The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
SN65LBC180: SN65LBC180 replacing SN75LBC180
Part Number: SN65LBC180
Other Parts Discussed in Thread: SN75LBC180,
Hi team,
My customer is trying to migrate from SN75LBC180 to SN65LBC180.
They have different VOD range in different temperature range as follows:
  1. SN75LBC180: |VOD| 1.5V-5V under 0 to +70C
  2. SN65LBC180: |VOD| 1.1V-5V under -40 to +85C
What is the |VOD| range of SN65LBC180 under 0 to +70C?
Should the minimum |VOD| be 1.5V like SN75LBC180 by limiting temperature range?
My customer would like to check if SN65 can easily replace SN75 from VOD perspective.
Kazuki Itoh
  • Hi Kazuki-san,
    The behavior of these two devices should be very similar when within overlapping temperature ranges, so I would expect that the SN65LBC180 would show 1.5V Vod within the 0 - 70C range. However, because this is not specified in the datasheet explicitly it is not something we can guarantee as we can with the SN75LBC180.
    Today is a holiday in the US, so please give our RS-485 expert until Monday to respond with further input here.
    Eric Schott
  • Hi Eric-san,
    Thank you for the reply.
    Do you have any additional input from RS-485 expert?
    Kazuki Itoh
  • Hi Kazuki-san,
    Sorry, our RS-485 expert is still out of office. We will provide further comments once he is available again this week.
    Eric Schott
  • What is the |VOD| range of SN65LBC180 under 0 to +70C?
    It should be the same (or close to it). The ATE (automated test equipment) that screens the two parts are slightly different but if you limit the temperature for the part I would expect very close VoD results.
    -Bobby
