I am using wilink8 (R8.7_SP1) with hi3516a hisilicon SOC and linux kernel 3.4.35. Wifi module is connected to hotspot successfully and getting pinged for some time.And then it gets crashed. Wifi IRQ is increased as seen in /proc/interrupts. Can you please guide to find out root-cause and possible solution?. Hereby adding more details below and attaching crash log.
CRASH LOG DETAIL
wpa_supplicant v2.1-devel
random: Trying to read entropy from /dev/random
Successfully initialized wpa_supplicant
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant.conf'
ctrl_interface='/var/run/wpa_supplicant'
ctrl_interface_group='0'
eapol_version=1
ap_scan=1
fast_reauth=1
Priority group 5
id=0 ssid='ipcamtest'
rfkill: Cannot open RFKILL control device
nl80211: RFKILL status not available
nl80211: Supports Probe Response offload in AP mode
nl80211: Using driver-based off-channel TX
nl80211: Unexpected vendor data info
nl80211: Use separate P2P group interface (driver advertised support)
nl80211: Enable multi-channel concurrent (driver advertised support)
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 4 iftype 2 (STATION)
nl80211: Subscribe to mgmt frames with non-AP handle 0x1c8d410
nl80211: Register frame type=0xd0 nl_handle=0x1c8d410
nl80211: Register frame match - hexdump(len=1): 06
nl80211: Register frame match - hexdump(len=2): 0a 07
nl80211: Register frame match - hexdump(len=2): 0a 11
netlink: Operstate: linkmode=1, operstate=5
nl80211: driver param='(null)'
Add interface wlan0 to a new radio phy0
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz
nl80211: 2402-2472 @ 20 mBm
nl80211: 2457-2482 @ 40 MHz
nl80211: 2457-2482 @ 20 mBm
nl80211: 2474-2494 @ 20 MHz
nl80211: 2474-2494 @ 20 mBm
nl80211: 5170-5250 @ 160 MHz
nl80211: 5170-5250 @ 20 mBm
nl80211: 5250-5330 @ 160 MHz
nl80211: 5250-5330 @ 20 mBm
nl80211: 5490-5730 @ 160 MHz
nl80211: 5490-5730 @ 20 mBm
nl80211: 5735-5835 @ 80 MHz
nl80211: 5735-5835 @ 20 mBm
nl80211: 57240-63720 @ 2160 MHz
nl80211: 57240-63720 @ 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
nl80211: Do not indicate P2P_DEVICE support (p2p_device=1 driver param not specified)
wlan0: Own MAC address: 68:c9:0b:07:f8:a5
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
wlan0: RSN: flushing PMKID list in the driver
nl80211: Flush PMKIDs
wlan0: Total active networks 1
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
nl80211: Set supplicant port unauthorized for 00:00:00:00:00:00
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
ctrl_interface_group=0
wlan0: Added interface wlan0
wlan0: State: DISCONNECTED -> DISCONNECTED
wpa_driver_nl80211_set_operstate: operstate 0->0 (DORMANT)
netlink: Operstate: linkmode=-1, operstate=5
Daemonize..
[root@ABC ~]# wlan0: authenticate with 86:73:03:c5:50:f7
wlan0: send auth to 86:73:03:c5:50:f7 (try 1/3)
wlan0: authenticated
wlan0: associate with 86:73:03:c5:50:f7 (try 1/3)
wlan0: RX AssocResp from 86:73:03:c5:50:f7 (capab=0x421 status=0 aid=2)
wlan0: associated
ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
wlcore: Association completed.
[root@ABC ~]#
[root@ABC ~]# ifconfig wlan0 192.168.43.7
[root@ABC ~]# ping 192.168.43.1
PING 192.168.43.1 (192.168.43.1): 56 data bytes
64 bytes from 192.168.43.1: seq=0 ttl=64 time=21.134 ms
64 bytes from 192.168.43.1: seq=1 ttl=64 time=11.719 ms
64 bytes from 192.168.43.1: seq=2 ttl=64 time=11.651 ms
64 bytes from 192.168.43.1: seq=3 ttl=64 time=16.125 ms
64 bytes from 192.168.43.1: seq=4 ttl=64 time=9.679 ms
64 bytes from 192.168.43.1: seq=5 ttl=64 time=11.711 ms
64 bytes from 192.168.43.1: seq=6 ttl=64 time=11.106 ms
64 bytes from 192.168.43.1: seq=7 ttl=64 time=11.015 ms
64 bytes from 192.168.43.1: seq=8 ttl=64 time=11.200 ms
64 bytes from 192.168.43.1: seq=9 ttl=64 time=12.146 ms
64 bytes from 192.168.43.1: seq=10 ttl=64 time=11.755 ms
64 bytes from 192.168.43.1: seq=11 ttl=64 time=11.850 ms
64 bytes from 192.168.43.1: seq=12 ttl=64 time=12.404 ms
64 bytes from 192.168.43.1: seq=13 ttl=64 time=12.028 ms
64 bytes from 192.168.43.1: seq=14 ttl=64 time=15.216 ms
64 bytes from 192.168.43.1: seq=15 ttl=64 time=11.540 ms
64 bytes from 192.168.43.1: seq=16 ttl=64 time=21.032 ms
64 bytes from 192.168.43.1: seq=17 ttl=64 time=14.732 ms
64 bytes from 192.168.43.1: seq=18 ttl=64 time=10.640 ms
64 bytes from 192.168.43.1: seq=19 ttl=64 time=6.499 ms
64 bytes from 192.168.43.1: seq=20 ttl=64 time=12.216 ms
64 bytes from 192.168.43.1: seq=21 ttl=64 time=52.347 ms
64 bytes from 192.168.43.1: seq=22 ttl=64 time=10.513 ms
64 bytes from 192.168.43.1: seq=23 ttl=64 time=12.026 ms
64 bytes from 192.168.43.1: seq=24 ttl=64 time=9.371 ms
64 bytes from 192.168.43.1: seq=25 ttl=64 time=11.462 ms
64 bytes from 192.168.43.1: seq=26 ttl=64 time=120.445 ms
64 bytes from 192.168.43.1: seq=27 ttl=64 time=10.027 ms
64 bytes from 192.168.43.1: seq=28 ttl=64 time=10.804 ms
64 bytes from 192.168.43.1: seq=29 ttl=64 time=2.676 ms
wlcore: ERROR ELP wakeup timeout!
------------[ cut here ]------------
WARNING: at /home/reddesk/wifi_working/build-utilites/src/compat_wireless/drivers/net/wireless/ti/wlcore/)
Modules linked in: wl18xx(O) wlcore_sdio(O) wlcore(O) mac80211(O) cfg80211(O) compat(O) hi_mipi(O) hi3516a_adec(PO) hi3516a_aenc(PO) hi3516a_ao(PO) hi3516a_ai(PO) hi3516a_aio(PO) acodec(PO) se)
Backtrace:
[<c0011fdc>] (dump_backtrace+0x0/0x110) from [<c04a3cc0>] (dump_stack+0x18/0x1c)
r6:bf461920 r5:00000009 r4:00000000 r3:c063f640
[<c04a3ca8>] (dump_stack+0x0/0x1c) from [<c001c374>] (warn_slowpath_common+0x5c/0x6c)
[<c001c318>] (warn_slowpath_common+0x0/0x6c) from [<c001c428>] (warn_slowpath_null+0x24/0x2c)
r8:bf47f6a4 r7:ffffa395 r6:00000000 r5:c06403c0 r4:ccb5d320
r3:00000009
[<c001c404>] (warn_slowpath_null+0x0/0x2c) from [<bf461920>] (wl12xx_queue_recovery_work.part.41+0x84/0x88 [wlcore])
[<bf46189c>] (wl12xx_queue_recovery_work.part.41+0x0/0x88 [wlcore]) from [<bf46338c>] (wl12xx_queue_recovery_work+0x1c/0x20 [wlcore])
r4:ccb5d320 r3:00000002
[<bf463370>] (wl12xx_queue_recovery_work+0x0/0x20 [wlcore]) from [<bf46cff4>] (wl1271_ps_elp_wakeup+0x1f4/0x20c [wlcore])
[<bf46ce00>] (wl1271_ps_elp_wakeup+0x0/0x20c [wlcore]) from [<bf46c02c>] (wl1271_tx_work+0x24/0x58 [wlcore])
[<bf46c008>] (wl1271_tx_work+0x0/0x58 [wlcore]) from [<c0030f88>] (process_one_work+0x118/0x388)
r5:cd81d1c0 r4:ccb5d4f0
[<c0030e70>] (process_one_work+0x0/0x388) from [<c0031584>] (worker_thread+0x1ac/0x38c)
[<c00313d8>] (worker_thread+0x0/0x38c) from [<c0035c94>] (kthread+0x98/0x9c)
[<c0035bfc>] (kthread+0x0/0x9c) from [<c001f724>] (do_exit+0x0/0x698)
r6:c001f724 r5:c0035bfc r4:cd82feb4
---[ end trace 480f8c6fc8805fde ]---
wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.69
Backtrace:
r6:bf469184 r5:00000009 r4:00000000 r3:c063f640
r8:ccb5d358 r7:bf460c64 r6:bf47f6a4 r5:bf4a4520 r4:ccb5d320
r3:00000009
[<c001c404>] (warn_slowpath_null+0x0/0x2c) from [<bf469184>] (wlcore_set_partition+0xa8/0x50c [wlcore])
[<bf4690dc>] (wlcore_set_partition+0x0/0x50c [wlcore]) from [<bf460cd8>] (wl1271_recovery_work+0x74/0x354 [wlcore])
r6:ccb5d320 r5:cd81d1c0 r4:ccb5d5bc
[<bf460c64>] (wl1271_recovery_work+0x0/0x354 [wlcore]) from [<c0030f88>] (process_one_work+0x118/0x388)
r8:00000000 r7:bf460c64 r6:ccb4fa00 r5:cd81d1c0 r4:ccb5d5bc
---[ end trace 480f8c6fc8805fdf ]---
wlcore: down
ieee80211 phy0: Hardware restart was requested
wlcore: PHY firmware version: Rev 8.2.0.0.236
wlcore: firmware booted (Rev 8.9.0.0.69)
--- 192.168.43.1 ping statistics ---
36 packets transmitted, 30 packets received, 16% packet loss
round-trip min/avg/max = 2.676/16.902/120.445 ms
U-Boot 2010.06 (Dec 28 2016 - 18:05:29) Check Nand Flash Controller v610 ... found Special NAND id table Version 1.36 Nand ID: 0x01 0xF1 0x80 0x1D 0x01 0xF1 0x80 0x1D Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:4bit/512 Nand total size: 128MB MMC: MMC FLASH INIT: No card on slot! In: serial Out: serial Err: serial Set training value to DDR controller Hit any key to stop autoboot: 0 Card did not respond to voltage select! mmc_init err : -17 set read bl len failed, trying default 512Byte mmc read failed ** Can't read partition table on 0:0 ** set read bl len failed, trying default 512Byte mmc read failed ** Unable to use 0:1 for fatls ** ethaddr : 00:1B:09:01:5C:0A exiting from automac without any process NAND read: device 0 offset 0x3a0000, size 0x380000 3670016 bytes read: OK ## Booting kernel from Legacy Image at 82000000 ... Image Name: Linux-3.4.35 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3382888 Bytes = 3.2 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. Booting Linux on physical CPU 0 Linux version 3.4.35 (darshanpatel@darshanpatel) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v400) ) #4 Tue Jan 17 14:00:15 IST 2017 CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: hi3516a Memory policy: ECC disabled, Data cache writeback Built 1 zonelists in Zone order, mobility grouping on. Total pages: 56134 Kernel command line: mem=221M console=ttyAMA0,115200 root=/dev/mtdblock5 rootfstype=yaffs2 mtdparts=hinand:384K(uboot),256K(ubootEnv),3M(recKernel),5120K(kernel),5M(data),45M(rootfs),45M(userf) PID hash table entries: 1024 (order: 0, 4096 bytes) Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 221MB = 221MB total Memory: 217468k/217468k available, 8836k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xce000000 - 0xff000000 ( 784 MB) lowmem : 0xc0000000 - 0xcdd00000 ( 221 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .text : 0xc0008000 - 0xc0608000 (6144 kB) .init : 0xc0608000 - 0xc062f7a4 ( 158 kB) .data : 0xc0630000 - 0xc0667100 ( 221 kB) .bss : 0xc0667124 - 0xc06a3f30 ( 244 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:128 sched_clock: 32 bits at 49MHz, resolution 20ns, wraps every 86767ms Console: colour dummy device 80x30 Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 Initializing cgroup subsys freezer CPU: Testing write buffer coherency: ok Setting up static identity map for 0x804aae10 - 0x804aae68 dummy: NET: Registered protocol family 16 Serial: AMBA PL011 UART driver uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 40) is a PL011 rev2 console [ttyAMA0] enabled uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 41) is a PL011 rev2 bio: create slab <bio-0> at 0 SCSI subsystem initialized hi-spi-master hi-spi-master.0: with 1 chip select slaves attached hi-spi-master hi-spi-master.1: with 3 chip select slaves attached usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb i2c_gpio_probe:190 i2c-gpio i2c-gpio.1: using pins 0 (SDA) and 0 (SCL) Switching to clocksource timer0 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP: reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) squashfs: version 4.0 (2009/01/31) Phillip Lougher jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc. fuse init (API version 7.18) SGI XFS with security attributes, large block/inode numbers, no debug enabled msgmni has been set to 424 Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) io scheduler noop registered io scheduler deadline registered (default) io scheduler cfq registered brd: module loaded Spi id table Version 1.22 Found Nand Flash Controller V610. Nand ID: 0x01 0xF1 0x80 0x1D 0x01 0xF1 0x80 0x1D Nand: AMD/Spansion NAND 128MiB 3,3V 8-bit Nand(HW-Auto): Block:128KB Page:2KB OOB:64B ECC:4bit/512 Chip:128MB*1 8 cmdlinepart partitions found on MTD device hinand 8 cmdlinepart partitions found on MTD device hinand Creating 8 MTD partitions on "hinand": 0x000000000000-0x000000060000 : "uboot" 0x000000060000-0x0000000a0000 : "ubootEnv" 0x0000000a0000-0x0000003a0000 : "recKernel" 0x0000003a0000-0x0000008a0000 : "kernel" 0x0000008a0000-0x000000da0000 : "data" 0x000000da0000-0x000003aa0000 : "rootfs" 0x000003aa0000-0x0000067a0000 : "userfs" 0x0000067a0000-0x000007fa0000 : "upgrade" Higmac dma_sg_phy: 0x8da80000 higmac_mdio_bus: probed ETH0: mii, phy_addr=1, mii_name=mdio0 PPP generic driver version 2.4.2 PPP BSD Compression module registered PPP Deflate Compression module registered PPP MPPE Compression module registered NET: Registered protocol family 24 ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver hiusb-ehci hiusb-ehci.0: HIUSB EHCI hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1 hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000 hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver hiusb-ohci hiusb-ohci.0: HIUSB OHCI hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2 hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. rtc-s35390a 1-0030: rtc core: registered rtc-s35390a as rtc0 i2c /dev entries driver hisi_i2c hisi_i2c.0: Hisilicon [i2c-0] probed! hisi_i2c hisi_i2c.2: Hisilicon [i2c-2] probed! error setting wl12xx data usbcore: registered new interface driver usbhid usbhid: USB HID core driver Netfilter messages via NETLINK v0.30. nf_conntrack version 0.5.0 (3397 buckets, 13588 max) ip_tables: (C) 2000-2006 Netfilter Core Team TCP: cubic registered Initializing XFRM netlink socket NET: Registered protocol family 10 ip6_tables: (C) 2000-2006 Netfilter Core Team IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 NET: Registered protocol family 15 Bridge firewalling registered Ebtables v2.0 registered Registering the dns_resolver key type VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 mmc0: card claims to support voltages below the defined range. These will be ignored. rtc-s35390a 1-0030: setting system clock to 2017-09-02 13:18:24 UTC (1504358304) yaffs: dev is 32505861 name is "mtdblock5" rw yaffs: passed flags "" mmc0: queuing unknown CIS tuple 0x91 (3 bytes) mmc0: new high speed SDIO card at address 0001 VFS: Mounted root (yaffs2 filesystem) on device 31:5. Freeing init memory: 156K mknod: /dev/null: File exists Populating /dev using udev: udevd (698): /proc/698/oom_adj is deprecated, please use /proc/698/oom_score_adj instead. done Initializing random number generator... done. Starting network... net.core.rmem_default = 65535 net.core.rmem_max = 16777216 net.ipv4.tcp_rmem = 4096 87380 8388608 net.ipv4.tcp_wmem = 4096 65536 8388608 net.ipv4.tcp_mem = 8388608 8388608 8388608 net.ipv4.route.flush = 1 net.ipv4.udp_rmem_min = 524288 net.ipv4.udp_wmem_min = 524288 net.ipv4.udp_mem = 1048576 1048576 1048576 net.ipv4.netfilter.ip_conntrack_max = 100000 net.ipv4.netfilter.ip_conntrack_generic_timeout = 120 net.ipv4.netfilter.ip_conntrack_tcp_timeout_established = 54000 net.ipv4.netfilter.ip_conntrack_tcp_timeout_time_wait = 30 ADDRCONF(NETDEV_UP): eth0: link is not ready [IPCAM_INIT_SCRIPT]->IP CAMERA Starting Script. yaffs: dev is 32505863 name is "mtdblock7" rw yaffs: passed flags "" [IPCAM_INIT_SCRIPT]->Upgrade partition Mount successfully yaffs: dev is 32505860 name is "mtdblock4" rw yaffs: passed flags "" [IPCAM_INIT_SCRIPT]->Data partition Mount successfully [IPCAM_INIT_SCRIPT]->Setting ip 192.168.112.190 Stopping vsftpd: no vsftpd found; none killed [IPCAM_INIT_SCRIPT]->Start FTP Starting vsftpd: OK yaffs: dev is 32505862 name is "mtdblock6" rw yaffs: passed flags "" [IPCAM_INIT_SCRIPT]->Kernel Version Signature available in /mnt/data/ [IPCAM_INIT_SCRIPT]->Uboot Version Signature available in /mnt/data/ [IPCAM_INIT_SCRIPT]->Currently Primary Kernel Running !! [IPCAM_INIT_SCRIPT]->Application Related Invokations Started!!! [IPCAM_INIT_SCRIPT]->Root permissions already Granted! Moving on.. rmmod: can't unload 'hi3516a_adec': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_aenc': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_ao': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_ai': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_aio': unknown symbol in module, or unknown parameter rmmod: can't unload 'acodec': unknown symbol in module, or unknown parameter remove audio rmmod: can't unload 'MxGpioDrv': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_ive': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_vda': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_rc': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_jpege': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_h264e': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_h265e': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_chnl': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_venc': unknown symbol in module, or unknown parameter rmmod: can't unload 'hifb': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_vou': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_vpss': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_viu': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi_mipi': unknown symbol in module, or unknown parameter rmmod: can't unload 'ssp_ad9020': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_vgs': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_region': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_tde': unknown symbol in module, or unknown parameter rmmod: can't unload 'drv8838': unknown symbol in module, or unknown parameter rmmod: can't unload 'isl29035': unknown symbol in module, or unknown parameter rmmod: can't unload 'wdt': unknown symbol in module, or unknown parameter rmmod: can't unload 'pwm': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_isp': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_sys': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi3516a_base': unknown symbol in module, or unknown parameter rmmod: can't unload 'hi_media': unknown symbol in module, or unknown parameter rmmod: can't unload 'mmz': unknown symbol in module, or unknown parameter rmmod: can't unload 'cmemk': unknown symbol in module, or unknown parameter CMEMK module: built on Dec 28 2016 at 17:47:46 Reference Linux version 3.4.35 allocated heap buffer 0xcf000000 of size 0x2300000 cmemk initialized Hisilicon Media Memory Zone Manager Module himedia: init ok hi3516a_base: module license 'Proprietary' taints kernel. Disabling lock debugging due to kernel taint PHY: mdio0:01 - Link is Up - 100/Full ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready load sys.ko for Hi3516A...OK! load tde.ko ...OK! load region.ko ....OK! load vgs.ko for Hi3516A...OK! ISP Mod init! load viu.ko for Hi3516A...OK! load vpss.ko ....OK! load vou.ko ....OK! load rc.ko for Hi3516A...OK! load venc.ko for Hi3516A...OK! load chnl.ko for Hi3516A...OK! load h264e.ko for Hi3516A...OK! load h265e.ko for Hi3516A...OK! load jpege.ko for Hi3516A...OK! load vda.ko ....OK! load ive.ko for Hi3516A...OK! DRV8838 probed!! IRCUT : Current State[on] IRCUT :Device Registered with pin MOTOR_PH->9[3] MOTOR_EN 9[5] EN_TIME->[100] DRV8838 Motor Driver Chip : Module Initialized ISL29035 Ambient Light Sensor Driver Initializing... isl29035: ALS chip found Hisilicon Watchdog Timer: 0.01 initialized. default_margin=30 sec (nowayout= 1, nodeamon= 1) *******MxGPIO driver: last Modified On Dec 28 2016 at 17:47:50 ##Piris Driver Last modified on [17:47:56][Dec 28 2016] PPS[400] ==== Your input Sensor type is imx123 ==== *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0050: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0054: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x200f0058: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x2 *******Sensor_spi driver: last Modified On Jan 13 2017 at 17:07:58 with maximun buffer limit 80 00f005c: 0x00000000 --> 0x00000001 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x2003002c: 0x00090007 --> 0x00090007 [END] *** Board tools : ver0.0.1_20121120 *** [debug]: {source/utils/cmdshell.c:166}cmdstr:himm 0x20030104: 0x00000acodec inited! 003 --> 0x00000000 [END] insert audio ==== Your input Sensor type is imx123 ==== mipi_init init phy power successful! load hi_mipi driver successful! Loading modules backported from Linux version R8.7_SP1-0-g13c25bc Backport generated by backports.git R8.7_SP1-0-gd4777ef ==== Wilink8 drivers inserted sucessfully ==== Sat Sep 2 18:48:30 2017 SYS_MAIN_LOG:E: main : ***** APPLICATION START *****: Jan 13 2017 17:25:56 wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11) wlcore: loaded wlcore: driver version: R8.7_SP1 ABC login: 2017-09-02 13:18:33: (log.c.166) server started 2017-09-02 13:18:33: (mod_fd_transfer.c.508) [socket- /tmp/IntSocket ], [bin-path- /mediaStreamer ], [key- /unicaststream/ ] 2017-09-02 13:18:33: (mod_fd_transfer.c.508) [socket- /tmp/OnvifSocket ], [bin-path- /OnvifServer ], [key- /onvif/ ] 2017-09-02 13:18:33: (mod_fd_transfer.c.508) [socket- /tmp/AudioSocket ], [bin-path- /av_server ], [key- /networkaudio/ ] rlinear mode ActualDuty[0], finalDuty[0] ActualDuty[0], finalDuty[0] ootipwatchd[1086]: IPwatchD started -------Sony IMX123 Sensor QXGA 30 Linear Initial OK!------- Password: wlcore: PHY firmware version: Rev 8.2.0.0.236 wlcore: firmware booted (Rev 8.9.0.0.69) ADDRCONF(NETDEV_UP): wlan0: link is not ready Sat Sep 2 18:48:35 2017 SYS_DISK_MGR_LOG:E: updateStorageDiskInfo : Disk Id File not open [/etc/.diskId] -------Sony IMX123 Sensor QXGA 30 Linear Initial OK!------- ActualDuty[0], finalDuty[0] ActualDuty[0], finalDuty[0] login[1033]: root login on 'ttyAMA0' [root@ABC ~]# [root@ABC ~]# [root@ABC ~]# [root@ABC ~]# /Sat Sep 2 18:48:37 2017 ONVIF_MAIN_LOG:E: watchFileEvents : IP change event received iptables: No chain/target/match by that name. ./wifi_notify.sh wpa_supplicant v2.1-devel random: Trying to read entropy from /dev/random Successfully initialized wpa_supplicant Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A' Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf' Reading configuration file '/etc/wpa_supplicant.conf' ctrl_interface='/var/run/wpa_supplicant' ctrl_interface_group='0' eapol_version=1 ap_scan=1 fast_reauth=1 Priority group 5 id=0 ssid='ipcamtest' rfkill: Cannot open RFKILL control device nl80211: RFKILL status not available nl80211: Supports Probe Response offload in AP mode nl80211: Using driver-based off-channel TX nl80211: Unexpected vendor data info nl80211: Unexpected vendor data info nl80211: Unexpected vendor data info nl80211: Unexpected vendor data info nl80211: Unexpected vendor data info nl80211: Use separate P2P group interface (driver advertised support) nl80211: Enable multi-channel concurrent (driver advertised support) nl80211: interface wlan0 in phy phy0 nl80211: Set mode ifindex 4 iftype 2 (STATION) nl80211: Subscribe to mgmt frames with non-AP handle 0x1c8d410 nl80211: Register frame type=0xd0 nl_handle=0x1c8d410 nl80211: Register frame match - hexdump(len=1): 06 nl80211: Register frame type=0xd0 nl_handle=0x1c8d410 nl80211: Register frame match - hexdump(len=2): 0a 07 nl80211: Register frame type=0xd0 nl_handle=0x1c8d410 nl80211: Register frame match - hexdump(len=2): 0a 11 netlink: Operstate: linkmode=1, operstate=5 nl80211: driver param='(null)' Add interface wlan0 to a new radio phy0 nl80211: Regulatory information - country=00 nl80211: 2402-2472 @ 40 MHz nl80211: 2402-2472 @ 20 mBm nl80211: 2457-2482 @ 40 MHz nl80211: 2457-2482 @ 20 mBm nl80211: 2474-2494 @ 20 MHz nl80211: 2474-2494 @ 20 mBm nl80211: 5170-5250 @ 160 MHz nl80211: 5170-5250 @ 20 mBm nl80211: 5250-5330 @ 160 MHz nl80211: 5250-5330 @ 20 mBm nl80211: 5490-5730 @ 160 MHz nl80211: 5490-5730 @ 20 mBm nl80211: 5735-5835 @ 80 MHz nl80211: 5735-5835 @ 20 mBm nl80211: 57240-63720 @ 2160 MHz nl80211: 57240-63720 @ 0 mBm nl80211: Added 802.11b mode based on 802.11g information nl80211: Do not indicate P2P_DEVICE support (p2p_device=1 driver param not specified) wlan0: Own MAC address: 68:c9:0b:07:f8:a5 wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0 wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0 wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0 wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0 wlan0: RSN: flushing PMKID list in the driver nl80211: Flush PMKIDs wlan0: Total active networks 1 EAPOL: SUPP_PAE entering state DISCONNECTED EAPOL: Supplicant port status: Unauthorized nl80211: Set supplicant port unauthorized for 00:00:00:00:00:00 EAPOL: KEY_RX entering state NO_KEY_RECEIVE EAPOL: SUPP_BE entering state INITIALIZE EAP: EAP entering state DISABLED EAPOL: Supplicant port status: Unauthorized nl80211: Set supplicant port unauthorized for 00:00:00:00:00:00 EAPOL: Supplicant port status: Unauthorized nl80211: Set supplicant port unauthorized for 00:00:00:00:00:00 ctrl_interface_group=0 wlan0: Added interface wlan0 wlan0: State: DISCONNECTED -> DISCONNECTED wpa_driver_nl80211_set_operstate: operstate 0->0 (DORMANT) netlink: Operstate: linkmode=-1, operstate=5 Daemonize.. [root@ABC ~]# wlan0: authenticate with 86:73:03:c5:50:f7 wlan0: send auth to 86:73:03:c5:50:f7 (try 1/3) wlan0: authenticated wlan0: associate with 86:73:03:c5:50:f7 (try 1/3) wlan0: RX AssocResp from 86:73:03:c5:50:f7 (capab=0x421 status=0 aid=2) wlan0: associated ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready wlcore: Association completed. [root@ABC ~]# [root@ABC ~]# ifconfig wlan0 192.168.43.7 [root@ABC ~]# ping 192.168.43.1 PING 192.168.43.1 (192.168.43.1): 56 data bytes 64 bytes from 192.168.43.1: seq=0 ttl=64 time=21.134 ms 64 bytes from 192.168.43.1: seq=1 ttl=64 time=11.719 ms 64 bytes from 192.168.43.1: seq=2 ttl=64 time=11.651 ms 64 bytes from 192.168.43.1: seq=3 ttl=64 time=16.125 ms 64 bytes from 192.168.43.1: seq=4 ttl=64 time=9.679 ms 64 bytes from 192.168.43.1: seq=5 ttl=64 time=11.711 ms 64 bytes from 192.168.43.1: seq=6 ttl=64 time=11.106 ms 64 bytes from 192.168.43.1: seq=7 ttl=64 time=11.015 ms 64 bytes from 192.168.43.1: seq=8 ttl=64 time=11.200 ms 64 bytes from 192.168.43.1: seq=9 ttl=64 time=12.146 ms 64 bytes from 192.168.43.1: seq=10 ttl=64 time=11.755 ms 64 bytes from 192.168.43.1: seq=11 ttl=64 time=11.850 ms 64 bytes from 192.168.43.1: seq=12 ttl=64 time=12.404 ms 64 bytes from 192.168.43.1: seq=13 ttl=64 time=12.028 ms 64 bytes from 192.168.43.1: seq=14 ttl=64 time=15.216 ms 64 bytes from 192.168.43.1: seq=15 ttl=64 time=11.540 ms 64 bytes from 192.168.43.1: seq=16 ttl=64 time=21.032 ms 64 bytes from 192.168.43.1: seq=17 ttl=64 time=14.732 ms 64 bytes from 192.168.43.1: seq=18 ttl=64 time=10.640 ms 64 bytes from 192.168.43.1: seq=19 ttl=64 time=6.499 ms 64 bytes from 192.168.43.1: seq=20 ttl=64 time=12.216 ms 64 bytes from 192.168.43.1: seq=21 ttl=64 time=52.347 ms 64 bytes from 192.168.43.1: seq=22 ttl=64 time=10.513 ms 64 bytes from 192.168.43.1: seq=23 ttl=64 time=12.026 ms 64 bytes from 192.168.43.1: seq=24 ttl=64 time=9.371 ms 64 bytes from 192.168.43.1: seq=25 ttl=64 time=11.462 ms 64 bytes from 192.168.43.1: seq=26 ttl=64 time=120.445 ms 64 bytes from 192.168.43.1: seq=27 ttl=64 time=10.027 ms 64 bytes from 192.168.43.1: seq=28 ttl=64 time=10.804 ms 64 bytes from 192.168.43.1: seq=29 ttl=64 time=2.676 ms wlcore: ERROR ELP wakeup timeout! ------------[ cut here ]------------ WARNING: at /home/reddesk/wifi_working/build-utilites/src/compat_wireless/drivers/net/wireless/ti/wlcore/) Modules linked in: wl18xx(O) wlcore_sdio(O) wlcore(O) mac80211(O) cfg80211(O) compat(O) hi_mipi(O) hi3516a_adec(PO) hi3516a_aenc(PO) hi3516a_ao(PO) hi3516a_ai(PO) hi3516a_aio(PO) acodec(PO) se) Backtrace: [<c0011fdc>] (dump_backtrace+0x0/0x110) from [<c04a3cc0>] (dump_stack+0x18/0x1c) r6:bf461920 r5:00000009 r4:00000000 r3:c063f640 [<c04a3ca8>] (dump_stack+0x0/0x1c) from [<c001c374>] (warn_slowpath_common+0x5c/0x6c) [<c001c318>] (warn_slowpath_common+0x0/0x6c) from [<c001c428>] (warn_slowpath_null+0x24/0x2c) r8:bf47f6a4 r7:ffffa395 r6:00000000 r5:c06403c0 r4:ccb5d320 r3:00000009 [<c001c404>] (warn_slowpath_null+0x0/0x2c) from [<bf461920>] (wl12xx_queue_recovery_work.part.41+0x84/0x88 [wlcore]) [<bf46189c>] (wl12xx_queue_recovery_work.part.41+0x0/0x88 [wlcore]) from [<bf46338c>] (wl12xx_queue_recovery_work+0x1c/0x20 [wlcore]) r4:ccb5d320 r3:00000002 [<bf463370>] (wl12xx_queue_recovery_work+0x0/0x20 [wlcore]) from [<bf46cff4>] (wl1271_ps_elp_wakeup+0x1f4/0x20c [wlcore]) [<bf46ce00>] (wl1271_ps_elp_wakeup+0x0/0x20c [wlcore]) from [<bf46c02c>] (wl1271_tx_work+0x24/0x58 [wlcore]) [<bf46c008>] (wl1271_tx_work+0x0/0x58 [wlcore]) from [<c0030f88>] (process_one_work+0x118/0x388) r5:cd81d1c0 r4:ccb5d4f0 [<c0030e70>] (process_one_work+0x0/0x388) from [<c0031584>] (worker_thread+0x1ac/0x38c) [<c00313d8>] (worker_thread+0x0/0x38c) from [<c0035c94>] (kthread+0x98/0x9c) [<c0035bfc>] (kthread+0x0/0x9c) from [<c001f724>] (do_exit+0x0/0x698) r6:c001f724 r5:c0035bfc r4:cd82feb4 ---[ end trace 480f8c6fc8805fde ]--- wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.69 ------------[ cut here ]------------ WARNING: at /home/reddesk/wifi_working/build-utilites/src/compat_wireless/drivers/net/wireless/ti/wlcore/) Modules linked in: wl18xx(O) wlcore_sdio(O) wlcore(O) mac80211(O) cfg80211(O) compat(O) hi_mipi(O) hi3516a_adec(PO) hi3516a_aenc(PO) hi3516a_ao(PO) hi3516a_ai(PO) hi3516a_aio(PO) acodec(PO) se) Backtrace: [<c0011fdc>] (dump_backtrace+0x0/0x110) from [<c04a3cc0>] (dump_stack+0x18/0x1c) r6:bf469184 r5:00000009 r4:00000000 r3:c063f640 [<c04a3ca8>] (dump_stack+0x0/0x1c) from [<c001c374>] (warn_slowpath_common+0x5c/0x6c) [<c001c318>] (warn_slowpath_common+0x0/0x6c) from [<c001c428>] (warn_slowpath_null+0x24/0x2c) r8:ccb5d358 r7:bf460c64 r6:bf47f6a4 r5:bf4a4520 r4:ccb5d320 r3:00000009 [<c001c404>] (warn_slowpath_null+0x0/0x2c) from [<bf469184>] (wlcore_set_partition+0xa8/0x50c [wlcore]) [<bf4690dc>] (wlcore_set_partition+0x0/0x50c [wlcore]) from [<bf460cd8>] (wl1271_recovery_work+0x74/0x354 [wlcore]) r6:ccb5d320 r5:cd81d1c0 r4:ccb5d5bc [<bf460c64>] (wl1271_recovery_work+0x0/0x354 [wlcore]) from [<c0030f88>] (process_one_work+0x118/0x388) r8:00000000 r7:bf460c64 r6:ccb4fa00 r5:cd81d1c0 r4:ccb5d5bc [<c0030e70>] (process_one_work+0x0/0x388) from [<c0031584>] (worker_thread+0x1ac/0x38c) [<c00313d8>] (worker_thread+0x0/0x38c) from [<c0035c94>] (kthread+0x98/0x9c) [<c0035bfc>] (kthread+0x0/0x9c) from [<c001f724>] (do_exit+0x0/0x698) r6:c001f724 r5:c0035bfc r4:cd82feb4 ---[ end trace 480f8c6fc8805fdf ]--- wlcore: down ieee80211 phy0: Hardware restart was requested wlcore: PHY firmware version: Rev 8.2.0.0.236 wlcore: firmware booted (Rev 8.9.0.0.69) wlcore: Association completed. --- 192.168.43.1 ping statistics --- 36 packets transmitted, 30 packets received, 16% packet loss round-trip min/avg/max = 2.676/16.902/120.445 ms [root@ABC ~]# [root@ABC ~]# [root@ABC ~]# dmesg <6>Booting Linux on physical CPU 0 <5>Linux version 3.4.35 (reddesk@reddesk) (gcc version 4.8.3 20131202 (prerelease) (Hisilicon_v400) ) #4 Tue Jan 17 14:00:15 IST 2017 <4>CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d <4>CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache <4>Machine: hi3516a <4>Memory policy: ECC disabled, Data cache writeback <7>On node 0 totalpages: 56576 <7>free_area_init_node: node 0, pgdat c06669fc, node_mem_map c06a4000 <7> Normal zone: 442 pages used for memmap <7> Normal zone: 0 pages reserved <7> Normal zone: 56134 pages, LIFO batch:15 <7>pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 <7>pcpu-alloc: [0] 0 <4>Built 1 zonelists in Zone order, mobility grouping on. Total pages: 56134 <5>Kernel command line: mem=221M console=ttyAMA0,115200 root=/dev/mtdblock5 rootfstype=yaffs2 mtdparts=hinand:384K(uboot),256K(ubootEnv),3M(recKernel),5120K(kernel),5M(data),45M(rootfs),45M(us) <6>PID hash table entries: 1024 (order: 0, 4096 bytes) <6>Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) <6>Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) <6>Memory: 221MB = 221MB total <5>Memory: 217468k/217468k available, 8836k reserved, 0K highmem <5>Virtual kernel memory layout: <5> vector : 0xffff0000 - 0xffff1000 ( 4 kB) <5> fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) <5> vmalloc : 0xce000000 - 0xff000000 ( 784 MB) <5> lowmem : 0xc0000000 - 0xcdd00000 ( 221 MB) <5> modules : 0xbf000000 - 0xc0000000 ( 16 MB) <5> .text : 0xc0008000 - 0xc0608000 (6144 kB) <5> .init : 0xc0608000 - 0xc062f7a4 ( 158 kB) <5> .data : 0xc0630000 - 0xc0667100 ( 221 kB) <5> .bss : 0xc0667124 - 0xc06a3f30 ( 244 kB) <6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 <6>NR_IRQS:128 <6>sched_clock: 32 bits at 49MHz, resolution 20ns, wraps every 86767ms <6>Console: colour dummy device 80x30 <6>Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256) <6>pid_max: default: 32768 minimum: 301 <6>Mount-cache hash table entries: 512 <6>Initializing cgroup subsys freezer <6>CPU: Testing write buffer coherency: ok <6>Setting up static identity map for 0x804aae10 - 0x804aae68 <6>dummy: <6>NET: Registered protocol family 16 <6>Serial: AMBA PL011 UART driver <6>uart:0: ttyAMA0 at MMIO 0x20080000 (irq = 40) is a PL011 rev2 <6>console [ttyAMA0] enabled <6>uart:1: ttyAMA1 at MMIO 0x20090000 (irq = 41) is a PL011 rev2 <6>bio: create slab <bio-0> at 0 <5>SCSI subsystem initialized <5>hi-spi-master hi-spi-master.0: with 1 chip select slaves attached <5>hi-spi-master hi-spi-master.1: with 3 chip select slaves attached <6>usbcore: registered new interface driver usbfs <6>usbcore: registered new interface driver hub <6>usbcore: registered new device driver usb <4>i2c_gpio_probe:190 <6>i2c-gpio i2c-gpio.1: using pins 0 (SDA) and 0 (SCL) <6>Switching to clocksource timer0 <6>NET: Registered protocol family 2 <6>IP route cache hash table entries: 2048 (order: 1, 8192 bytes) <6>TCP established hash table entries: 8192 (order: 4, 65536 bytes) <6>TCP bind hash table entries: 8192 (order: 3, 32768 bytes) <6>TCP: Hash tables configured (established 8192 bind 8192) <6>TCP: reno registered <6>UDP hash table entries: 256 (order: 0, 4096 bytes) <6>UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) <6>NET: Registered protocol family 1 <6>RPC: Registered named UNIX socket transport module. <6>RPC: Registered udp transport module. <6>RPC: Registered tcp transport module. <6>RPC: Registered tcp NFSv4.1 backchannel transport module. <5>VFS: Disk quotas dquot_6.5.2 <4>Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) <6>squashfs: version 4.0 (2009/01/31) Phillip Lougher <6>jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc. <6>fuse init (API version 7.18) <6>SGI XFS with security attributes, large block/inode numbers, no debug enabled <7>yaffs: yaffs built Jan 16 2017 12:02:17 Installing. <6>msgmni has been set to 424 <6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) <6>io scheduler noop registered <6>io scheduler deadline registered (default) <6>io scheduler cfq registered <6>brd: module loaded <6>Spi id table Version 1.22 <7>Hisfc350 Device Driver, Version 1.10 <5>Found Nand Flash Controller V610. <4>Nand ID: 0x01 0xF1 0x80 0x1D 0x01 0xF1 0x80 0x1D <4>Nand: AMD/Spansion NAND 128MiB 3,3V 8-bit <4>Nand(HW-Auto): Block:128KB Page:2KB OOB:64B ECC:4bit/512 Chip:128MB*1 <5>8 cmdlinepart partitions found on MTD device hinand <5>8 cmdlinepart partitions found on MTD device hinand <5>Creating 8 MTD partitions on "hinand": <5>0x000000000000-0x000000060000 : "uboot" <5>0x000000060000-0x0000000a0000 : "ubootEnv" <5>0x0000000a0000-0x0000003a0000 : "recKernel" <5>0x0000003a0000-0x0000008a0000 : "kernel" <5>0x0000008a0000-0x000000da0000 : "data" <5>0x000000da0000-0x000003aa0000 : "rootfs" <5>0x000003aa0000-0x0000067a0000 : "userfs" <5>0x0000067a0000-0x000007fa0000 : "upgrade" <6>Higmac dma_sg_phy: 0x8da80000 <6>higmac_mdio_bus: probed <6>ETH0: mii, phy_addr=1, mii_name=mdio0 <6>PPP generic driver version 2.4.2 <6>PPP BSD Compression module registered <6>PPP Deflate Compression module registered <6>PPP MPPE Compression module registered <6>NET: Registered protocol family 24 <6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver <6>hiusb-ehci hiusb-ehci.0: HIUSB EHCI <6>hiusb-ehci hiusb-ehci.0: new USB bus registered, assigned bus number 1 <6>hiusb-ehci hiusb-ehci.0: irq 53, io mem 0x100b0000 <6>hiusb-ehci hiusb-ehci.0: USB 0.0 started, EHCI 1.00 <6>hub 1-0:1.0: USB hub found <6>hub 1-0:1.0: 1 port detected <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver <6>hiusb-ohci hiusb-ohci.0: HIUSB OHCI <6>hiusb-ohci hiusb-ohci.0: new USB bus registered, assigned bus number 2 <6>hiusb-ohci hiusb-ohci.0: irq 54, io mem 0x100a0000 <6>hub 2-0:1.0: USB hub found <6>hub 2-0:1.0: 1 port detected <6>Initializing USB Mass Storage driver... <6>usbcore: registered new interface driver usb-storage <6>USB Mass Storage support registered. <6>rtc-s35390a 1-0030: rtc core: registered rtc-s35390a as rtc0 <6>i2c /dev entries driver <5>hisi_i2c hisi_i2c.0: Hisilicon [i2c-0] probed! <5>hisi_i2c hisi_i2c.2: Hisilicon [i2c-2] probed! <3>error setting wl12xx data <6>usbcore: registered new interface driver usbhid <6>usbhid: USB HID core driver <6>Netfilter messages via NETLINK v0.30. <6>nf_conntrack version 0.5.0 (3397 buckets, 13588 max) <6>ip_tables: (C) 2000-2006 Netfilter Core Team <6>TCP: cubic registered <6>Initializing XFRM netlink socket <6>NET: Registered protocol family 10 <6>ip6_tables: (C) 2000-2006 Netfilter Core Team <6>IPv6 over IPv4 tunneling driver <6>NET: Registered protocol family 17 <6>NET: Registered protocol family 15 <5>Bridge firewalling registered <6>Ebtables v2.0 registered <5>Registering the dns_resolver key type <6>VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 <4>mmc0: card claims to support voltages below the defined range. These will be ignored. <6>rtc-s35390a 1-0030: setting system clock to 2017-09-02 13:18:24 UTC (1504358304) <6>yaffs: dev is 32505861 name is "mtdblock5" rw <6>yaffs: passed flags "" <7>yaffs: yaffs: Attempting MTD mount of 31.5,"mtdblock5" <7>yaffs: checking block 4 bad <4>mmc0: queuing unknown CIS tuple 0x91 (3 bytes) <6>mmc0: new high speed SDIO card at address 0001 <7>yaffs: checking block 5 bad <7>yaffs: yaffs_read_super: is_checkpointed 1 <6>VFS: Mounted root (yaffs2 filesystem) on device 31:5. <6>Freeing init memory: 156K <4>udevd (698): /proc/698/oom_adj is deprecated, please use /proc/698/oom_score_adj instead. <6>ADDRCONF(NETDEV_UP): eth0: link is not ready <6>yaffs: dev is 32505863 name is "mtdblock7" rw <6>yaffs: passed flags "" <7>yaffs: yaffs: Attempting MTD mount of 31.7,"mtdblock7" <7>yaffs: checking block 0 bad <7>yaffs: yaffs_read_super: is_checkpointed 1 <6>yaffs: dev is 32505860 name is "mtdblock4" rw <6>yaffs: passed flags "" <7>yaffs: yaffs: Attempting MTD mount of 31.4,"mtdblock4" <7>yaffs: checking block 0 bad <7>yaffs: checking block 1 bad <7>yaffs: checking block 2 bad <7>yaffs: checking block 3 bad <7>yaffs: checking block 4 bad <7>yaffs: checking block 5 bad <7>yaffs: checking block 6 bad <7>yaffs: checking block 7 bad <7>yaffs: checking block 8 bad <7>yaffs: checking block 9 bad <7>yaffs: checking block 10 bad <7>yaffs: checking block 11 bad <7>yaffs: checking block 12 bad <7>yaffs: checking block 13 bad <7>yaffs: checking block 14 bad <7>yaffs: checking block 15 bad <7>yaffs: checking block 16 bad <7>yaffs: checking block 17 bad <7>yaffs: checking block 18 bad <7>yaffs: checking block 19 bad <7>yaffs: checking block 20 bad <7>yaffs: checking block 21 bad <7>yaffs: checking block 22 bad <7>yaffs: checking block 23 bad <7>yaffs: checking block 24 bad <7>yaffs: checking block 25 bad <7>yaffs: checking block 26 bad <7>yaffs: checking block 27 bad <7>yaffs: checking block 28 bad <7>yaffs: checking block 29 bad <7>yaffs: checking block 30 bad <7>yaffs: checking block 31 bad <7>yaffs: checking block 32 bad <7>yaffs: checking block 33 bad <7>yaffs: checking block 34 bad <7>yaffs: checking block 35 bad <7>yaffs: checking block 36 bad <7>yaffs: checking block 37 bad <7>yaffs: checking block 38 bad <7>yaffs: checking block 39 bad <7>yaffs: yaffs_read_super: is_checkpointed 0 <6>yaffs: dev is 32505862 name is "mtdblock6" rw <6>yaffs: passed flags "" <7>yaffs: yaffs: Attempting MTD mount of 31.6,"mtdblock6" <7>yaffs: checking block 87 bad <7>yaffs: yaffs_read_super: is_checkpointed 1 <6>CMEMK module: built on Dec 28 2016 at 17:47:46 <6> Reference Linux version 3.4.35 <6>allocated heap buffer 0xcf000000 of size 0x2300000 <6>cmemk initialized <6>Hisilicon Media Memory Zone Manager <4>Module himedia: init ok <4>hi3516a_base: module license 'Proprietary' taints kernel. <4>Disabling lock debugging due to kernel taint <6>PHY: mdio0:01 - Link is Up - 100/Full <6>ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready <4>load sys.ko for Hi3516A...OK! <4>load tde.ko ...OK! <6>load region.ko ....OK! <4>load vgs.ko for Hi3516A...OK! <6>ISP Mod init! <4>load viu.ko for Hi3516A...OK! <6>load vpss.ko ....OK! <6>load vou.ko ....OK! <4>load rc.ko for Hi3516A...OK! <4>load venc.ko for Hi3516A...OK! <4>load chnl.ko for Hi3516A...OK! <4>load h264e.ko for Hi3516A...OK! <4>load h265e.ko for Hi3516A...OK! <4>load jpege.ko for Hi3516A...OK! <6>load vda.ko ....OK! <4>load ive.ko for Hi3516A...OK! <4>DRV8838 probed!! <6>IRCUT : Current State[on] <6>IRCUT :Device Registered with pin MOTOR_PH->9[3] MOTOR_EN 9[5] EN_TIME->[100] <6>DRV8838 Motor Driver Chip : Module Initialized <6>ISL29035 Ambient Light Sensor Driver Initializing... <6>isl29035: ALS chip found <6>Hisilicon Watchdog Timer: 0.01 initialized. default_margin=30 sec (nowayout= 1, nodeamon= 1) <4> <4>*******MxGPIO driver: last Modified On Dec 28 2016 at 17:47:50 <4>##Piris Driver Last modified on [17:47:56][Dec 28 2016] PPS[400] <4> <4>*******Sensor_spi driver: last Modified On Jan 13 2017 at 17:07:58 with maximun buffer limit 80 <4>acodec inited! <1>mipi_init <4>init phy power successful! <4>load hi_mipi driver successful! <6>Loading modules backported from Linux version R8.7_SP1-0-g13c25bc <6>Backport generated by backports.git R8.7_SP1-0-gd4777ef <6>wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11) <6>wlcore: loaded <6>wlcore: driver version: R8.7_SP1 <4>ActualDuty[0], finalDuty[0] <4>ActualDuty[0], finalDuty[0] <6>wlcore: PHY firmware version: Rev 8.2.0.0.236 <6>wlcore: firmware booted (Rev 8.9.0.0.69) <6>ADDRCONF(NETDEV_UP): wlan0: link is not ready <4>ActualDuty[0], finalDuty[0] <4>ActualDuty[0], finalDuty[0] <7>eth0: no IPv6 routers present <6>wlan0: authenticate with 86:73:03:c5:50:f7 <6>wlan0: send auth to 86:73:03:c5:50:f7 (try 1/3) <6>wlan0: authenticated <6>wlan0: associate with 86:73:03:c5:50:f7 (try 1/3) <6>wlan0: RX AssocResp from 86:73:03:c5:50:f7 (capab=0x421 status=0 aid=2) <6>wlan0: associated <6>ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready <6>wlcore: Association completed. <7>wlan0: no IPv6 routers present <3>wlcore: ERROR ELP wakeup timeout! <4>------------[ cut here ]------------ <4>WARNING: at /home/reddesk/wifi_working/build-utilites/src/compat_wireless/drivers/net/wireless/ti/wlco) <4>Modules linked in: wl18xx(O) wlcore_sdio(O) wlcore(O) mac80211(O) cfg80211(O) compat(O) hi_mipi(O) hi3516a_adec(PO) hi3516a_aenc(PO) hi3516a_ao(PO) hi3516a_ai(PO) hi3516a_aio(PO) acodec(PO)) <4>Backtrace: <4>[<c0011fdc>] (dump_backtrace+0x0/0x110) from [<c04a3cc0>] (dump_stack+0x18/0x1c) <4> r6:bf461920 r5:00000009 r4:00000000 r3:c063f640 <4>[<c04a3ca8>] (dump_stack+0x0/0x1c) from [<c001c374>] (warn_slowpath_common+0x5c/0x6c) <4>[<c001c318>] (warn_slowpath_common+0x0/0x6c) from [<c001c428>] (warn_slowpath_null+0x24/0x2c) <4> r8:bf47f6a4 r7:ffffa395 r6:00000000 r5:c06403c0 r4:ccb5d320 <4>r3:00000009 <4>[<c001c404>] (warn_slowpath_null+0x0/0x2c) from [<bf461920>] (wl12xx_queue_recovery_work.part.41+0x84/0x88 [wlcore]) <4>[<bf46189c>] (wl12xx_queue_recovery_work.part.41+0x0/0x88 [wlcore]) from [<bf46338c>] (wl12xx_queue_recovery_work+0x1c/0x20 [wlcore]) <4> r4:ccb5d320 r3:00000002 <4>[<bf463370>] (wl12xx_queue_recovery_work+0x0/0x20 [wlcore]) from [<bf46cff4>] (wl1271_ps_elp_wakeup+0x1f4/0x20c [wlcore]) <4>[<bf46ce00>] (wl1271_ps_elp_wakeup+0x0/0x20c [wlcore]) from [<bf46c02c>] (wl1271_tx_work+0x24/0x58 [wlcore]) <4>[<bf46c008>] (wl1271_tx_work+0x0/0x58 [wlcore]) from [<c0030f88>] (process_one_work+0x118/0x388) <4> r5:cd81d1c0 r4:ccb5d4f0 <4>[<c0030e70>] (process_one_work+0x0/0x388) from [<c0031584>] (worker_thread+0x1ac/0x38c) <4>[<c00313d8>] (worker_thread+0x0/0x38c) from [<c0035c94>] (kthread+0x98/0x9c) <4>[<c0035bfc>] (kthread+0x0/0x9c) from [<c001f724>] (do_exit+0x0/0x698) <4> r6:c001f724 r5:c0035bfc r4:cd82feb4 <4>---[ end trace 480f8c6fc8805fde ]--- <6>wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.69 <4>------------[ cut here ]------------ <4>WARNING: at /home/reddesk/wifi_working/build-utilites/src/compat_wireless/drivers/net/wireless/ti/wlco) <4>Modules linked in: wl18xx(O) wlcore_sdio(O) wlcore(O) mac80211(O) cfg80211(O) compat(O) hi_mipi(O) hi3516a_adec(PO) hi3516a_aenc(PO) hi3516a_ao(PO) hi3516a_ai(PO) hi3516a_aio(PO) acodec(PO)) <4>Backtrace: <4>[<c0011fdc>] (dump_backtrace+0x0/0x110) from [<c04a3cc0>] (dump_stack+0x18/0x1c) <4> r6:bf469184 r5:00000009 r4:00000000 r3:c063f640 <4>[<c04a3ca8>] (dump_stack+0x0/0x1c) from [<c001c374>] (warn_slowpath_common+0x5c/0x6c) <4>[<c001c318>] (warn_slowpath_common+0x0/0x6c) from [<c001c428>] (warn_slowpath_null+0x24/0x2c) <4> r8:ccb5d358 r7:bf460c64 r6:bf47f6a4 r5:bf4a4520 r4:ccb5d320 <4>r3:00000009 <4>[<c001c404>] (warn_slowpath_null+0x0/0x2c) from [<bf469184>] (wlcore_set_partition+0xa8/0x50c [wlcore]) <4>[<bf4690dc>] (wlcore_set_partition+0x0/0x50c [wlcore]) from [<bf460cd8>] (wl1271_recovery_work+0x74/0x354 [wlcore]) <4> r6:ccb5d320 r5:cd81d1c0 r4:ccb5d5bc <4>[<bf460c64>] (wl1271_recovery_work+0x0/0x354 [wlcore]) from [<c0030f88>] (process_one_work+0x118/0x388) <4> r8:00000000 r7:bf460c64 r6:ccb4fa00 r5:cd81d1c0 r4:ccb5d5bc <4>[<c0030e70>] (process_one_work+0x0/0x388) from [<c0031584>] (worker_thread+0x1ac/0x38c) <4>[<c00313d8>] (worker_thread+0x0/0x38c) from [<c0035c94>] (kthread+0x98/0x9c) <4>[<c0035bfc>] (kthread+0x0/0x9c) from [<c001f724>] (do_exit+0x0/0x698) <4> r6:c001f724 r5:c0035bfc r4:cd82feb4 <4>---[ end trace 480f8c6fc8805fdf ]--- <6>wlcore: down <6>ieee80211 phy0: Hardware restart was requested <6>wlcore: PHY firmware version: Rev 8.2.0.0.236 <6>wlcore: firmware booted (Rev 8.9.0.0.69) <6>wlcore: Association completed. [root@ABC ~]# cat /proc/interrupts CPU0 35: 14932 GIC timer 36: 1 GIC timer3 40: 3574 GIC uart-pl011 51: 4658 GIC hi_mci 52: 0 GIC hi_mci 53: 8 GIC ehci_hcd:usb1 54: 1 GIC ohci_hcd:usb2 57: 42 GIC gmac0 65: 0 GIC VOU Interrupt 66: 0 GIC mipi int 67: 13764 GIC ISP, VIU 68: 6870 GIC VPSS0 69: 0 GIC tde_osr_isr 70: 10281 GIC VGS0 71: 0 GIC AIO Interrupt 72: 10285 GIC VEDU_0 73: 688 GIC JPEGU_0 75: 0 GIC HEVCU_0 76: 581 GIC VDA 77: 0 GIC IVE 81: 573 GIC wl18xx Err: 0 [root@ABC ~]#
DarshanPatel
