Can you please review the attached schematic for correct implementation of the AC coupling caps and associated resistors?
If the resistors always ensure CM voltage in this application why would they not be integrated into the mux die? This is an application specific mux so would it ever be a bad ideal to implement the resistors? It would sure make the routing more mistake proof by implement in die and not having to glom on resistor pads.
Dan
