The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
BQ24296M: RF noise issue.
Part Number: BQ24296M
Hello.
Our products using BQ24296M have an issue with RF noise that significantly affects on our RF subsystem at 868/915MHz.
RF noise from BQ24296M starts when switching converter goes to continuous current mode.
It looks like synchonous switching converter does not work well.
Switcing process has a long dead time. LSFET Rds on is relatively high.
I suspect that this causes RF noise, typical for non-syncronous converters.
Design description is here e2e.ti.com/.../bq24296m-emi-issue-during-pmic-switching
The suggestions from this topic did reduce the noise by 3-5 dB, which is insufficient.
Could you please suggest how to reduce RF noise further?
    Thank you for reaching out via E2E.
    The 3 techniques listed to reduce EMI shared in the previous thread you linked remain TI's recommendation. Can you please help to share more details on what you specifically implemented to reduce noise by 3-5 dB.
    My only additional suggestion is to try adding an EMI bead at VBUS input to further suppress noise.
    Garrett
  • Hi Garrett. Could you also comment on the issue regarding non-synchronous switching? Is it an expected behavior?
    BR, Vasyl.
  • Hi Vasyl,
    The BQ24296M is a synchronous buck converter as it has an integrated LSFET (denoted Q3 in functional block diagram on datasheet page 15).
    Dead time during switching is expected to ensure both switching FETs are not on at the same time therefore preventing shoot-through.
    Below is a waveform of SW node on BQ24296MEVM board and as you can see the dead time is within reason the same as you observe.
    Garrett
