I was talking about antenna diversity at this forum. (See URL below)
e2e.ti.com/.../2107862
Since the previous thread has become long, I make a new thread.
As for this problem, additional questions came from my customers.
Could you give me advice?
1, You answered that Antenna Diversity worked with CC1310EMK without problems, but did you use the whip antenna?
Or did you use the PCB antenna?
2, The antenna control signal when receiving search is toggled at 360 u second.
I feel that time is short for measuring power with each antenna, but is it the expected behavior? Or is it mis-coding?
3, Do I have to set preamble settings to the same value for both transmitter and receiver?
Is the setting of nPreamBytes in CMD_PROP_RADIO_DIV_SETUP related to the preamble on the receiving side too?
I appreciate your response.
Miyashiro
