I am using kernel 3.16.5 backport with R8.6 for Wi-Fi and using BlueZ for BT.
During startup, I have script to enable BT and issue "hciattach" command without any issues but Wi-Fi has issue. From time to time, while loading BT firmware (bts file), Wi-Fi get disconnected from mmc2. Reboot usually solved it but I need to understand what could caused this and how to fix it. Attached log. Thanks.
AT91Bootstrap 3.6.1-00078-g5415d4e (Tue Feb 4 15:36:46 CET 2014)
NAND: ONFI flash detected
NAND: Manufacturer ID: 0x2c Chip ID: 0x34
NAND: Disable On-Die ECC
NAND: Initialize PMECC params, cap: 0x4, sector: 0x200
NAND: Image: Copy 0x80000 bytes from 0x40000 to 0x26f00000
NAND: Done to load image
U-Boot 2013.07 (Feb 04 2014 - 15:36:32)
CPU: SAMA5D31
Crystal frequency: 12 MHz
CPU clock : 528 MHz
Master clock : 132 MHz
DRAM: 256 MiB
NAND: 512 MiB
MMC: mci: 0, mci: 1
In: serial
Out: serial
Err: serial
Net: miiphy_register: non unique device name 'macb0'
macb0
Warning: failed to set MAC address
, macb0
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x180000, size 0x86b2
34482 bytes read: OK
NAND read: device 0 offset 0x200000, size 0x384028
3686440 bytes read: OK
Kernel image @ 0x22000000 [ 0x000000 - 0x384028 ]
## Flattened Device Tree blob at 21000000
Booting using the fdt blob at 0x21000000
Loading Device Tree to 2bb0f000, end 2bb1a6b1 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.16.5-sama5-armv7-r8 (root@john-test) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ) #10 Mon Oct 26 16:15:58 PDT 2015
[ 0.000000] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=50c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: SAMA5D3 Xplained
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] AT91: Detected soc type: sama5d3
[ 0.000000] AT91: Detected soc subtype: sama5d31
[ 0.000000] AT91: sram at 0x300000 of 0x20000 mapped at 0xfef58000
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyS0,115200 mem=256M mmcrootfstype=ext4 root=/dev/mmcblk0p2 r rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 254088K/262144K available (3489K kernel code, 212K rwdata, 1556K rodata, 152K init, 171K bss, 8056K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf800000 - 0xc0000000 ( 8 MB)
[ 0.000000] .text : 0xc0008000 - 0xc04f570c (5046 kB)
[ 0.000000] .init : 0xc04f6000 - 0xc051c2e4 ( 153 kB)
[ 0.000000] .data : 0xc051e000 - 0xc05530c0 ( 213 kB)
[ 0.000000] .bss : 0xc05530c0 - 0xc057de60 ( 172 kB)
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 21474836480000000ns
[ 0.000000] Console: colour dummy device 80x30
[ 0.050000] Calibrating delay loop... 351.43 BogoMIPS (lpj=1757184)
[ 0.060000] pid_max: default: 32768 minimum: 301
[ 0.060000] Security Framework initialized
[ 0.060000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060000] CPU: Testing write buffer coherency: ok
[ 0.060000] Setting up static identity map for 0x203479f0 - 0x20347a3c
[ 0.060000] devtmpfs: initialized
[ 0.060000] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[ 0.060000] pinctrl core: initialized pinctrl subsystem
[ 0.060000] regulator-dummy: no parameters
[ 0.080000] NET: Registered protocol family 16
[ 0.080000] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.080000] cpuidle: using governor ladder
[ 0.080000] cpuidle: using governor menu
[ 0.090000] No ATAGs?
[ 0.090000] AT91: Power Management
[ 0.090000] gpio-at91 fffff200.gpio: at address fefff200
[ 0.100000] gpio-at91 fffff400.gpio: at address fefff400
[ 0.100000] gpio-at91 fffff600.gpio: at address fefff600
[ 0.100000] gpio-at91 fffff800.gpio: at address fefff800
[ 0.100000] gpio-at91 fffffa00.gpio: at address fefffa00
[ 0.100000] pinctrl-at91 ahb:apb:pinctrl@fffff200: initialized AT91 pinctrl driver
[ 0.150000] at_hdmac ffffe600.dma-controller: Atmel AHB DMA Controller ( cpy slave ), 8 channels
[ 0.150000] at_hdmac ffffe800.dma-controller: Atmel AHB DMA Controller ( cpy slave ), 8 channels
[ 0.230000] wlan-en-regulator: 1800 mV
[ 0.230000] SCSI subsystem initialized
[ 0.230000] usbcore: registered new interface driver usbfs
[ 0.230000] usbcore: registered new interface driver hub
[ 0.230000] usbcore: registered new device driver usb
[ 0.230000] at91_i2c f0014000.i2c: using dma0chan0 (tx) and dma0chan1 (rx) for DMA transfers
[ 0.230000] at91_i2c f0014000.i2c: AT91 i2c bus driver.
[ 0.230000] at91_i2c f0018000.i2c: using dma0chan2 (tx) and dma0chan3 (rx) for DMA transfers
[ 0.230000] at91_i2c f0018000.i2c: AT91 i2c bus driver.
[ 0.230000] at91_i2c f801c000.i2c: can't get a DMA channel for tx
[ 0.230000] at91_i2c f801c000.i2c: can't use DMA
[ 0.230000] at91_i2c f801c000.i2c: AT91 i2c bus driver.
[ 0.240000] pps_core: LinuxPPS API ver. 1 registered
[ 0.240000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.240000] PTP clock support registered
[ 0.240000] Bluetooth: Core ver 2.19
[ 0.240000] NET: Registered protocol family 31
[ 0.240000] Bluetooth: HCI device and connection manager initialized
[ 0.240000] Bluetooth: HCI socket layer initialized
[ 0.240000] Bluetooth: L2CAP socket layer initialized
[ 0.240000] Bluetooth: SCO socket layer initialized
[ 0.240000] Switched to clocksource tcb_clksrc
[ 0.270000] NET: Registered protocol family 2
[ 0.270000] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.270000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.270000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.270000] TCP: reno registered
[ 0.270000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.270000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.270000] NET: Registered protocol family 1
[ 0.280000] RPC: Registered named UNIX socket transport module.
[ 0.280000] RPC: Registered udp transport module.
[ 0.280000] RPC: Registered tcp transport module.
[ 0.280000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.280000] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.280000] msgmni has been set to 496
[ 0.290000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.290000] io scheduler noop registered (default)
[ 0.290000] VCC_1V8: 1800 mV
[ 0.290000] VCC_1V2: 1200 mV
[ 0.290000] VCC_3V3: 3300 mV
[ 0.300000] FUSE_2V5: 2500 mV
[ 0.300000] VDDANA: 3300 mV
[ 0.300000] LDO_REG3: at 600 mV
[ 0.310000] LDO_REG4: at 600 mV
[ 0.310000] f001c000.serial: ttyS1 at MMIO 0xf001c000 (irq = 30, base_baud = 4125000) is a ATMEL_SERIAL
[ 0.310000] f0020000.serial: ttyS2 at MMIO 0xf0020000 (irq = 31, base_baud = 4125000) is a ATMEL_SERIAL
[ 0.310000] ffffee00.serial: ttyS0 at MMIO 0xffffee00 (irq = 43, base_baud = 8250000) is a ATMEL_SERIAL
[ 0.850000] console [ttyS0] enabled
[ 0.860000] f0024000.serial: ttyS5 at MMIO 0xf0024000 (irq = 50, base_baud = 4125000) is a ATMEL_SERIAL
[ 0.870000] [drm] Initialized drm 1.1.0 20060810
[ 0.880000] brd: module loaded
[ 0.900000] loop: module loaded
[ 0.910000] atmel_nand_nfc 70000000.nfc: NFC is probed.
[ 0.910000] atmel_nand 60000000.nand: Use On Flash BBT
[ 0.920000] atmel_nand 60000000.nand: Using dma0chan4 for DMA transfers.
[ 0.920000] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xdc
[ 0.930000] nand: Micron MT29F4G08ABADAWP
[ 0.930000] nand: 512MiB, SLC, page size: 2048, OOB size: 64
[ 0.940000] atmel_nand 60000000.nand: minimum ECC: 4 bits in 512 bytes
[ 0.950000] atmel_nand 60000000.nand: Initialize PMECC params, cap: 4, sector: 512
[ 0.950000] atmel_nand 60000000.nand: Using NFC Sram read
[ 0.960000] nand: WARNING: MT29F4G08ABADAWP: the ECC used on your system is too weak compared to the one required by the NAND chip
[ 0.970000] Bad block table found at page 262080, version 0x01
[ 0.980000] Bad block table found at page 262016, version 0x01
[ 0.990000] 6 ofpart partitions found on MTD device atmel_nand
[ 0.990000] Creating 6 MTD partitions on "atmel_nand":
[ 1.000000] 0x000000000000-0x000000040000 : "at91bootstrap"
[ 1.000000] 0x000000040000-0x0000000c0000 : "bootloader"
[ 1.010000] 0x0000000c0000-0x000000180000 : "bootloader env"
[ 1.020000] 0x000000180000-0x000000200000 : "device tree"
[ 1.030000] 0x000000200000-0x000000800000 : "kernel"
[ 1.040000] 0x000000800000-0x000010000000 : "rootfs"
[ 1.040000] atmel_spi f0004000.spi: version: 0x213
[ 1.050000] atmel_spi f0004000.spi: Using dma0chan5 (tx) and dma0chan6 (rx) for DMA transfers
[ 1.060000] atmel_spi f0004000.spi: Atmel SPI Controller at 0xf0004000 (irq 26)
[ 1.070000] atmel_spi f8008000.spi: version: 0x213
[ 1.070000] atmel_spi f8008000.spi: Using dma1chan0 (tx) and dma1chan1 (rx) for DMA transfers
[ 1.080000] atmel_spi f8008000.spi: Atmel SPI Controller at 0xf8008000 (irq 35)
[ 1.090000] PPP generic driver version 2.4.2
[ 1.100000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.100000] ehci-atmel: EHCI Atmel driver
[ 1.110000] atmel-ehci 700000.ehci: EHCI Host Controller
[ 1.110000] atmel-ehci 700000.ehci: new USB bus registered, assigned bus number 1
[ 1.120000] atmel-ehci 700000.ehci: irq 52, io mem 0x00700000
[ 1.150000] atmel-ehci 700000.ehci: USB 2.0 started, EHCI 1.00
[ 1.150000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.160000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.170000] usb usb1: Product: EHCI Host Controller
[ 1.170000] usb usb1: Manufacturer: Linux 3.16.5-sama5-armv7-r8 ehci_hcd
[ 1.180000] usb usb1: SerialNumber: 700000.ehci
[ 1.180000] hub 1-0:1.0: USB hub found
[ 1.190000] hub 1-0:1.0: 3 ports detected
[ 1.190000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.200000] ohci-atmel: OHCI Atmel driver
[ 1.200000] at91_ohci 600000.ohci: OHCI Host Controller
[ 1.210000] at91_ohci 600000.ohci: new USB bus registered, assigned bus number 2
[ 1.220000] at91_ohci 600000.ohci: irq 52, io mem 0x00600000
[ 1.280000] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.290000] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.290000] usb usb2: Product: OHCI Host Controller
[ 1.300000] usb usb2: Manufacturer: Linux 3.16.5-sama5-armv7-r8 ohci_hcd
[ 1.300000] usb usb2: SerialNumber: at91
[ 1.310000] hub 2-0:1.0: USB hub found
[ 1.310000] hub 2-0:1.0: 3 ports detected
[ 1.320000] usbcore: registered new interface driver cdc_acm
[ 1.330000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.330000] usbcore: registered new interface driver usb-storage
[ 1.340000] usbcore: registered new interface driver usbserial
[ 1.350000] usbcore: registered new interface driver usbserial_generic
[ 1.350000] usbserial: USB Serial support registered for generic
[ 1.360000] usbcore: registered new interface driver ftdi_sio
[ 1.360000] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.370000] usbcore: registered new interface driver pl2303
[ 1.380000] usbserial: USB Serial support registered for pl2303
[ 1.380000] atmel_usba_udc 500000.gadget: MMIO registers at 0xf8030000 mapped at d08c0000
[ 1.390000] atmel_usba_udc 500000.gadget: FIFO at 0x00500000 mapped at d2200000
[ 1.400000] g_serial gadget: Gadget Serial v2.4
[ 1.410000] g_serial gadget: g_serial ready
[ 1.410000] rtc (null): invalid alarm value: 1900-1-6 22:36:15
[ 1.420000] at91_rtc fffffeb0.rtc: rtc core: registered fffffeb0.rtc as rtc0
[ 1.420000] at91_rtc fffffeb0.rtc: AT91 Real Time Clock driver.
[ 1.430000] i2c /dev entries driver
[ 1.440000] Bluetooth: HCI UART driver ver 2.2
[ 1.440000] Bluetooth: HCI H4 protocol initialized
[ 1.440000] usbcore: registered new interface driver btusb
[ 1.450000] atmel_aes f8038000.aes: version: 0x135
[ 1.460000] atmel_aes f8038000.aes: Atmel AES - Using dma1chan2, dma1chan3 for DMA transfers
[ 1.470000] atmel_sha f8034000.sha: version: 0x410
[ 1.470000] atmel_sha f8034000.sha: using dma1chan4 for DMA transfers
[ 1.480000] atmel_sha f8034000.sha: Atmel SHA1/SHA256/SHA224/SHA384/SHA512
[ 1.490000] atmel_tdes f803c000.tdes: version: 0x701
[ 1.490000] atmel_tdes f803c000.tdes: using dma1chan5, dma1chan6 for DMA transfers
[ 1.500000] atmel_tdes f803c000.tdes: Atmel DES/TDES
[ 1.510000] usbcore: registered new interface driver usbhid
[ 1.520000] usbhid: USB HID core driver
[ 1.520000] iio iio:device0: Resolution used: 12 bits
[ 1.520000] iio iio:device0: ADC Touch screen is disabled.
[ 1.530000] nf_conntrack version 0.5.0 (3970 buckets, 15880 max)
[ 1.540000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.550000] TCP: cubic registered
[ 1.550000] NET: Registered protocol family 10
[ 1.560000] sit: IPv6 over IPv4 tunneling driver
[ 1.570000] NET: Registered protocol family 17
[ 1.570000] Bridge firewalling registered
[ 1.580000] Bluetooth: RFCOMM TTY layer initialized
[ 1.580000] Bluetooth: RFCOMM socket layer initialized
[ 1.590000] Bluetooth: RFCOMM ver 1.11
[ 1.590000] registered taskstats version 1
[ 1.600000] input: gpio_keys as /devices/gpio_keys/input/input0
[ 1.610000] at91_rtc fffffeb0.rtc: setting system clock to 2007-01-06 22:36:25 UTC (1168122985)
[ 1.620000] atmel_mci f0000000.mmc: version: 0x505
[ 1.620000] atmel_mci f0000000.mmc: using dma0chan7 for DMA transfers
[ 1.630000] atmel_mci f0000000.mmc: No vmmc regulator found
[ 1.640000] atmel_mci f0000000.mmc: No vqmmc regulator found
[ 1.680000] atmel_mci f0000000.mmc: Atmel MCI controller at 0xf0000000 irq 25, 1 slots
[ 1.680000] atmel_mci f8000000.mmc: version: 0x505
[ 1.690000] atmel_mci f8000000.mmc: using dma1chan7 for DMA transfers
[ 1.700000] atmel_mci f8000000.mmc: No vmmc regulator found
[ 1.700000] atmel_mci f8000000.mmc: No vqmmc regulator found
[ 1.720000] g_serial gadget: high-speed config #2: CDC ACM config
[ 1.750000] atmel_mci f8000000.mmc: Atmel MCI controller at 0xf8000000 irq 33, 1 slots
[ 1.750000] atmel_mci f8004000.mmc: version: 0x505
[ 1.760000] atmel_mci f8004000.mmc: no DMA channel available
[ 1.760000] atmel_mci f8004000.mmc: using PIO
[ 1.770000] atmel_mci f8004000.mmc: No vqmmc regulator found
[ 1.800000] mmc1: host does not support reading read-only switch. assuming write-enable.
[ 1.810000] atmel_mci f8004000.mmc: Atmel MCI controller at 0xf8004000 irq 34, 1 slots
[ 1.820000] mmc1: new high speed SDHC card at address 59b4
[ 1.830000] mmcblk0: mmc1:59b4 00000 14.9 GiB
[ 1.840000] mmcblk0: p1 p2
[ 1.840000] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.850000] atmel_mci f8004000.mmc: card claims to support voltages below defined range
[ 1.860000] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 1.880000] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 1.890000] mmc2: new high speed SDIO card at address 0001
[ 1.920000] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.920000] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.940000] devtmpfs: mounted
[ 1.940000] Freeing unused kernel memory: 152K (c04f6000 - c051c000)
[ 2.190000] usb 2-3: new full-speed USB device number 2 using at91_ohci
INIT: version 2.88 booting
[ 2.420000] usb 2-3: New USB device found, idVendor=0403, idProduct=6001
[ 2.420000] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.430000] usb 2-3: Product: FT232R USB UART
[ 2.440000] usb 2-3: Manufacturer: FTDI
[ 2.440000] usb 2-3: SerialNumber: A503GAI5
[ 2.450000] ftdi_sio 2-3:1.0: FTDI USB Serial Device converter detected
[ 2.460000] usb 2-3: Detected FT232RL
[ 2.460000] usb 2-3: Number of endpoints 2
[ 2.460000] usb 2-3: Endpoint 1 MaxPacketSize 64
[ 2.470000] usb 2-3: Endpoint 2 MaxPacketSize 64
[ 2.470000] usb 2-3: Setting MaxPacketSize 64
[ 2.480000] usb 2-3: FTDI USB Serial Device converter now attached to ttyUSB0
[info] Using makefile-style concurrent boot in runlevel S.
[....] Starting the hotplug events dispatcher: udevd[ 3.570000] udevd[727]: starting version 175
. ok
[ ok [ 5.730000] random: nonblocking pool is initialized
[ 5.750000] Loading modules backported from Linux version R8.6-0-g3f5b34f
[ 5.750000] Backport generated by backports.git R8.6-0-g4677dc3
done.
[ 5.900000] cfg80211: Calling CRDA to update world regulatory domain
[....] [ 6.060000] wlcore: Time Sync: gpio requested
Waiting for /dev to be fully populated...[ 6.100000] wlcore: ERROR could not get configuration binary ti-connectivity/wl18xx-conf.bin: -2
[ 6.110000] wlcore: WARNING falling back to default config
[ 6.230000] cfg80211: World regulatory domain updated:
[ 6.240000] cfg80211: DFS Master region: unset
[ 6.240000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.250000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.260000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.270000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.280000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.290000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.300000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 6.300000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.310000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
done.
[ ok ] Activating swap...done.
[ 7.600000] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[....] Checking root file system...fsck from util-linux 2.20.1
rootfs: clean, 20933/119760 files, 134157/478207 blocks
done.
[ 7.900000] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ ok ] Cleaning up temporary files... /tmp.
[info] Loading kernel module g_serial.
[ ok ] Activating lvm and md swap...done.
[....] Checking file systems...fsck from util-linux 2.20.1
done.
[....] Mounting local filesystems...[ 13.390000] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
done.
[ ok ] Activating swapfile swap...done.
[ ok ] Cleaning up temporary files....
[ ok ] Setting kernel variables ...done.
[ ok ] Configuring network interfaces...done.
INIT: Entering runlevel: 2
[info] Using makefile-style concurrent boot in runlevel 2.
[ ok ] Starting enhanced syslogd: rsyslogd.
[ ok ] Starting periodic command scheduler: cron.
[ ok ] Starting system message bus: dbus.
[ ok ] Starting NTP server: ntpd.
[ ok ] Starting bluetooth: bluetoothd.
[ ok ] Starting OpenBSD Secure Shell server: sshd.
BT Enabled
Charger Config
Enabling TI Chip (/dev/ttyUSB0)
Found a Texas Instruments' chip!
Firmware file : /lib/firmware/ti-connectivity/TIInit_11.8.32.bts
Loaded BTS script version 1
[ 22.900000] mmc2: card 0001 removed
[ 22.940000] atmel_mci f8004000.mmc: card claims to support voltages below defined range
[ 22.960000] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 22.970000] mmc2: new high speed SDIO card at address 0001
[ 22.980000] wlcore: ERROR error requesting time_sync gpio
[ 22.980000] wlcore: ERROR can't allocate hw
[ 22.990000] wl18xx_driver: probe of wl18xx.0.auto failed with error -16
Can't set device: Protocol not supported
Can't initialize device: Protocol not supported
Device setup complete
