Hi there,
I would like to use the RF430FRL152H in "Infinite Sampling" mode. Hence, I have set the bit in the interrupt control register. Unfortunately, when setting the Start bit in the firmware control register, the samples do not seem to update. I have tried to play with other settings (e.g. sample frequency, number of passes,...) without effect.
Using the "polled" mode by setting the start bit, waiting for sampling and reading the result works as expected.
So what do I have to consider when using the "Infinite Sampling" mode? I'd like to just read the sample storage periodically, without having to trigger a conversion every time...
Best regards
Benjamin
