Other Parts Discussed in Thread: Z-STACK
Memory corrupt in CC2538 after some data rx/tx over zigbee.
It works fine for 4-5 minutes after that i can see in memory it lost the table data on array of 5x250 size.
Dhaval
Hi Dhaval,
You will need to give us more details about what is going on. You mentioned Zigbee, which stack and/or application are your using (including the version)?
You can stop the debugger and check the call stack (in CCS, it is the debug window, in IAR, it is under the view menu), and see which line or function is causing the problem.
Also, are you using TI-RTOS, drivers or your own driver library?
Can you provide some code to show how and what you send your data?
Michel
