Other Parts Discussed in Thread: WL1835
Tool/software: Linux
I have tested the continuous TX test for WL1835 for 20Mhz upper and 20Mhz lower. Followed the commands as described in below link
Link : processors.wiki.ti.com/.../WL18xx_TX_Testing
- Commands mentioned in section 2) 20MHz Primary Upper and 3) 20MHz Primary Lower
But I did not get the output as defined in above link in DSO.
For both the case we got the same output. The utility used which gives proper output for other cases mentioned in above link ( like 20Mhz, 40 Mhz upper, 40Mhz lower etc.)
I have attached photos of the output that i have got in DSO for 20Mhz upper and 20 Mhz lower.
Ankit
