Tool/software: TI-RTOS
Using the example application in the demo folder (local_time in SDK 1.60.00.04), I was able to retrieve NTP time successfully. However my MQTT secure connection does not work due to connection failure to broker. It works fine if I use my old NTP code, which makes me believe that the clock sync is not setting the date & time properly.
Debugging the clock_sync library shows that the date_time structure accepts Month in 0 to 11 and the year is the number of years after 1900 as opposed to the earlier version where the month and year is adjusted in code. Moreover I was also unable to recompile the clock_sync library.
Appreciate if someone can urgently look into this issue.
