I am measuring the peak power of WL1835MOD with the TI SDMMC adaptor board, with fw version 4 and the WL1835MOD_INI.ini as the configuration setting and RTTT as the testing tool. I notice almost 6dB difference in power level when SoC limits check box is enabled vs when that is disabled and the power level matches to the FCC test reports maximum conducted power only when the SoC limits are disabled.
When I use calibrator tool on my board with the same INI and fw version, the power levels only match the conducted power levels when SoC limits are enabled.
I would like to know, whether SoC limits were applied or not during the FCC testing of this product and how to ensure that the same settings are followed on my board.
Also is there a way to configure SoC limits using "calibrator" tool ?
Also any insight on what this SoC limits in the RTTT means and what are the limits set on the firmware for each channel will be really helpful. Thanks a lot!
