The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
replacement for hef4050 (driver) cd4096ube (inverter) due 3.3v instead 5v
Other Parts Discussed in Thread: TXB0108
For driving 4 datalines (2 as output and 2 as input) ihave have this buffered.
1 input and 1 output is normal, 1 input and 1 output is inverted.
works well with 5v ofcourse. But the voltage in the project is
changed to 3.3v. Wich ic I can use as replacement?
I can use inline a level shifter like TXB0108 but I want to
avoid that. I thought about the 74LVC06 and 74LVC07.
They need to drive the TIL 111 optocoupler. This is
because the data input is 15v TTL.
I prefer DIL-casing. Is this Availble?
