed095e78 ffffffff 00000000 ed087080 c07f6c70
    [ 1.964529] 5e80: ed095f24 ed095e90 c056f550 c00595e4 400001d3 ffffffff ed095ee4 ed07add8
    [ 1.973241] 5ea0: ed095f34 ed095eb0 c0570a60 c0008584 ed07adc0 ed25fbd0 00000001 00000000
    [ 1.981955] 5ec0: ed07adc0 c07f6264 00000000 c07f6274 ed07add8 c07f6264 00000009 ed095f34
    [ 1.990668] 5ee0: ed095f38 ed095ef8 c0059cb8 c00595e4 400001d3 ffffffff c0058240 ed07adc0
    [ 1.999381] 5f00: c07f6264 ed094000 c07f6274 ed07adc0 c07f6264 ed094000 c07f6274 ed07add8
    [ 2.008094] 5f20: c07f6264 00000009 ed095f64 ed095f38 c0059cb8 c00595cc ed087080 ed089de8
    [ 2.016807] 5f40: 00000000 ed07adc0 c0059b90 00000000 00000000 00000000 ed095fac ed095f68
    [ 2.025520] 5f60: c005f74c c0059b9c 042ac892 00000000 c0171205 ed07adc0 00000000 ed095f7c
    [ 2.034232] 5f80: ed095f7c 00000001 ed095f88 ed095f88 ed089de8 c005f6a0 00000000 00000000
    [ 2.042945] 5fa0: 00000000 ed095fb0 c0014238 c005f6ac 00000000 00000000 00000000 00000000
    [ 2.051657] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 2.060369] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 1531bc60 08414844
    [ 2.069073] Backtrace:
    [ 2.071691] [<c005f948>] (kthread_data+0x0/0x18) from [<c005a5c8>] (wq_worker_sleeping+0x14/0xbc)
    Rudresh
  • Hi Joseph,
    In the DTS entry following are for edma channels allocation.
    &mmc3 {
    status = "okay";
    /* these are on the crossbar and are outlined in the
    xbar-event-map element */
    dmas = <&edma 32
    &edma 33>;
    dma-names = "tx", "rx";
    vmmc-supply = <&vmmcwl_fixed>;
    bus-width = <4>;
    pinctrl-names = "default", "sleep";
    pinctrl-0 = <&mmc3_pins_default>;
    pinctrl-1 = <&mmc3_pins_sleep>;
    cap-power-off-card;
    keep-power-in-suspend;
    ti,non-removable;
    How the edma values are configured as 32 and 33. This is for am437xx for Wilink SDIO interface.
    Rudresh
