HI
I am trying to include the certificate to the example code for cc3200 on "mqtt client "
am unable to connect to broker please help me
help me in including the certificate to mqtt client example on cc3200
HI
The CC3200-SDK’s MQTT-Client application establishes a non-secure connection w/ IBM’s broker, and now let's assume that you need to change the configuration to establish a secure connection w/ your server using the private key file, certificate file and CA file. Please modify ‘connect_config’ as explained below.
/* connection configuration */
connect_config usr_connect_config[] =
                SL_MQTT_NETCONN_URL | SL_MQTT_NETCONN_SEC,
                SERVER_ADDRESS,
                PORT_NUMBER,
                <method to tcp secured socket>,
                <cipher to tcp secured socket>,
                <number of files for secure transfer>, /* 3 'coz of the above assumption */
                security_file_list  /* See ‘security_file_list’ below */
            SERVER_MODE,
            true,
        NULL,
        "user1",
        <user-name>,
        <password>,
        true,
        KEEP_ALIVE_TIMER,
        {Mqtt_Recv, sl_MqttEvt, sl_MqttDisconnect},
        TOPIC_COUNT,
        {TOPIC1, TOPIC2, TOPIC3},
        {QOS2, QOS2, QOS2},
        {WILL_TOPIC,WILL_MSG,WILL_QOS,WILL_RETAIN},
        false
char *security_file_list[] = {“/cert/clientkey.der”, “/cert/clientcert.der”, "/cert/cacert.der"};
-/Praneet
