Sample Code for Application Note AN069 Low Cost Long Range One Way Audio Communication
Other Parts Discussed in Thread: CC1101, MSP430F2232
Would be grateful to all who could point me to the link for the sample source code for: Application Note AN069 Low Cost, Long Range One Way Audio Communication at 900 MHz.
Thank you, sorry if this is obvious, I've browsed about the TI site, but maybe I've overlooked...Thanks
Also would be grateful to other communications code suggestions or links relating to the application of the MPS430F2232 / F2274 and the CC1101  Thanks
    Go to http://www.ti.com and type AN069 in the Keyword Search box.  This will take you to a page with the search results, of which a link to the Technical Document of AN069 exists.  At that link you will find both the PDF file and a ZIP file.  The ZIP file contains the software associated with that Application Note.
    Although a MSP430F2232 / CC1101 platform is not specifically supported in SimpliciTI, there is support for a varient of the MSP430 and CC1101 in this protocol stack that you may want to consider.
  • is there an EVAL Kit for this, based on the SWRA237 app note?  How may I obtain a working demonstration?
