The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS7A91: PG glitch
Part Number: TPS7A91
Hi Team,
My customer finds that when the PG is pull up to Vout. There is a glitch at the PG. And the peak value is different as different pull up resistor. Below is the schematic and waveform (@100k pull up). Could you pls help analyze?
Hailiang
