Changing booting (entry) point of cc3200 ti-rtos application in IAR
Other Parts Discussed in Thread: CC3200
Hi
I am working on cc3200 with code composer studio IDE, To check the code size optimization on different compilers I ported my application to IAR and compiled it successfully.
Requirement: We are using second stage bootloader which loads the ti-rtos application to SRAM, at address location of 0x2000e001 .
To make it working in CCS IDE we have changed the application's linker files as follows...
1) CC3200_LP.cmd
#define RAM_BASE 0x2000D000
/* System memory map */
MEMORY
    /* Application uses internal RAM for program and data */
    SRAM (RWX) : origin = 0x2000D000, length =0x00043000
/* Section allocation in memory */
SECTIONS
    .intvecs:   > RAM_BASE
    .boot : > 0x2000E000
    -l"C:\TI\tirtos_simplelink_2_01_00_03\products\bios_6_40_03_39\packages\ti\targets\arm\rtsarm\lib\boot.aem4"<boot.oem4>(.text)
    .text   :   > SRAM
    .const  :   > SRAM
    .cinit  :   > SRAM
    .pinit  :   > SRAM
    .init_array : > SRAM
    .vtable :   > SRAM
    .data   :   > SRAM
    .bss    :   > SRAM
    .sysmem :   > SRAM
    .stack  :   > SRAM
__STACK_TOP = __stack + __STACK_SIZE;
2) linker.cmd (inside Release/configPkg)
SECTIONS
    .bootVecs:  type = DSECT
    .vecs: load > 0x2000d000, type = DSECT
    .resetVecs: load > 0x2000d000
    xdc.meta: type = COPY
This is working Fine, Similarly I tried to apply the changes in icf file, but I couldn't make it working and I am new to IAR workbench.
I was able to change the reset vector location, but I couldn't find where to change the boot location of application.
Could you guys help in solving jumping to entry point issue.
