Step by step for flashing html website
Other Parts Discussed in Thread: UNIFLASH, CC3200, CC3200SDK, CC3100
Hi all,
I have been looking around to flash html webpages for cc3200 using uniflash to the cc3200 serial flash. I want to create something similar to that of AP provisioning demo.
I have found some resources asked by previous people but after reading it, im still not as clear. Could anyone provide a step by step process ? Right now. this is my understanding.
1. make an html webpage
2. flash it to the serial flash using uniflash ( for this step, I am not sure what to do, like where do i get a .bin file ? also, where is the .ucf file ? and how do i target it to the www/ folder within the serial flash ? [Could anyone please provide me some insight ? ive read the documents online including the programmers guide and am still a little confused]
3. Modify ccs file ( I used the http server demo In which I modify contents displayed on the html webpage)
regards,
Dennis
  • Hi Dennis,
    Regarding Uniflash, see this wiki. processors.wiki.ti.com/.../CC31xx_&_CC32xx_UniFlash_Quick_Start_Guide
    If you are using httpserver as base for your development, open at Uniflash this .ucf file C:\ti\CC3200SDK_1.1.0\cc3200-sdk\example\httpserver\html\httpserver.ucf. You can then overwrite the existing webpage, with your webpage.
    .bin file can be found at Release folder at your project in your CCS workspace. Example "C:\CC3200SDKV110Workspace\httpserver\Release\httpserver.bin."
    - kel
  • Hi Kel,
    Thanks for the quick response, I understand that I can overwrite it, however, my question is that for example, The Provisioning ap demo code, it has its own set of html and .ucf and template etc, how do I go about creating those ? or is it better to just modify those and flash it into the serial flash ?
    Also, to my understanding, .bin file is generated from the ccs compiled file is that correct ? thus in theory, if I overwrote the html file in the httpserver with the html file from Provisioning ap. When I run the httpserver demo, the html should in theory be the one from the httpserver but with contents misplaced as the .bin file was generated for the html for httpserver ?
    warm regards,
    Dennis
  • Hi Dennis,
    If your new to this I suggest you try modifying those webpages and flash them to Serial Flash using Uniflash.
    See, HTTP Server->Default Web Page section of CC3100\CC3200 SimpleLink™ Wi-Fi® Network Processor Subsystem Programmer's Guide to get understanding about this.
    - kel
