BQ24640: Question about charge current
Part Number: BQ24640
My customer has some questions as follows.
Q1: 7.3.2 Output Current Regulation
Regarding the output current regulation, which is the set maximum charging current, peak current, valley current, or average current?
Q2: Charge current regulation accuracy
Datasheet specifies charge current regulation accuracy at VIREG_CHG = 40mV, 20mV, 5mV and 1.5mV. How about if VIREG_CHG > 40mV? The charge current regulation accuracy gets better? Could you show the data of “charge current regulation accuracy” for VIREG_CHG range = 50mV to 100mV?
K.Hirano
  • Hello Kazuhiko,
    The Output current regulation sets the maximum current.
    We don't have the date to provide an accurate answer.
    Christian.
  • Christian,
    Thank you for your responses.
    Let me confirm a bit more.
    Q1:
    The maximum current means peak current?
    Q2:
    Even if TI does not have data to be share, with VIREG_CHG > 40mV, the charge current regulation accuracy could theoretically be higher?
    K.Hirano
  • Hello Kazuhiko,
    Q1:
    Yes
    Q2:
    Yes, theorectically it could be higher, but without the data I can't confirm.
    Christian
