Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TPS548A20: Rtrip resistor design inquiry
Part Number: TPS548A20
My customer had an issue as the link below on the TPS548A20 they designed.
 - https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1230796/tps548a20-device-failure-history/4651108
Recently they found the below recommendation in the datasheet for the Rtrip resistor.
The TPS548A20 they designed was out of this range and used 68.1K (R2093).
Q1) Why is the resistance range limited?
Q2) What symptoms can occur when using values outside this range?
Thank you.
JH
