Other Parts Discussed in Thread: TPS82085, TPSM82864A, TPSM82810, TPSM82813
The thermal resistance information found in the TPSM82823 datasheet is significantly higher than other products with similar specifications.
Is the thermal resistance information in the TPSM82823 datasheet correct?
Will the customer have no problems with heat when using this product instead of the TPS82085 in the same environment?
Thank you.
