Part Number: WL1837MOD
Other Parts Discussed in Thread: WL1837
I am using WL1837MOD WiFi module with NXP's iMX6D processor (Android KitKat 4.4.3) for my ongoing project. We want to stream video content to our one device to another device. for that, we have created p2p go in one device and another device act as a client. We are able to create p2p go in the device at 2.4Ghz frequency band. Although device creates p2p go at always fixed frequency (2412MHz). but for the better performance, we want to create p2p go at 5Ghz band. For that, we have changed wpasupplicant code to create p2p go at the fixed 5180Mhz frequency. the reason behind fix frequency is p2p go creation always failed on other frequency values. we are able to create p2p go at 5180Mhz frequency in some area of our office. But in some area in the office, it failed to create p2p go at 5180Mhz frequency as like other frequencies.
So my are questions as below.
- Why device always creates p2p go at 2412Mhz on 2.4Ghz band?
- Is best frequency selection in 5Ghz and 2.4Ghz band for p2p Go creation is supported in WL1837?
- Why we are only able to create p2p go at fixed 5180Mhz on 5Ghz band (some area in the office).
Kindly, Help us to resolve issue ...!!!
For your reference, I am attaching logs of p2p creation at 5Ghz and 2.4Ghz.
Mrudang
Fail to create p2p go at 5Ghz
D/WebsocketService( 660): Trying to start P2PGO
D/wpa_supplicant( 591): RX ctrl_iface - hexdump(len=24): 50 32 50 5f 47 52 4f 55 50 5f 41 44 44 20 70 65 72 73 69 73 74 65 6e 74
D/wpa_supplicant( 591): p2p-dev-wlan0: Control interface command 'P2P_GROUP_ADD persistent'
D/wpa_supplicant( 591): CTRL_IFACE monitor send - hexdump(len=39): 2f 64 61 74 61 2f 6d 69 73 63 2f 77 69 66 69 2f 73 6f 63 6b 65 74 73 2f 77 70 61 5f 63 74 72 6c ...
D/wpa_supplicant( 591): P2P: Stop any on-going P2P FIND
D/wpa_supplicant( 591): P2P: Stopping find
D/wpa_supplicant( 591): P2P: Clear timeout (state=IDLE)
D/wpa_supplicant( 591): P2P: State IDLE -> IDLE
D/wpa_supplicant( 591): P2P: Request to start GO on 5 GHz band
D/wpa_supplicant( 591): P2P: Use random 5 GHz band channel: 5180 MHz
D/wpa_supplicant( 591): P2P: Set GO freq based on forced frequency 5180 MHz
D/wpa_supplicant( 591): P2P: Cannot force GO on any of the channels we are already using. Use one of the free channels
D/wpa_supplicant( 591): P2P: Create a new interface p2p-wlan0-0 for the group
D/wpa_supplicant( 591): nl80211: Create interface iftype 9 (P2P_GO)
D/wpa_supplicant( 591): nl80211: New interface p2p-wlan0-0 created: ifindex=3
D/wpa_supplicant( 591): nl80211: Set TX rates failed: ret=-100 (Network is down)
D/wpa_supplicant( 591): P2P: Created pending virtual interface p2p-wlan0-0 addr 3a:d2:69:b7:a8:90
D/wpa_supplicant( 591): Override interface parameter: ctrl_interface ('/data/misc/wifi/sockets' -> '/data/misc/wifi/sockets')
D/wpa_supplicant( 591): Initializing interface 'p2p-wlan0-0' conf 'N/A' driver 'nl80211' ctrl_interface '/data/misc/wifi/sockets' bridge 'N/A'
D/wpa_supplicant( 591): rfkill: initial event: idx=0 type=2 op=0 soft=1 hard=0
D/wpa_supplicant( 591): rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0
D/wpa_supplicant( 591): nl80211: Supports Probe Response offload in AP mode
D/wpa_supplicant( 591): nl80211: Using driver-based off-channel TX
D/wpa_supplicant( 591): nl80211: Use separate P2P group interface (driver advertised support)
D/wpa_supplicant( 591): nl80211: Enable multi-channel concurrent (driver advertised support)
D/wpa_supplicant( 591): nl80211: interface p2p-wlan0-0 in phy phy0
D/wpa_supplicant( 591): nl80211: Set mode ifindex 3 iftype 9 (P2P_GO)
D/wpa_supplicant( 591): nl80211: Setup AP - device_ap_sme=0 use_monitor=0
D/wpa_supplicant( 591): nl80211: Subscribe to mgmt frames with AP handle 0x7876a480
D/wpa_supplicant( 591): nl80211: Register frame type=0xb0 nl_handle=0x7876a480
D/wpa_supplicant( 591): nl80211: Register frame match - hexdump(len=0): [NULL]
D/wpa_supplicant( 591): nl80211: Register frame type=0x0 nl_handle=0x7876a480
D/wpa_supplicant( 591): nl80211: Register frame type=0x20 nl_handle=0x7876a480
D/wpa_supplicant( 591): nl80211: Register frame type=0xa0 nl_handle=0x7876a480
D/wpa_supplicant( 591): nl80211: Register frame type=0xc0 nl_handle=0x7876a480
D/wpa_supplicant( 591): nl80211: Register frame type=0xd0 nl_handle=0x7876a480
D/wpa_supplicant( 591): nl80211: Register frame type=0x40 nl_handle=0x7876a480
D/wpa_supplicant( 591): netlink: Operstate: linkmode=1, operstate=5
D/wpa_supplicant( 591): nl80211: driver param='p2p_device=1'
D/wpa_supplicant( 591): nl80211: Regulatory information - country=00
D/wpa_supplicant( 591): nl80211: 2402-2472 @ 40 MHz
D/wpa_supplicant( 591): nl80211: 2457-2482 @ 40 MHz
D/wpa_supplicant( 591): nl80211: 2474-2494 @ 20 MHz
D/wpa_supplicant( 591): nl80211: 5170-5250 @ 160 MHz
D/wpa_supplicant( 591): nl80211: 5250-5330 @ 160 MHz
D/wpa_supplicant( 591): nl80211: 5490-5730 @ 160 MHz
D/wpa_supplicant( 591): nl80211: 5735-5835 @ 80 MHz
D/wpa_supplicant( 591): nl80211: 57240-63720 @ 2160 MHz
D/wpa_supplicant( 591): nl80211: Added 802.11b mode based on 802.11g information
D/wpa_supplicant( 591): p2p-wlan0-0: Own MAC address: 3a:d2:69:b7:a8:90
D/wpa_supplicant( 591): wpa_driver_nl80211_set_key: ifindex=3 (p2p-wlan0-0) alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 591): wpa_driver_nl80211_set_key: ifindex=3 (p2p-wlan0-0) alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 591): wpa_driver_nl80211_set_key: ifindex=3 (p2p-wlan0-0) alg=0 addr=0x0 key_idx=2 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 591): wpa_driver_nl80211_set_key: ifindex=3 (p2p-wlan0-0) alg=0 addr=0x0 key_idx=3 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 591): p2p-wlan0-0: RSN: flushing PMKID list in the driver
D/wpa_supplicant( 591): nl80211: Flush PMKIDs
D/wpa_supplicant( 591): p2p-wlan0-0: State: DISCONNECTED -> INACTIVE
D/wpa_supplicant( 591): TDLS: TDLS operation not supported by driver
D/wpa_supplicant( 591): TDLS: Driver uses internal link setup
D/wpa_supplicant( 591): WPS: Set UUID for interface p2p-wlan0-0
D/wpa_supplicant( 591): WPS: UUID from the first interface - hexdump(len=16): 4b 22 9e f8 47 f5 5a 44 bf 49 68 6e 6c b1 02 56
D/wpa_supplicant( 591): EAPOL: SUPP_PAE entering state DISCONNECTED
D/wpa_supplicant( 591): EAPOL: Supplicant port status: Unauthorized
D/wpa_supplicant( 591): nl80211: Set supplicant port unauthorized for 00:00:00:00:00:00
D/wpa_supplicant( 591): EAPOL: KEY_RX entering state NO_KEY_RECEIVE
D/wpa_supplicant( 591): EAPOL: SUPP_BE entering state INITIALIZE
D/wpa_supplicant( 591): EAP: EAP entering state DISABLED
D/wpa_supplicant( 591): Using existing control interface directory.
D/wpa_supplicant( 591): p2p-wlan0-0: Added interface p2p-wlan0-0
D/wpa_supplicant( 591): p2p-wlan0-0: State: INACTIVE -> DISCONNECTED
D/wpa_supplicant( 591): wpa_driver_nl80211_set_operstate: operstate 0->0 (DORMANT)
D/wpa_supplicant( 591): netlink: Operstate: linkmode=-1, operstate=5
D/wpa_supplicant( 591): p2p-dev-wlan0: P2P: Use separate group interface p2p-wlan0-0
D/wpa_supplicant( 591): p2p-wlan0-0: P2P: Starting GO
D/wpa_supplicant( 591): p2p-wlan0-0: P2P: Request scan (that will be skipped) to start GO)
D/wpa_supplicant( 591): p2p-wlan0-0: Setting scan request: 0 sec 0 usec
D/wpa_supplicant( 591): EAPOL: startWhen --> 0
D/wpa_supplicant( 591): EAPOL: disable timer tick
D/wpa_supplicant( 591): RTM_NEWLINK: operstate=0 ifi_flags=0x1002 ()
D/wpa_supplicant( 591): nl80211: Ignore interface down event since interface p2p-wlan0-0 is up
D/wpa_supplicant( 591): RTM_NEWLINK: operstate=0 ifi_flags=0x1043 ([UP][RUNNING])
D/wpa_supplicant( 591): RTM_NEWLINK, IFLA_IFNAME: Interface 'p2p-wlan0-0' added
D/wpa_supplicant( 591): nl80211: if_removed already cleared - ignore event
D/wpa_supplicant( 591): RTM_NEWLINK: operstate=0 ifi_flags=0x1003 ([UP])
D/WebsocketService( 660): P2pGO started successfully
D/wpa_supplicant( 591): p2p-wlan0-0: State: DISCONNECTED -> SCANNING
D/wpa_supplicant( 591): Start a pre-selected network without scan step
D/wpa_supplicant( 591): Setting up AP (SSID='DIRECT-hQ')
D/wpa_supplicant( 591): nl80211: Setup AP operations for P2P group (GO)
D/wpa_supplicant( 591): nl80211: Unsubscribe mgmt frames handle 0x7876a480 (start AP)
D/wpa_supplicant( 591): nl80211: Set freq 5180 (ht_enabled=0, vht_enabled=0, bandwidth=0 MHz, cf1=0 MHz, cf2=0 MHz)
D/wpa_supplicant( 591): nl80211: Failed to set channel (freq=5180): -22 (Invalid argument)
I/wpa_supplicant( 591): p2p-wlan0-0: Failed to start AP functionality
D/wpa_supplicant( 591): p2p-wlan0-0: State: SCANNING -> DISCONNECTED
D/wpa_supplicant( 591): RX ctrl_iface - hexdump(len=9): 52 45 43 4f 4e 4e 45 43 54
D/wpa_supplicant( 591): wlan0: Control interface command 'RECONNECT'
D/ConnectivityService( 418): handleConnectivityChange: addresses changed linkProperty[1]: resetMask=0
D/ConnectivityService( 418): car=removed=[] added=[fe80::3ad2:69ff:feb7:a890/64,]
D/Nat464Xlat( 418): requiresClat: netType=1, hasIPv4Address=true
D/dalvikvm( 418): GC_CONCURRENT freed 519K, 11% free 5524K/6148K, paused 27ms+5ms, total 100ms
D/ConnectivityService( 418): handleConnectivityChange: address are the same reset per doReset linkProperty[1]: resetMask=0
D/wpa_supplicant( 591): RX ctrl_iface - hexdump(len=11): 53 49 47 4e 41 4c 5f 50 4f 4c 4c
D/wpa_supplicant( 591): wlan0: Control interface command 'SIGNAL_POLL'
D/wpa_supplicant( 591): nl80211: survey data missing!
I/GlobalDismissManager( 872): no sender configured
D/AlertService( 872): Beginning updateAlertNotification
D/AlertService( 872): No fired or scheduled alerts
D/AlertService( 872): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
D/AlarmScheduler( 872): No events found starting within 1 week.
I/ActivityManager( 418): Resuming delayed broadcast
D/EndoluxeReceiver( 660): Received intent action : android.net.wifi.STATE_CHANGE
D/CaptivePortalTracker( 418): NoActiveNetworkState{ when=-1ms what=1 obj=NetworkInfo: type: WIFI[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: "Volansys", roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false target=com.android.internal.util.StateMachine$SmHandler }
D/Tethering( 418): MasterInitialState.processMessage what=3
D/MQTTService( 660): >>>>>>>>>Broadcast Receive = android.net.conn.CONNECTIVITY_CHANGE
D/CaptivePortalTracker( 418): DelayedCaptiveCheckState{ when=-1ms what=1 obj=NetworkInfo: type: WIFI[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: "Volansys", roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false target=com.android.internal.util.StateMachine$SmHandler }
D/MQTTService( 660): 38d269b7a890
D/CloudRest( 660): Cloud Endpoint called =======>>>>> http://103.254.244.206:3000/api/devices/38d269b7a890
D/dalvikvm( 660): GC_CONCURRENT freed 715K, 15% free 4504K/5288K, paused 3ms+3ms, total 28ms
D/MQTTService( 660): retry device registered
W/ActivityThread( 660): ClassLoader.loadClass: The class loader returned by Thread.getContextClassLoader() may fail for processes that host multiple applications. You should explicitly specify a context class loader. For example: Thread.setContextClassLoader(getClass().getClassLoader());
E/Volley ( 660): [43] BasicNetwork.performRequest: Unexpected response code 409 for http://103.254.244.206:3000/api/devices/38d269b7a890
D/MQTTService( 660): Error : com.android.volley.ServerError
p2p go at 2ghz
D/CloudRest( 643): Cloud Endpoint called =======>>>>> http://103.254.244.206:3000/api/devices/38d269b7a890
D/MQTTService( 643): Error : Internet Connectivity not available
D/MQTTService( 643): retry device registered
D/WebsocketService( 643): Trying to start P2PGO
D/wpa_supplicant( 594): RX ctrl_iface - hexdump(len=24): 50 32 50 5f 47 52 4f 55 50 5f 41 44 44 20 70 65 72 73 69 73 74 65 6e 74
D/wpa_supplicant( 594): p2p-dev-wlan0: Control interface command 'P2P_GROUP_ADD persistent'
D/wpa_supplicant( 594): CTRL_IFACE monitor send - hexdump(len=39): 2f 64 61 74 61 2f 6d 69 73 63 2f 77 69 66 69 2f 73 6f 63 6b 65 74 73 2f 77 70 61 5f 63 74 72 6c ...
D/wpa_supplicant( 594): P2P: Stop any on-going P2P FIND
D/wpa_supplicant( 594): P2P: Stopping find
D/wpa_supplicant( 594): P2P: Clear timeout (state=IDLE)
D/wpa_supplicant( 594): P2P: State IDLE -> IDLE
D/wpa_supplicant( 594): P2P: Set GO freq 2412 MHz (no preference known)
D/wpa_supplicant( 594): P2P: Cannot force GO on any of the channels we are already using. Use one of the free channels
D/wpa_supplicant( 594): P2P: Create a new interface p2p-wlan0-0 for the group
D/wpa_supplicant( 594): nl80211: Create interface iftype 9 (P2P_GO)
D/wpa_supplicant( 594): nl80211: New interface p2p-wlan0-0 created: ifindex=3
D/wpa_supplicant( 594): nl80211: Set TX rates failed: ret=-100 (Network is down)
D/wpa_supplicant( 594): P2P: Created pending virtual interface p2p-wlan0-0 addr 3a:d2:69:b7:a8:90
D/wpa_supplicant( 594): Override interface parameter: ctrl_interface ('/data/misc/wifi/sockets' -> '/data/misc/wifi/sockets')
D/wpa_supplicant( 594): Initializing interface 'p2p-wlan0-0' conf 'N/A' driver 'nl80211' ctrl_interface '/data/misc/wifi/sockets' bridge 'N/A'
D/wpa_supplicant( 594): rfkill: initial event: idx=0 type=2 op=0 soft=1 hard=0
D/wpa_supplicant( 594): rfkill: initial event: idx=1 type=1 op=0 soft=0 hard=0
D/wpa_supplicant( 594): nl80211: Supports Probe Response offload in AP mode
D/wpa_supplicant( 594): nl80211: Using driver-based off-channel TX
D/wpa_supplicant( 594): nl80211: Use separate P2P group interface (driver advertised support)
D/wpa_supplicant( 594): nl80211: Enable multi-channel concurrent (driver advertised support)
D/wpa_supplicant( 594): nl80211: interface p2p-wlan0-0 in phy phy0
D/wpa_supplicant( 594): nl80211: Set mode ifindex 3 iftype 9 (P2P_GO)
D/wpa_supplicant( 594): nl80211: Setup AP - device_ap_sme=0 use_monitor=0
D/wpa_supplicant( 594): nl80211: Subscribe to mgmt frames with AP handle 0x77699190
D/wpa_supplicant( 594): nl80211: Register frame type=0xb0 nl_handle=0x77699190
D/wpa_supplicant( 594): nl80211: Register frame match - hexdump(len=0): [NULL]
D/wpa_supplicant( 594): nl80211: Register frame type=0x0 nl_handle=0x77699190
D/wpa_supplicant( 594): nl80211: Register frame type=0x20 nl_handle=0x77699190
D/wpa_supplicant( 594): nl80211: Register frame type=0xa0 nl_handle=0x77699190
D/wpa_supplicant( 594): nl80211: Register frame type=0xc0 nl_handle=0x77699190
D/wpa_supplicant( 594): nl80211: Register frame type=0xd0 nl_handle=0x77699190
D/wpa_supplicant( 594): nl80211: Register frame type=0x40 nl_handle=0x77699190
D/wpa_supplicant( 594): netlink: Operstate: linkmode=1, operstate=5
D/wpa_supplicant( 594): nl80211: driver param='p2p_device=1'
D/wpa_supplicant( 594): nl80211: Regulatory information - country=00
D/wpa_supplicant( 594): nl80211: 2402-2472 @ 40 MHz
D/wpa_supplicant( 594): nl80211: 2457-2482 @ 40 MHz
D/wpa_supplicant( 594): nl80211: 2474-2494 @ 20 MHz
D/wpa_supplicant( 594): nl80211: 5170-5250 @ 160 MHz
D/wpa_supplicant( 594): nl80211: 5250-5330 @ 160 MHz
D/wpa_supplicant( 594): nl80211: 5490-5730 @ 160 MHz
D/wpa_supplicant( 594): nl80211: 5735-5835 @ 80 MHz
D/wpa_supplicant( 594): nl80211: 57240-63720 @ 2160 MHz
D/wpa_supplicant( 594): nl80211: Added 802.11b mode based on 802.11g information
D/wpa_supplicant( 594): p2p-wlan0-0: Own MAC address: 3a:d2:69:b7:a8:90
D/wpa_supplicant( 594): wpa_driver_nl80211_set_key: ifindex=3 (p2p-wlan0-0) alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 594): wpa_driver_nl80211_set_key: ifindex=3 (p2p-wlan0-0) alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 594): wpa_driver_nl80211_set_key: ifindex=3 (p2p-wlan0-0) alg=0 addr=0x0 key_idx=2 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 594): wpa_driver_nl80211_set_key: ifindex=3 (p2p-wlan0-0) alg=0 addr=0x0 key_idx=3 set_tx=0 seq_len=0 key_len=0
D/wpa_supplicant( 594): p2p-wlan0-0: RSN: flushing PMKID list in the driver
D/wpa_supplicant( 594): nl80211: Flush PMKIDs
D/wpa_supplicant( 594): p2p-wlan0-0: State: DISCONNECTED -> INACTIVE
D/wpa_supplicant( 594): TDLS: TDLS operation not supported by driver
D/wpa_supplicant( 594): TDLS: Driver uses internal link setup
D/wpa_supplicant( 594): WPS: Set UUID for interface p2p-wlan0-0
D/wpa_supplicant( 594): WPS: UUID from the first interface - hexdump(len=16): 4b 22 9e f8 47 f5 5a 44 bf 49 68 6e 6c b1 02 56
D/wpa_supplicant( 594): EAPOL: SUPP_PAE entering state DISCONNECTED
D/wpa_supplicant( 594): EAPOL: Supplicant port status: Unauthorized
D/wpa_supplicant( 594): nl80211: Set supplicant port unauthorized for 00:00:00:00:00:00
D/wpa_supplicant( 594): EAPOL: KEY_RX entering state NO_KEY_RECEIVE
D/wpa_supplicant( 594): EAPOL: SUPP_BE entering state INITIALIZE
D/wpa_supplicant( 594): EAP: EAP entering state DISABLED
D/wpa_supplicant( 594): Using existing control interface directory.
D/wpa_supplicant( 594): p2p-wlan0-0: Added interface p2p-wlan0-0
D/wpa_supplicant( 594): p2p-wlan0-0: State: INACTIVE -> DISCONNECTED
D/wpa_supplicant( 594): wpa_driver_nl80211_set_operstate: operstate 0->0 (DORMANT)
D/wpa_supplicant( 594): netlink: Operstate: linkmode=-1, operstate=5
D/wpa_supplicant( 594): p2p-dev-wlan0: P2P: Use separate group interface p2p-wlan0-0
D/wpa_supplicant( 594): p2p-wlan0-0: P2P: Starting GO
D/wpa_supplicant( 594): p2p-wlan0-0: P2P: Request scan (that will be skipped) to start GO)
D/wpa_supplicant( 594): p2p-wlan0-0: Setting scan request: 0 sec 0 usec
D/WebsocketService( 643): P2pGO started successfully
D/wpa_supplicant( 594): p2p-wlan0-0: State: DISCONNECTED -> SCANNING
D/wpa_supplicant( 594): Start a pre-selected network without scan step
D/wpa_supplicant( 594): Setting up AP (SSID='DIRECT-9g')
D/wpa_supplicant( 594): nl80211: Setup AP operations for P2P group (GO)
D/wpa_supplicant( 594): nl80211: Unsubscribe mgmt frames handle 0x77699190 (start AP)
D/wpa_supplicant( 594): nl80211: Set freq 2412 (ht_enabled=0, vht_enabled=0, bandwidth=0 MHz, cf1=0 MHz, cf2=0 MHz)
D/wpa_supplicant( 594): P2P: * Capability dev=25 group=4b
D/wpa_supplicant( 594): P2P: * Device Info
D/wpa_supplicant( 594): P2P: * P2P IE header
D/wpa_supplicant( 594): P2P: * Device ID: 38:d2:69:b7:a8:91
D/wpa_supplicant( 594): P2P: GO - group idle
D/wpa_supplicant( 594): P2P: * Capability dev=25 group=0b
D/wpa_supplicant( 594): BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
D/wpa_supplicant( 594): Completing interface initialization
D/wpa_supplicant( 594): Mode: IEEE 802.11g Channel: 1 Frequency: 2412 MHz
D/wpa_supplicant( 594): nl80211: Set freq 2412 (ht_enabled=1, vht_enabled=0, bandwidth=20 MHz, cf1=2412 MHz, cf2=0 MHz)
D/wpa_supplicant( 594): RATE[0] rate=60 flags=0x1
D/wpa_supplicant( 594): RATE[1] rate=90 flags=0x0
D/wpa_supplicant( 594): RATE[2] rate=120 flags=0x1
D/wpa_supplicant( 594): RATE[3] rate=180 flags=0x0
D/wpa_supplicant( 594): RATE[4] rate=240 flags=0x1
D/wpa_supplicant( 594): RATE[5] rate=360 flags=0x0
D/wpa_supplicant( 594): RATE[6] rate=480 flags=0x0
D/wpa_supplicant( 594): RATE[7] rate=540 flags=0x0
D/wpa_supplicant( 594): p2p-wlan0-0: Flushing old station entries
D/wpa_supplicant( 594): nl80211: flush -> DEL_STATION p2p-wlan0-0 (all)
D/wpa_supplicant( 594): p2p-wlan0-0: Deauthenticate all stations
D/wpa_supplicant( 594): nl80211: Frame command failed: ret=-16 (Device or resource busy) (freq=2412 wait=0)
E/wpa_supplicant( 594): Using interface p2p-wlan0-0 with hwaddr 3a:d2:69:b7:a8:90 and ssid "DIRECT-9g"
D/wpa_supplicant( 594): WPS: Use configured UUID - hexdump(len=16): 4b 22 9e f8 47 f5 5a 44 bf 49 68 6e 6c b1 02 56
D/wpa_supplicant( 594): WPS: Build Beacon IEs
D/wpa_supplicant( 594): WPS: * Version (hardcoded 0x10)
D/wpa_supplicant( 594): WPS: * Wi-Fi Protected Setup State (2)
D/wpa_supplicant( 594): WPS: * Version2 (0x20)
D/wpa_supplicant( 594): WPS: * Device Name
D/wpa_supplicant( 594): WPS: * Primary Device Type
D/wpa_supplicant( 594): WPS: Build Probe Response IEs
D/wpa_supplicant( 594): WPS: * Response Type (3)
D/wpa_supplicant( 594): WPS: * UUID-E
D/wpa_supplicant( 594): WPS: * Manufacturer
D/wpa_supplicant( 594): WPS: * Model Name
D/wpa_supplicant( 594): WPS: * Model Number
D/wpa_supplicant( 594): WPS: * Serial Number
D/wpa_supplicant( 594): WPS: * Config Methods (4008)
D/wpa_supplicant( 594): GMK - hexdump(len=32): [REMOVED]
D/wpa_supplicant( 594): Key Counter - hexdump(len=32): [REMOVED]
D/wpa_supplicant( 594): WPA: Delay group state machine start until Beacon frames have been configured
D/wpa_supplicant( 594): WPS: Building WPS IE for (Re)Association Response
D/wpa_supplicant( 594): nl80211: Set beacon (beacon_set=0)
D/wpa_supplicant( 594): nl80211: Beacon head - hexdump(len=60): 80 00 00 00 ff ff ff ff ff ff 3a d2 69 b7 a8 90 3a d2 69 b7 a8 90 00 00 00 00 00 00 00 00 00 00 ...
D/wpa_supplicant( 594): nl80211: Beacon tail - hexdump(len=207): 2a 01 04 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 0c 00 2d 1a 7c 00 1d ff 00 ...
D/wpa_supplicant( 594): nl80211: ifindex=3
D/wpa_supplicant( 594): nl80211: beacon_int=100
D/wpa_supplicant( 594): nl80211: dtim_period=2
D/wpa_supplicant( 594): nl80211: ssid - hexdump(len=9): 44 49 52 45 43 54 2d 39 67
D/wpa_supplicant( 594): nl80211: proberesp (offload) - hexdump(len=324): 50 00 00 00 00 00 00 00 00 00 3a d2 69 b7 a8 90 3a d2 69 b7 a8 90 00 00 00 00 00 00 00 00 00 00 ...
D/wpa_supplicant( 594): nl80211: hidden SSID not in use
D/wpa_supplicant( 594): nl80211: privacy=1
D/wpa_supplicant( 594): nl80211: auth_algs=0x1
D/wpa_supplicant( 594): nl80211: wpa_version=0x2
D/wpa_supplicant( 594): nl80211: key_mgmt_suites=0x2
D/wpa_supplicant( 594): nl80211: pairwise_ciphers=0x10
D/wpa_supplicant( 594): nl80211: group_cipher=0x10
D/wpa_supplicant( 594): nl80211: beacon_ies - hexdump(len=104): 7f 08 04 00 00 00 00 00 00 40 dd 39 00 50 f2 04 10 4a 00 01 10 10 44 00 01 02 10 49 00 06 00 37 ...
D/wpa_supplicant( 594): nl80211: proberesp_ies - hexdump(len=228): 7f 08 04 00 00 00 00 00 00 40 dd 95 00 50 f2 04 10 4a 00 01 10 10 44 00 01 02 10 3b 00 01 03 10 ...
D/wpa_supplicant( 594): nl80211: assocresp_ies - hexdump(len=57): 7f 08 04 00 00 00 00 00 00 40 dd 18 00 50 f2 04 10 4a 00 01 10 10 3b 00 01 03 10 49 00 06 00 37 ...
D/wpa_supplicant( 594): WPA: Start group state machine to set initial keys
D/wpa_supplicant( 594): WPA: group state machine entering state GTK_INIT (VLAN-ID 0)
D/wpa_supplicant( 594): GTK - hexdump(len=16): [REMOVED]
D/wpa_supplicant( 594): WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0)
D/wpa_supplicant( 594): wpa_driver_nl80211_set_key: ifindex=3 (p2p-wlan0-0) alg=3 addr=0x76eef807 key_idx=1 set_tx=1 seq_len=0 key_len=16
D/wpa_supplicant( 594): broadcast key
D/wpa_supplicant( 594): wpa_driver_nl80211_set_operstate: operstate 0->1 (UP)
D/wpa_supplicant( 594): netlink: Operstate: linkmode=-1, operstate=6
D/wpa_supplicant( 594): p2p-wlan0-0: State: SCANNING -> COMPLETED
I/wpa_supplicant( 594): p2p-wlan0-0: CTRL-EVENT-CONNECTED - Connection to 3a:d2:69:b7:a8:90 completed (auth) [id=0 id_str=]
D/wpa_supplicant( 594): wpa_driver_nl80211_set_operstate: operstate 1->1 (UP)
D/wpa_supplicant( 594): p2p-wlan0-0: P2P: Station mode scan operation not pending anymore (sta_scan_pending=0 p2p_cb_on_scan_complete=0)
D/wpa_supplicant( 594): P2P: Group setup without provisioning
I/wpa_supplicant( 594): P2P-GROUP-STARTED p2p-wlan0-0 GO ssid="DIRECT-9g" freq=2412 passphrase="aAui190T" go_dev_addr=38:d2:69:b7:a8:91 [PERSISTENT]
D/wpa_supplicant( 594): P2P: Storing credentials for a persistent group (GO Dev Addr 38:d2:69:b7:a8:91)
D/wpa_supplicant( 594): P2P: Create a new persistent group entry
D/wpa_supplicant( 594): Writing configuration file '/data/misc/wifi/wpa_supplicant.conf'
D/wpa_supplicant( 594): Configuration file '/data/misc/wifi/wpa_supplicant.conf' written successfully
D/wpa_supplicant( 594): p2p-wlan0-0: Setup of interface done.
D/wpa_supplicant( 594): RTM_NEWLINK: operstate=1 ifi_flags=0x1002 ()
D/wpa_supplicant( 594): nl80211: Ignore interface down event since interface p2p-wlan0-0 is up
D/wpa_supplicant( 594): RTM_NEWLINK: operstate=1 ifi_flags=0x1043 ([UP][RUNNING])
D/wpa_supplicant( 594): RTM_NEWLINK, IFLA_IFNAME: Interface 'p2p-wlan0-0' added
D/wpa_supplicant( 594): nl80211: if_removed already cleared - ignore event
D/wpa_supplicant( 594): RTM_NEWLINK: operstate=1 ifi_flags=0x1003 ([UP])
D/wpa_supplicant( 594): RTM_NEWLINK: operstate=1 ifi_flags=0x11003 ([UP][LOWER_UP])
D/wpa_supplicant( 594): RTM_NEWLINK: operstate=1 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
D/wpa_supplicant( 594): RX ctrl_iface - hexdump(len=9): 52 45 43 4f 4e 4e 45 43 54
D/wpa_supplicant( 594): wlan0: Control interface command 'RECONNECT'
D/wpa_supplicant( 594): wlan0: Selecting BSS from priority group 0
D/wpa_supplicant( 594): wlan0: 0: 3a:d2:69:b7:a8:f6 ssid='DIRECT-N4' wpa_ie_len=0 rsn_ie_len=20 caps=0x11 level=-88 wps
D/wpa_supplicant( 594): wlan0: skip - disabled
D/wpa_supplicant( 594): wlan0: No suitable network found
D/wpa_supplicant( 594): wlan0: No enabled networks (8 disabled networks)
D/wpa_supplicant( 594): wlan0: Short-circuit new scan request since there are no enabled networks
D/wpa_supplicant( 594): wlan0: State: DISCONNECTED -> INACTIVE
D/wpa_supplicant( 594): wlan0: Setting scan request: 0 sec 0 usec
D/wpa_supplicant( 594): wlan0: No enabled networks - do not scan
D/wpa_supplicant( 594): wlan0: State: INACTIVE -> INACTIVE
D/wpa_supplicant( 594): wlan0: P2P: Station mode scan operation not pending anymore (sta_scan_pending=0 p2p_cb_on_scan_complete=0)
D/wpa_supplicant( 594): RX global ctrl_iface - hexdump(len=13): 4c 49 53 54 5f 4e 45 54 57 4f 52 4b 53
D/CommandListener( 116): Setting iface cfg
D/CommandListener( 116): Trying to bring up p2p-wlan0-0
D/WifiP2pService( 419): =====>>> GO: True
D/EndoluxeUtils( 419): ***
D/EndoluxeUtils( 419): console=ttymxc0,115200
D/EndoluxeUtils( 419): vmalloc=400M
D/EndoluxeUtils( 419): consoleblank=0
D/EndoluxeUtils( 419): rootwait
D/EndoluxeUtils( 419): androidboot.hardware=freescale
D/EndoluxeUtils( 419): androidboot.bootdev=mmcblk3
D/EndoluxeUtils( 419): androidboot.serialno=Endo_ffffffffffff
D/EndoluxeUtils( 419): wlcore.mac=00:19:B8:02:6F:33
D/EndoluxeUtils( 419): **** Could not detect Endoluxe product type ****
D/EndoluxeUtils( 419): **** Default Endoluxe product type: cyclops ****
D/WifiP2pService( 419): =====>>> Endoluxe Product: Cyclops
D/TetherController( 116): Starting tethering services
D/TetherController( 116): Tethering services running
I/WfdSink ( 896): p2p this deviceDevice: Android_8a16
I/WfdSink ( 896): deviceAddress: 38:d2:69:b7:a8:91
I/WfdSink ( 896): primary type: 10-0050F204-5
I/WfdSink ( 896): secondary type: null
I/WfdSink ( 896): wps: 0
I/WfdSink ( 896): grpcapab: 0
I/WfdSink ( 896): devcapab: 0
I/WfdSink ( 896): status: 0
I/WfdSink ( 896): wfdInfo: WFD enabled: trueWFD DeviceInfo: 17
I/WfdSink ( 896): WFD CtrlPort: 7236
I/WfdSink ( 896): WFD MaxThroughput: 50
D/WifiP2pService( 419): Started Dhcp server on p2p-wlan0-0
D/WebsocketService( 643): Broadcast Receive : android.net.wifi.p2p.CONNECTION_STATE_CHANGE
D/wpa_supplicant( 594): RX ctrl_iface - hexdump(len=16): 53 43 41 4e 5f 49 4e 54 45 52 56 41 4c 20 36 30
D/wpa_supplicant( 594): wlan0: Control interface command 'SCAN_INTERVAL 60'
D/wpa_supplicant( 594): wlan0: Setting scan interval: 60 sec
D/MainActivity( 896): Brodcast receive ::::: android.net.wifi.p2p.THIS_DEVICE_CHANGED
I/WfdSink ( 896): Received group info: network: DIRECT-9g, isGO: true, GO: Device: , deviceAddress: 38:d2:69:b7:a8:91, primary type: null, secondary type: null, wps: 0, grpcapab: 0, devcapab: 0, status: 4, wfdInfo: WFD enabled: falseWFD DeviceInfo: 0, WFD CtrlPort: 0, WFD MaxThroughput: 0, interface: p2p-wlan0-0, networkId: -1
W/ContextImpl( 896): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1150 android.content.ContextWrapper.sendBroadcast:365 com.fsl.wfd.WfdSink$1.onReceive:185 android.app.LoadedApk$ReceiverDispatcher$Args.run:759 android.os.Handler.handleCallback:733
W/ContextImpl( 896): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1150 android.content.ContextWrapper.sendBroadcast:365 com.fsl.wfd.WfdSink$3.onGroupInfoAvailable:258 android.net.wifi.p2p.WifiP2pManager$Channel$P2pHandler.handleMessage:740 android.os.Handler.dispatchMessage:102
I/dnsmasq ( 989): started, version 2.51 cachesize 150
I/dnsmasq ( 989): compile time options: no-IPv6 GNU-getopt no-DBus no-I18N DHCP no-scripts no-TFTP
W/dnsmasq ( 989): warning: no upstream servers configured
I/dnsmasq ( 989): DHCP, IP range 192.168.49.2 -- 192.168.49.254, lease time 1h
I/dnsmasq ( 989): DHCP, IP range 192.168.48.2 -- 192.168.48.254, lease time 1h
I/dnsmasq ( 989): DHCP, IP range 192.168.47.2 -- 192.168.47.254, lease time 1h
I/dnsmasq ( 989): DHCP, IP range 192.168.46.2 -- 192.168.46.254, lease time 1h
I/dnsmasq ( 989): DHCP, IP range 192.168.45.2 -- 192.168.45.254, lease time 1h
I/dnsmasq ( 989): DHCP, IP range 192.168.44.2 -- 192.168.44.254, lease time 1h
I/dnsmasq ( 989): DHCP, IP range 192.168.43.2 -- 192.168.43.254, lease time 1h
I/dnsmasq ( 989): DHCP, IP range 192.168.42.2 -- 192.168.42.254, lease time 1h
I/dnsmasq ( 989): read /etc/hosts - 1 addresses
D/wpa_supplicant( 594): EAPOL: disable timer tick
D/wpa_supplicant( 594): AP mode active - skip EAPOL Supplicant port status: Unauthorized
D/wpa_supplicant( 594): nl80211: BSS Event 59 (NL80211_CMD_FRAME) received for p2p-wlan0-0
D/wpa_supplicant( 594): p2p-wlan0-0: Event RX_MGMT (20) received
D/wpa_supplicant( 594): P2P: Parsing WPS IE
D/wpa_supplicant( 594): P2P: Config Methods (WPS): 0x4288
D/wpa_supplicant( 594): P2P: Device Password ID: 0
D/wpa_supplicant( 594): P2P: Primary Device Type (WPS): 10-0050F204-5
D/wpa_supplicant( 594): P2P: Parsing P2P IE
D/wpa_supplicant( 594): P2P: Attribute 2 length 2
D/wpa_supplicant( 594): P2P: * Device Capability 25 Group Capability 00
D/wpa_supplicant( 594): P2P: Attribute 6 length 5
D/wpa_supplicant( 594): P2P: * Listen Channel: Country IN(0x04) Regulatory Class 81 Channel Number 1
I/GlobalDismissManager( 875): no sender configured
D/AlertService( 875): Beginning updateAlertNotification
D/AlertService( 875): No fired or scheduled alerts
D/AlertService( 875): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
D/AlarmScheduler( 875): No events found starting within 1 week.
I/ActivityManager( 419): Resuming delayed broadcast
D/PuckEventReceiver( 714): android.net.wifi.p2p.CONNECTION_STATE_CHANGE
D/PuckEventReceiver( 714): =============== WIFI_P2P_CONNECTION_CHANGED_ACTION isServiceStarted:false
D/PuckEventReceiver( 714): NetworkInfo: type: WIFI_P2P[], state: CONNECTED/CONNECTED, reason: (unspecified), extra: (none), roaming: false, failover: false, isAvailable: true, isConnectedToProvisioningNetwork: false
D/PuckEventReceiver( 714): =============== WIFI_P2P_CONNECTION_CHANGED_ACTION : connected
D/PuckEventReceiver( 714): Send Broadcast of wfd-event connected
W/ContextImpl( 714): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1150 android.content.ContextWrapper.sendBroadcast:365 com.android.settings.wfd.PuckEventReceiver.sendWfdConnectedMessage:32 com.android.settings.wfd.PuckEventReceiver.onReceive:96 android.app.ActivityThread.handleReceiver:2407
D/EndoluxeReceiver( 643): Received intent action : android.net.wifi.p2p.CONNECTION_STATE_CHANGE
D/EndoluxeReceiver( 643): Group info requested
D/EndoluxeReceiver( 643): Group Member size : 0
I/ActivityManager( 419): Delay finish: com.android.providers.calendar/.CalendarProviderBroadcastReceiver
D/dalvikvm( 643): GC_CONCURRENT freed 442K, 10% free 4611K/5116K, paused 3ms+2ms, total 41ms
D/dalvikvm( 643): WAIT_FOR_CONCURRENT_GC blocked 8ms
D/MQTTService( 643): 38d269b7a890
D/wpa_supplicant( 594): P2P: * Listen Channel: Country XX(0x04) Regulatory Class 81 Channel Number 6
