The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
[FAQ] [H] Frequently Asked Questions: Logic and Voltage Translation
Select this link to see answers to common questions, detailed use case implementations, and part recommendations for logic and voltage translation devices.        .
Top Logic and Voltage Translation FAQs - All-Time
How does a slow or floating input affect a CMOS device?
Why does a logic device's part number have an E4/G4 suffix?
What's the difference between TTL and 5V CMOS logic?
Can the input voltage (Vi) to my logic device be higher than the supply voltage (Vcc)?
What is the difference between TXS TXB and LSF devices?
Why do the leadframes look strongly oxidized or corroded?
How do I determine the output voltage (VOH, VOL) or output current (IOH, IOL) of a CMOS logic device?
Dual Footprinting - How to design around supply constraints and create flexibility for boards
What method is best used for estimating specification values between those given in the datasheet?
Use the links below to find an answer to your question. If your question is not answered, feel free to post a question in our E2E forum.
The "Use Cases and Part Recommendations" leads to a series of application briefs and videos that provide solutions to common system challenges while providing part recommendations.
Use Cases & Part
Recommendations
Monostable
Multivibrators
Voltage
Translators
Input
Parameters
Output
Parameters
Power
and Thermals
Timing
Parameters
Logic
Technology
Quality and
Manufacturing
Simulation
Models
