Other Parts Discussed in Thread: WL1837
could you send us an example sequence of VS HCI commands for setting up the PCM path for the HFP? This if for porting to a MSFT BT stack HFP.
Essentially using these commands:
HCI_VS_BT_IP_Set_Audio_Path (0xFD95)
HCI_VS_Write_CODEC_Config (0xFD06)
HCI_VS_Write_CODEC_Config_Enhanced (0xFD07)
HCI_VS_BT_IP_Audio_Rate_Conversion (0xFDFD)
HCI_VS_AVPR_Enable (0xFD92)
--Gunter
