Other Parts Discussed in Thread: CC3200
We use the CC3200MOD on three different products. It happened more than a dozen times that after working properly for some time the CC3200 module on all three boards suddenly ceased to auto connect to router at power up, or ceased to be provisioned, or ceased to be reprogrammed, or reformatted.
Some times a board cannot work properly anymore after being reformatted and reprogrammed with the same image. Some time a board cannot be reprogrammed. Some times a board that has been working for a while suddenly cannot auto connect after power up; attempts to re-provision it failed.
We don't know why. When we remove the CC3200 from the board and solder a new one in, the problem goes away.
I don’t imagine it is a problem that CC3200 inherently has, because otherwise with such a high failure rate CC3200 would not survive in the industry. I would like to know if you can shed light on what could cause that to happen. Would programming tool, programming script, or our software code itself cause these kind of problems?
A few more details:
* In the lab, we rewired the CC3200MOD launch pad to program the CC3200 on our boards. In one instant, we identify one of them became bad and corrupted whatever CC3200 it tried to program -- that CC3200 were not useful anymore. In production we use the TI board http://www.ti.com/tool/cc31xxemuboost. We haven’t produced enough to see problems.
* We do have solder joint problems underneath the CC3200MOD in production and conceivably when manually soldered in the lab. In those case we could see the CC3200 wasn't working immediately. But our question is regarding to a board that is working for a while suddenly loses some wifi functionality.
In other words, if you can help us look into it that will be appreciated. This problem is bothering us.
Thank you!
Tony
